Page 2 of 3 1 2 3
Re: leak [Re: HMurphey] #149181
07/10/08 07:12 PM
07/10/08 07:12 PM
Alachua, FL
Mugrace72 Offline
Mugrace72  Offline
Alachua, FL
Harry'
We took your advice and did the Statue....where were you?
I would never have gone to it had you not brought it up back in May. Thanks for the tip.
Jack Woehrle
HCA-NA 5022-1
USSailing 654799E
Alachua FL/Put-In-Bay
Re: leak [Re: Mugrace72] #149182
07/10/08 07:19 PM
07/10/08 07:19 PM
“an island in the Pacifi...
hobie1616 Offline
hobie1616  Offline
I was married to a blow-hard. She lives down in N. Carolina, or S. Car. ???
It was SC and I was married to her too!
You're both wrong. It was California and last I heard she's in Gig Harbor, WA.
US Sail Level 2 Instructor
US Sail Level 3 Coach
Re: leak [Re: HMurphey] #149183
07/10/08 07:32 PM
07/10/08 07:32 PM
U
ucfsailor19 Offline OP
U
Yeah they are near the bottom, checked the rest of the hull and I'm positive this is my major problem. Not to say that there are other small leaks but this is definitely the big one. I'm going to have to figure out how to get sandpaper down in there, going to have to be on a stick somehow...
Re: leak [Re: ucfsailor19] #149184
07/10/08 11:56 PM
07/10/08 11:56 PM
SE Pa. or Chesapeak Bay
HMurphey Offline
HMurphey  Offline
Pete,
A 5gallon paint stirrer work well ... but you may need to turn the hull over to work from the "bottom" ... mask the deck area as epoxy can run.
To Jack,
Congrats on your hanging in there and winning ... I'm planning on doing the "Statue" race next year when I hope to have the $$$$ (its been a rough year ... I'm unemployed again as of last Monday ... I'm having trouble finding steady full-time employment currently and the bills mounting)
Sometimes I know what I'm talking about, glad you enjoyed the race.
Sail Flat, Sail Fast
HarryMurphey
TheMightyHobie18/P19MX
Re: leak [Re: HMurphey] #149185
07/11/08 06:19 AM
07/11/08 06:19 AM
Alachua, FL
Mugrace72 Offline
Mugrace72  Offline
Alachua, FL
We'll look for you in 2009. Good luck for now.
Jack Woehrle
HCA-NA 5022-1
USSailing 654799E
Re: leak [Re: Mugrace72] #149186
07/13/08 08:04 AM
07/13/08 08:04 AM
U
U
Hey guys,
I worked on fixing the leak for the boat, figure i'd share how I did it.
Parts List
West Marine Epoxy kit
Home Depot Paint stirrers (Two small ones and One Big one)
Home Depot 1" paint brush (As many as you need)
Home Depot sanding blocks, I got 60 grit.
Gorrila super glue (This stuff is amazing)
So I glued two of the small paint stirrers together. And then I glued the sanding block to the end of small paint stirrer (I don't have pictures but it can really only be glued on one way to work down in the slot).
Now you have your sanding tool. The reason I got the big paint stirrer is when you have the two small paint stirrers and the sanding block contraption it is hard to apply pressure on the sanding block to sand well. Well the big paint stirrer was in my other hand and I used it to push on the sanding block.
Once I was done sanding, I attempted to rip the sanding block off the paint stirrers, which didn't work well, that glue is really good.
Once I had the sanding block off, I glued the 1" paint brush to the end of the paint stirrers. And used that to paint on the epoxy.
I was even able to use the big paint stirrer to help lay the fiberglass down, which worked out a lot better than I thought it would.
Thanks again for your guys' help,
Pete
Re: leak [Re: ucfsailor19] #149187
07/14/08 08:36 PM
07/14/08 08:36 PM
HMurphey Offline
HMurphey  Offline
Pete,
That's a GREAT IDEA about using the Gorilla glue!!!! You taught me something ... I'm going to file that little trick away for future use.
HarryMurphey
TheMightyHobie18/#9458, Fleet 54/Div11
P19MX/#86, CRAC
Re: leak [Re: HMurphey] #149188
07/14/08 11:19 PM
07/14/08 11:19 PM
Albuquerque NM
Banzilla Offline
Banzilla  Offline
Albuquerque NM
In the immortal words of Elwood Blues, "This is glue. Strong stuff!"
I could not find a sound clip, but I am sure one of you will.
Sam
[b] Sail Like you have a Pair
Re: leak [Re: Banzilla] #149189
07/15/08 11:53 AM
07/15/08 11:53 AM
rexdenton Offline
rexdenton  Offline
Sam
Actually, Elwood is more specific; "This is MARINE glue...Strong stuff!!"
Nacra F18 #856
Re: leak [Re: rexdenton] #149190
07/15/08 12:35 PM
07/15/08 12:35 PM
Song - Minnie the Moocher - Curtis (Cab Calloway)
[Throughout the song, Jake and Elwood sneak up to the hotel. They come across the Winnebago. Elwood enters and glues down the accelerator.]
Elwood: This is glue. Strong stuff!
[The song ends. Police officers arrive in the audience.]
"Our Lady of Blessed Acceleration, don't fail me now!"
Re: leak [Re: mbounds] #149191
07/15/08 01:57 PM
07/15/08 01:57 PM
It's about time I watched that again...I don't remember either of those lines (and for four years, I played in the horn section of a Blues Brothers impersonation band in Cleveland, OH).
Re: leak [Re: Jake] #149192
07/15/08 03:59 PM
07/15/08 03:59 PM
Jake & Matt - with your small boat building experience, what would you say about Nida-core?
I see it's distributed locally (FL), but have to figure the cost is pretty high, even if you don't compare it to end grain balsa...
Re: leak [Re: waterbug_wpb] #149193
07/16/08 06:48 AM
07/16/08 06:48 AM
I don't deal much with cores. I do use balsa core for some of the structural components (primary bulkhead and subdeck/radio-tray) in my one meter but that's about it.
It looks like Nida-core makes a lot of different kinds of core materials...which one in particular?
Re: leak [Re: Jake] #149194
07/16/08 03:54 PM
07/16/08 03:54 PM
I think they indicate the aluminum honeycomb vartiety is for marine hull usage...
Not that I have any idea how to design lay-up for composite boats, but it's fun to imagine...
Re: leak [Re: Jake] #149195
07/16/08 04:37 PM
07/16/08 04:37 PM
radio-tray???
Lets see some schematics... where do you put a radio? where are your speakers? how do you power it? Inquiring minds NEED to know
Re: leak [Re: ] #149196
07/17/08 07:48 AM
07/17/08 07:48 AM
radio-tray???
nooooo...remote control radio and servos for a 1 meter monohull.
Re: leak [Re: Jake] #149197
07/17/08 08:37 AM
07/17/08 08:37 AM
gotcha...
I was hoping for some inspirational new ways to blare tunes while sailing.... but no.. All i get are your controls for your pigmy racer!
Re: leak [Re: ] #149198
07/17/08 09:28 AM
07/17/08 09:28 AM
THey have small speakers for an IPOD if memory serves.
Put those bad boys on the spreaders and point downward, or put them on the boom pointing rearward...
Re: leak [Re: ] #149199
07/17/08 10:02 AM
07/17/08 10:02 AM
Full Wave Audio: Got a waterproof Ipod holder, Ipod controls, and 12v battery good enough for (rocking loud and great quality) tunes for an entire Tybee 500 leg and then some.
Re: leak [Re: Jake] #149200
07/17/08 10:37 AM
07/17/08 10:37 AM
ThaT looks awesome.. where did you get it? what did it cost? when i google that i get parts, not an enire system
http://www.watercraftinnovations.com/index.cfm
Page 2 of 3 1 2 3
0 registered members (), 20,780 guests, and 1,475 spiders.
Most Online22,490
Yesterday at 08:14 AM
