Taipan 4.9 Shroud Lengths #150289
07/22/08 07:34 PM
07/22/08 07:34 PM
Maryland, USA
PRagen Offline OP
PRagen  Offline OP
Maryland, USA
Does anyone have the standard lengths for Taipan 4.9 shrouds? My shrouds were severely damaged in a storm and are so coiled up I can't determine the length. See attached photo.
The boat was stored on the beach and got tangled up with a few others that went flying. The mast did not survive either, but I have a new mast and should be back on the water soon.
Patrick Ragen
Taipan 4.9 USA 274
Re: Taipan 4.9 Shroud Lengths [Re: PRagen] #150290
07/23/08 12:31 AM
07/23/08 12:31 AM
Central California
ejpoulsen Offline
ejpoulsen  Offline
Central California
OUCH!!!!
Eric Poulsen
A-class USA 203
Ultimate 20
Central California
Re: Taipan 4.9 Shroud Lengths [Re: ejpoulsen] #150291
07/23/08 02:26 AM
07/23/08 02:26 AM
Adelaide South Australia
ratherbsailing Offline
send an email to greg at AHPC. he will help
Re: Taipan 4.9 Shroud Lengths [Re: ratherbsailing] #150292
07/23/08 02:01 PM
07/23/08 02:01 PM
Maryland, USA
PRagen Offline OP
PRagen  Offline OP
Maryland, USA
Thank, I tried that. Usually Greg is good about replying that but I have not received any replies to recent e-mails on the topic. Maybe he is on vacation or something.
Patrick Ragen
Taipan 4.9 USA 274
Re: Taipan 4.9 Shroud Lengths [Re: PRagen] #150293
07/23/08 04:39 PM
07/23/08 04:39 PM
australia
self_inflicted Offline
australia
Hi Patrick
This is from the build instructions,that i have from 1994
They say sidestays: 6120mm +GYS 131 adjuster(i think that is there adjuster) 3mm 1x19 wire
Forestay: 5570mm +GYS 133 adjuster
I know when i made mine i measured from the bearings surface of both thimbles.I didn't use there adjusters
Hope this helps
Re: Taipan 4.9 Shroud Lengths [Re: self_inflicted] #150294
07/23/08 04:49 PM
07/23/08 04:49 PM
Hobart, Tasmania, Oz.
Dazz Offline
Dazz  Offline
Greg is probably still in transit from the f18 worlds in spain.
C2 AUS 222 by Goodall design
"Darph Bobo"
Re: Taipan 4.9 Shroud Lengths [Re: self_inflicted] #150295
07/23/08 06:46 PM
07/23/08 06:46 PM
Maryland, USA
PRagen Offline OP
PRagen  Offline OP
Maryland, USA
Hi Patrick
Hope this helps
Richard, Thanks.
Someone from AHPC finally did respond since Greg is out.
Their 2004 data for the sidestays says 6015mm "b/s to b/s staymaster to swage eye" (The one eye attaches directly to the Staymaster adjuster)
But a newer spec for 2008 shows "...OR 6120mm for GYS tube adjuster - b/s terminal eye". So I guess there has been adjuster changes over the years.
Their forestay spec agrees with your comment.
Patrick Ragen
Taipan 4.9 USA 274
0 registered members (), 2,694 guests, and 623 spiders.
Yesterday at 10:10 AM
