| Re: A-class, "hydrofoils not permitted" violated?
[Re: Wouter]
#150269 07/23/08 03:35 PM 07/23/08 03:35 PM |
Posts: 1,226 Atlanta | Place the daggerboards under a 10 degress inward angle and have the hull both canted outward by 10, ehh voila according to the whigs at ISAF this boat is not using any hydrofoiling effect to lift it out of the water. Because the starboard daggerboard in in line with the port hull centreline. I'm pretty sure that the rule reads that each board has to be in line with its own hull centerline. | | | Re: A-class, "hydrofoils not permitted" violated?
[Re: Rhino1302]
#150270 07/23/08 03:54 PM 07/23/08 03:54 PM |
Posts: 12,310 South Carolina | you have two hulls and two centerlines...no problem. Two non-parallel centerlines? How do you define centerline? That was kinda my point. My boat's hulls are canted outward. As you look at the bows, they tilt inward at the top. The daggerboards and rudders are in line with the plane of each hull such that the hull, the board, and the rudder of the leeward hull is nice and plumb when flying a hull...many a-cats are that way (and so is the Nacra 20). I was just pointing out that it's tricky to define all this stuff...including what the vertical plane of a hull is.
Jake Kohl | | | Re: A-class, "hydrofoils not permitted" violated?
#150271 07/23/08 04:05 PM 07/23/08 04:05 PM |
Joined: Jul 2001 Posts: 256 North Europe, Sweden, Uppsala Hakan Frojdh OP
Posts: 256 North Europe, Sweden, Uppsala | One way of doing this is to remove the hydrofoil and min board tip distance rule and require that the centerboards and rudders must be straight and enter and exit the hulls through the centerline and that they are flush with the hull when they are fully retracted.
I guess that solid wings should be stopped also by require a min soft sail area or something like that.
I'm not sure how we should handle the case if someone shows up with a kite on their A-class.....
Or it's maybe time to try to find a single handed one design class, that is light, fast and has big turnout at the regattas. Any suggestions?
/hakan
[Re: bvining]
#150273 07/23/08 05:21 PM 07/23/08 05:21 PM |
Posts: 1,307 Asuncion, Paraguay | Anybody got a copy of ISAF Equipment Rules for sailing?
Look up hydrofoil.
Then look up daggerboard and rudder.
I just did that. The daggerboard is defined as "a retractable hull appendage, attached aproximately on the hull centreplane and not rotating, primarily used to affect leeway". The rudder is defined as "a movable hull apendage primarily used to affect steerage" The words "hydrofoil" and "foil" are not present in the document. The axis are referred to the waterplane with the boat in measurement trim, not the waterplane when moving. I see nothing there very helpful to prevent lift generating devices. All the best.
Luiz
[Re: bvining]
#150274 07/24/08 08:30 AM 07/24/08 08:30 AM |
Posts: 548 MERRITTISLAND, FL | I'm pretty sure that the rule reads that each board has to be in line with its own hull centerline. The resticted rule set does pretty well to keep this in check - even if they neglected to publish it on the site. No one seemed to upset about canted boards. A curved one with the same inboard and outbord limits keep the thing virtually identical in net force. It is impossible to restrict the board to be on a hull centerline as you then have to write a rule about the shape a hull can be as there may not be a centerline on an asymetrical hull. If you cant a symetric hull and put the board in straight, they are in effect now canted. Straight foils canted foils and limited curved foils all produce some lift forces. This is why the technical committee removed the hydrofoil reference and in its place restricted the limits of the foils. These boats have been measured and allowed to compete, so for the time being the argument is moot. There are several petitions being submitted to address this and it will go through the proper procedure to be voted on by the class and potentialy have the rules rewritten to address it. | | | Re: A-class, "hydrofoils not permitted" violated?
[Re: claus]
#150276 07/24/08 09:29 AM 07/24/08 09:29 AM |
Posts: 3,116 Annapolis, MD | Hmmmn... did the A class experience the recent growth spurt because lots of sailors discovered they liked designing and building faster sailboats to race and joined the class and built or bought the latest design ...
Or did the A class grow because a lot sailors wanted a light weight, high performance single sailed boat with great international sailors at the top of the list and got a boat to play?
I know I waited to see how the class dealt with the foil issue the first time.... If they had voted Yeah on the disruptive foil technology... I would have waited and bought a boat for 1/3 the price.
crac.sailregattas.com
#150277 07/25/08 10:16 AM 07/25/08 10:16 AM |
Posts: 805 Gainesville, FL 32607 USA | Re Jake's A-cat AND MINE TOO: "My boat's hulls are canted outward, bows tilt inward at the top. The daggerboards and rudders are in line with the vertical plane of each hull such that the hull, the board, and the rudder of the leeward hull plumb when flying a hull". So--- the newer boats have the boards tilted in, so that they get lift from the boards when heeled at speed, a big advantage when doing the Wild Thing. To add insult to injury, it appears that inward canted banana boards provide even MORE lift. By the way---- Lift = hydrofoils
[Re: dacarls]
#150278 07/25/08 11:35 AM 07/25/08 11:35 AM |
Posts: 12,310 South Carolina | Dave,
Come on...what would you know about the subject?
[Re: bvining]
#150281 07/25/08 07:42 PM 07/25/08 07:42 PM |
Joined: Sep 2006 Posts: 613 New Hampshire, USA windswept
Posts: 613 New Hampshire, USA | Bill,
I would think that Canted boards and curved boards would be viewed and treated the same way. That is how I responded to the vote anyway. if canted boards which are already in use throughout the class, then banana boards should be too. As to obsoleting the whole class, my Boyer is probably close to being there anyway. Where I think this will effect the class the most is those who own newer boats.
Tom Siders A-Cat USA-79 Tornado US775
718
guests, and 178
