Anti - bird mast top cover #150028
07/20/08 01:23 AM
07/20/08 01:23 AM
Hamburg
Smiths_Cat Offline OP
Hamburg
Hi
Birds picked the top sealing of my carbon mast. <img src="http://www.catsailor.com/forums/images/graemlins/frown.gif" alt="" />
The top of the mast was sealed with foam covered with a soft plastic. It was white.
I want to glue another piece of plastic on it or laminate glass over it. Is there any color (red, yellow...?) which keeps birds away?
Just curious, does anyone had the same problem?
Cheers,
Klaus
Re: Anti - bird mast top cover [Re: Smiths_Cat] #150029
07/20/08 02:22 AM
07/20/08 02:22 AM
I did a Google search using the phrase, "Colors that repel birds" and came up with some ideas.
Like when you are not sailing, turn your mast into a flagpole by attaching a retrieval line to your halyard shackle (or tie the halyard to itself to make it continuous) and use the halyard to hoist to the top of the mast a bright-colored balloon or a strip of bright-colored metallic tape that will wave in the breeze.
Products like this are actually available for the purpose of repelling birds, but you could probably come up with something yourself. Here are two links.
http://izola.co.uk/birds/products/itape.htm
http://www.gemplers.com/product/TEB/Scare-Eyes-Bird-Control-Balloon
Let us know what works.
Re: Anti - bird mast top cover [Re: Mary] #150030
07/20/08 06:54 AM
07/20/08 06:54 AM
Atlanta
bvining Offline
bvining  Offline
Atlanta
Mary,
Great idea, the seagulls have been using my boat as a picnic table. I cant believe the mess they make.
Bill
Re: Anti - bird mast top cover [Re: Smiths_Cat] #150031
07/20/08 07:22 AM
07/20/08 07:22 AM
GISCO Offline
GISCO  Offline
I had the same problem. After replacing the foam plug, I cut a piece of light aluminum the shape of the mast with a small tab on each side to bend over the mast. Then fastened it with pop rivets.
Gordon
Re: Anti - bird mast top cover [Re: GISCO] #150032
07/20/08 10:56 AM
07/20/08 10:56 AM
2017 F18 Americas Site
Dan_Delave Offline
Dan_Delave  Offline
I put a large zip tie on the top of the mast. There is a hole to attach it to. I mount is so the end sticks straight up so the birds cannot perch up there comfortably. Like the spike idea, that many big boat masts have, but cheap and easy to mount.
Later,
Dan
Re: Anti - bird mast top cover [Re: Mary] #150033
07/20/08 02:42 PM
07/20/08 02:42 PM
Hamburg
Hamburg
Wow Mary, you have really creative ideas. I like the holographic balloon.
Today I glued a red piece of plastic on the top. If this does not work, I will try the bright metallic tape.
Thanks and cheers,
Klaus
Re: Anti - bird mast top cover [Re: Smiths_Cat] #150034
07/21/08 07:17 AM
07/21/08 07:17 AM
Thanks and cheers,
Klaus
What about taking some stainless welding rod (or other small straight wire) and poking it into the foam at odd angles like those other bird repellent spikes you see on buildings? No bird would ever land there again.
Re: Anti - bird mast top cover [Re: Jake] #150035
07/21/08 08:15 AM
07/21/08 08:15 AM
Looks like it would also be a lightning rod. <img src="http://www.catsailor.com/forums/images/graemlins/frown.gif" alt="" />
0 registered members (), 2,609 guests, and 268 spiders.
