| Silicone Sealers #149765 07/17/08 07:54 PM 07/17/08 07:54 PM |
Joined: May 2008 Posts: 22 North of Los Angeles, Californ... marshall OP
Posts: 22 North of Los Angeles, Californ... | I've seen in past posts about 3M 5200 Silicone, recommended for sealing the seams and rivets on masts, as well as other things. Is there really a difference, by using 5200? I've looked for 3M 5200 in some stores. Just can't find it, but I have seen various Silicone sealers and adhesives by 3M, Permantex and other brands. I'm referring to the sealer that people here refer to, for spreading around existing rivets and seams on a mast, to prevent water from getting inside. Also the gaps where the front and rear crossbars meet the hulls, also to reduce the chance of water entering the hulls in this area. So, why find and use 3M 5200, instead of the more common silicone sealers I see? Marshall | | | Re: Silicone Sealers
[Re: marshall]
#149766 07/17/08 10:07 PM 07/17/08 10:07 PM |
Posts: 12,310 South Carolina | I've seen in past posts about 3M 5200 Silicone, recommended for sealing the seams and rivets on masts, as well as other things. Is there really a difference, by using 5200? I've looked for 3M 5200 in some stores. Just can't find it, but I have seen various Silicone sealers and adhesives by 3M, Permantex and other brands. I'm referring to the sealer that people here refer to, for spreading around existing rivets and seams on a mast, to prevent water from getting inside. Also the gaps where the front and rear crossbars meet the hulls, also to reduce the chance of water entering the hulls in this area. So, why find and use 3M 5200, instead of the more common silicone sealers I see? Marshall I don't think anything comes close to the durability, adhesion, and toughness of 3M 5200. It's very difficult to remove once it sets up. I live 180 miles inland from the coast yet all our local Wal-Marts carry 3M 5200 in the marine section. You can also order it from the store on this website.
Jake Kohl | | | Re: Silicone Sealers
[Re: marshall]
#149768 07/18/08 12:09 PM 07/18/08 12:09 PM |
Posts: 1,200 Vancouver, BC | 5200 has its uses...but generally best left for things that will never/hardly ever need separating. It normally is very tough to remove...but I found a product that does a good job on it and is safe for your boat surfaces/paint. Debond Marine Formula I use 5200 (or sometimes the faster curing 4200) to hold the mylar centerboard slot strips on my Tornado's keel line. Holds that on indefinately until I need to swap them out. Note the cure times for 5200 are 24-72 hrs, depending on humidity (reaction is moisture dependant).
238
guests, and 21
