| New main won't slide into comp tip #149419 07/13/08 09:45 AM 07/13/08 09:45 AM |
Joined: Nov 2007 Posts: 50 Severna Park, MD David_Nolte OP
Posts: 50 Severna Park, MD | I got a set of new sails, but the bolt rope in the luff of the main is larger than on my old sail and the top tip of it gets hung up and won't slide up into the comp tip. I've been putting packing tape on each time I sail to squeeze the top of the luff and give it a smoother entry. Anybody got any long term suggestions? Thanks.
David Nolte H16, H14, Nacra 5.0
| | | Re: New main won't slide into comp tip
[Re: David_Nolte]
#149420 07/13/08 01:52 PM 07/13/08 01:52 PM |
Joined: Sep 2007 Posts: 224 Cincinnati, Ohio Tri_X_Troll
Posts: 224 Cincinnati, Ohio | If they're from Hobie, there is no reason the bolt rope should be bigger. Sounds like your luff track might be damaged.
Ryan - H16
I prefer to go sailing because baseball, football, tennis, and golf only require 1 ball!
[Re: Tri_X_Troll]
#149421 07/14/08 09:42 AM 07/14/08 09:42 AM |
Posts: 50 Severna Park, MD | Nope, the luff track is fine. The old blown out sails run up just fine. The rope with its sheathing are slightly larger on the new sails. And when it gets stuck up there at the comptip, it gets smooshed, which makes it larger still and makes the problem that much worse.
The root of the problems seems to be that the top of the bolt rope is flat, it's a hard edge at the cut. Maybe something could be sewn on to give it a tapered edge so it slides into the comptip easier. Has anyone had a similar problem? And solved it? Thanks.
[Re: David_Nolte]
#149422 07/14/08 10:13 AM 07/14/08 10:13 AM |
Posts: 164 fort Myers, FL | First thing I would try is to lube the boltrope with McLube Sailkote or something similar, and to round off the bottom edges of the comptip track, before modifying the sail.
Arie Hobie 16 111812
246
guests, and 35
