| Pitchpole? #149871 07/18/08 09:27 PM 07/18/08 09:27 PM |
Joined: Sep 2007 Posts: 224 Cincinnati, Ohio Tri_X_Troll OP
Posts: 224 Cincinnati, Ohio | Ouch. Did it for the first time today. Ended up with some nasty rope burn and had to friendly couple in a canoe help me right it.
What I am wondering, though I'm sure I've read it somewhere, is it safe to assume that cats are most prone to pitchpole when sailing on a beam reach or a close reach?
It was blowing about 15kts and I was aft on the trampoline, sailing somewhere between a beam reach and a close reach. Wasn't even flying a hull and the stb hull burried and over I went.
I found my boat was much more prone to stuff a bow than it was to fly a hull. I was able to fly a hull when sailing close hauled, upwind, but just barely and even then it was wanting to burry a hull. Is this normal, or am I doing something wrong and trying to sail it like a monohull?
Any pointers?
Ryan - H16
I prefer to go sailing because baseball, football, tennis, and golf only require 1 ball!
| | | Re: Pitchpole? Possible rigging issues?
[Re: Tri_X_Troll]
#149872 07/18/08 09:49 PM 07/18/08 09:49 PM |
Posts: 168 San Diego | If your mast is raked too far forward you may be more prone to pitchpole. | | | Re: Pitchpole?
[Re: Smiths_Cat]
#149874 07/19/08 08:44 PM 07/19/08 08:44 PM |
Posts: 757 japan | all cats will do it if pushed hard enough
some cats are more prone to it than others
basically it depends on how much hull volume there is forward of the main beam
hobie 16's are 1 of the most likely to pitchpole due to their small hull volume forward of the main beam
search youtube for pitchpole
[Re: hokie]
#149876 07/19/08 11:47 PM 07/19/08 11:47 PM |
Posts: 1,479 Thailand | All of the above but first try adjusting mast rake back two holes. cool:
| | | Re: Pitchpole?
[Re: Gilo]
#149879 07/20/08 02:37 PM 07/20/08 02:37 PM |
Posts: 571 Hamburg | An eased jib and main will push the nose down ? On my Dart 18, easing the jib, was efficent to avoid a pitchpole. On H16 and other non spi boats, you cannot drop the traveller because it is max out on a broad reach... at least I think that is the way I sailed my Dart. Cheers, Klaus | | | Re: Pitchpole?
[Re: Smiths_Cat]
#149880 07/20/08 03:05 PM 07/20/08 03:05 PM |
Joined: Sep 2007 Posts: 531 Lake Murray SC FasterDamnit
Posts: 531 Lake Murray SC | An eased jib and main will push the nose down ? On my Dart 18, easing the jib, was efficent to avoid a pitchpole. On H16 and other non spi boats, you cannot drop the traveller because it is max out on a broad reach... at least I think that is the way I sailed my Dart. Cheers, Klaus As a long time H16 crew in my youth when we still had reaching legs, popping the jib allowed the bow to come up without loosing too much velocity. If I could keep the leeward bow flirtin' w/ disaster better then the next boat, we made time and occasionally a boat.
E-Scow 24' ULDB
1 registered members (FredL),
2,799
guests, and 283
