Cat Trax Leaks #149573
07/14/08 08:15 PM
07/14/08 08:15 PM
Thunder Bay ON CAN
M
mmadge Offline OP
mmadge  Offline OP
M
Thunder Bay ON CAN
I bought some Hobie cat trax used.Unfortunatly the tires have small holes in the side walls (seller did not mention this).I brought them to a garage and the guy put some plugs in them but was not sure they will hold.Any other suggestions.I was wondering if you can put a tube in the tire?
Re: Cat Trax Leaks [Re: mmadge] #149574
07/14/08 10:39 PM
07/14/08 10:39 PM
Westport, Ma. U.S.A.
Brian_Mc Offline
Brian_Mc  Offline
Yes on the tubes! There was a recent post about just that. Do a search here to find the links. You can also use the patch in a can, but it will gum up the insides, and may make it harder to remove the tires should you ever decide to get tubes. You also have to spin them for a long long time to spread the goop around inside the tire.
Re: Cat Trax Leaks [Re: Brian_Mc] #149575
07/15/08 07:30 AM
07/15/08 07:30 AM
Rick's got the tubes here in the Catsailor store if I remember correctly - they were tricky to find.
Re: Cat Trax Leaks [Re: Jake] #149576
07/15/08 08:58 AM
07/15/08 08:58 AM
RickWhite Offline
RickWhite  Offline
Here is the link to the tubes
https://store.catsailor.com/pc/viewPrd.asp?idcategory=0&idproduct=20045
Actually, this new store is really pretty easy to find things.
Of course there is shopping by category, but Also by brands or simply key words in the search.
I found the tubes by selecting Browse by Brands, then Cat Trax, and there were the tubes.
Also, I typed tubes in the search box and the Inner Tubes were the first item that came up.
Simple, really. <img src="http://www.catsailor.com/forums/images/graemlins/smile.gif" alt="" />
And tubes are the only way to go. I was really going nuts with my Cat Trax, Euros, etc. and Then I got the tubes and no more problems.., they are always inflated and ready to go. No more last minute pumping.
Rick
Rick White
www.onlinemarinestore.com
Re: Cat Trax Leaks [Re: RickWhite] #149577
07/15/08 03:47 PM
07/15/08 03:47 PM
Netherlands
Genealex Offline
Genealex  Offline
Netherlands
here's the thread:
cattrax vs eurotrax
Re: Cat Trax Leaks [Re: mmadge] #149578
07/15/08 03:55 PM
07/15/08 03:55 PM
Thunder Bay ON CAN
M
mmadge Offline OP
mmadge  Offline OP
M
Thunder Bay ON CAN
Thanks Guys
Re: Cat Trax Leaks [Re: Genealex] #149579
07/16/08 11:05 AM
07/16/08 11:05 AM
RickWhite Offline
RickWhite  Offline
No need to use "verses" anywhere. There is now only ONE beach wheel manufacturer -- Cat Trax.
Euro stopped marketing in the USA because of the dollar value and Cateez can no longer get wheels -- discontinued until further notice, and it has already been 7 months.
Rick
Rick White
0 registered members (), 474 guests, and 30 spiders.
