painting the hulls blue #150296
07/22/08 08:16 PM
07/22/08 08:16 PM
Ocean Springs, MS
Capt_Cardiac Offline OP
Ocean Springs, MS
I'm contemplating painting my white hulls dark blue. only because i want to and i always loved dk blue hulls. the question i have is are there any legit reasons not to paint them a dark color? is heat a real issue? i know they will scuff but i'm willing to deal with that.
what do you think? thanks
cc
Capt Cardiac
Ocean Springs Yacht Club
Sailor
Nacra20 - Flight of Ideas #5
Re: painting the hulls blue [Re: Capt_Cardiac] #150297
07/22/08 08:29 PM
07/22/08 08:29 PM
Use gelcoat. Sand off most, or all of the existing gelcoat and tint the new stuff any shade you like.
Re: painting the hulls blue [Re: fin.] #150298
07/23/08 12:13 AM
07/23/08 12:13 AM
TeamChums Offline
TeamChums  Offline
Awlgrip not gelcoat. Much easier to paint and lasts longer than gelcoat.
Lee
Lee
Re: painting the hulls blue [Re: Capt_Cardiac] #150299
07/23/08 06:20 AM
07/23/08 06:20 AM
There are other threads that deal with this issue extensively. One was in the last month or two. Try to find that.
Paint seems like the easiest choice. Two years from now, when you're tired of the constant cosmetic repairs, you can sand it off and do it the right way.
Re: painting the hulls blue [Re: Capt_Cardiac] #150300
07/23/08 06:46 AM
07/23/08 06:46 AM
Atlanta
bvining Offline
bvining  Offline
Atlanta
Ive heard a number of reasons for white boats, most of them are that white boats dont stick out on the starting line.
If you are working with room temp cure epoxy, you need to be careful with it softening above 140 deg F. A dark color surface can get to 160 deg F in the sun on a 100 deg day in Texas.
The HT hulls are vinylester and glass, so I dont believe you have to worry about heat. You could find a resin chemist and ask them if vinylester will soften at or below 160 deg F.
Or you could just keep the hulls covered, or in the shade, or splash them with water before you put them under any stress.
Go for paint, it looks better then gelcoat.
Bill
Re: painting the hulls blue [Re: fin.] #150301
07/23/08 06:57 AM
07/23/08 06:57 AM
Atlanta
bvining Offline
bvining  Offline
Atlanta
Two years from now his boat will still look great, with little or no maintenance if its been painted with a two part marine paint.
Re: painting the hulls blue [Re: bvining] #150302
07/23/08 09:55 AM
07/23/08 09:55 AM
Bill
Maybe I'll paint a stealth color (some sort of green/gray) so they won't even see me over early! Then change color for the finish line...
If you're painting, why not go with the color-flecs that change the hue of the paint depending on what angle you're viewing it from? Kind of like the "mother of pearl" finish on cars. Always liked that....
Or THIS color:
Re: painting the hulls blue [Re: Capt_Cardiac] #150303
07/23/08 10:32 AM
07/23/08 10:32 AM
In New England we say there's only two colors to paint a boat, white and black...anyone who paints a boat black is crazy.
Regards
Chet
Re: painting the hulls blue [Re: ] #150304
07/23/08 11:03 AM
07/23/08 11:03 AM
I was wondering why they dont make white tramps as my black tramp gets very hot in the florida summer sun..
I also used to have a black mast on my TheMightyHobie18 that was to hot to hold for more than a few seconds and would burn off all my fingerprints (kidding)
Re: painting the hulls blue [Re: Capt_Cardiac] #150305
07/23/08 11:07 AM
07/23/08 11:07 AM
Gulf Coast
tami Offline
tami  Offline
Gulf Coast
Legit reasons:
The hulls will get phenomenally hot. At the very least you want to paint the decks a lighter color.
You won't be seen as well if Goddess forbid you should need help. Blue hull, blue water, you won't stand out much... White is bad for that too, for that matter...
Re: painting the hulls blue [Re: ] #150306
07/23/08 11:14 AM
07/23/08 11:14 AM
Atlanta
bvining Offline
bvining  Offline
Atlanta
The all white boat thing is boring....
what about a reflective mirrored coating, or wood grain, or hawaiian shirt material, or clear coated carbon/kevlar, anything other than boring old white gel coat.
I toyed with doing something really differient, like a wood grain veneer in the mold, but never pulled the trigger.
Peter Johnstone painted his HT a silver with a slight fleck, that was really neat looking.
Re: painting the hulls blue [Re: bvining] #150307
07/23/08 11:32 AM
07/23/08 11:32 AM
Bill - have you seen the Chromaveil products? They're some sort of printed fabric/substrate that you include in the lamination for, what appears to be, a really wild exterior finish. There are some other sites where people are talking about application experience with it. It appears, however, that it doesn't work well with in conjunction with dark colored fabrics (carbon).
http://chromaveil.com/5001tub.html
Re: painting the hulls blue [Re: bvining] #150308
07/23/08 11:44 AM
07/23/08 11:44 AM
I still thought this was a very cool image.. (from an old post)
http://www.catsailor.com/forums/showflat...true#Post131260
Re: painting the hulls blue [Re: ] #150309
07/23/08 12:14 PM
07/23/08 12:14 PM
that boat had a 30 foot finish. It looked good 30 feet away or more. Any closer and you could see the wrinkles - that chrome vinyl does not flex at all.
Re: painting the hulls blue [Re: Jake] #150310
07/23/08 12:39 PM
07/23/08 12:39 PM
And is very expensive and will not last more than a year give or take six months.
Re: painting the hulls blue [Re: Robi] #150311
07/23/08 12:50 PM
07/23/08 12:50 PM
then it turns dull white.
Re: painting the hulls blue [Re: Jake] #150312
07/23/08 12:58 PM
07/23/08 12:58 PM
tampa, fl
K
ksurfer2 Offline
ksurfer2  Offline
K
tampa, fl
How would a laminate hull covering or paint affect one-design rules? Do rules for classes (N20 for example) dictate gel-coat, or can you refinish your hulls anyway you want?
Re: painting the hulls blue [Re: Robi] #150313
07/23/08 01:06 PM
07/23/08 01:06 PM
Don't you guys don't replace your hulls evey year??? <img src="http://www.catsailor.com/forums/images/graemlins/tongue.gif" alt="" />
Re: painting the hulls blue [Re: ] #150314
07/23/08 02:48 PM
07/23/08 02:48 PM
Aren't Tornados painted? Mabye get one of those. I'm sure they're cheap now that they're not "offical Olympic class" anymore...
And what of those Extreme 40 boats? Isn't Hillfiger black hull?
Re: painting the hulls blue [Re: ksurfer2] #150315
07/23/08 03:21 PM
07/23/08 03:21 PM
Clermont, FL, USA
David Ingram Offline
Clermont, FL, USA
The N20 rules do not specifcally say it has to be gel-coat but it does say:
2. PROTECTION NACRA CLASS DESIGNS
2. 1 THE HULLS. Daggerboards, rudders, stocks, standing rigging, spars and sails are strictly controlled except as specified in these rules.
Interpretations of these rules shall be given by Performance Sports International, Inc. (P.S. I., Inc.) in consultation with proper committees of the International Nacra Class Association (hereinafter referred to as INCA) . In the event of a conflict between rules, official plans, measurement form and/or measurement diagram, the matter shall be referred to INCA. (NOTE: To doubly guard against "loophole destruction" of these fine NACRA Class Catamarans and their potential for lasting racing pleasure, every deviation from past practice or precedent which is not specifically spelled out by plans, specifications or Design Rule is assumed illegal until
approved and thus recorded in writing by those dministering the Class Designing Rules.)
As long as the material added does not improve the preformance beyond what was original I'm sure there won't be an issue, but if it does... then there is probably going to be a problem.
F18 USA 242
http://www.solarwind.solar
0 registered members (), 337 guests, and 111 spiders.
Posts267,056
