fiberglass repair...again #150636
07/27/08 12:54 AM
07/27/08 12:54 AM
U
ucfsailor19 Offline OP
U
Hey guys,
Noticed on the Prindle 19 I have another area that needs some work. I took the port hull inspection cover off and just forward of the hole on top i can feel some damaged fiberglass. This area is formed into some sort of shape, i.e it is not just a flat area. I need to get in there with a flash light and a mirror to see it better. There are no holes or crack that go to the outside but i'd like to fix it before that happens. Would i be good just to sand it down some and put some large heavy cloth down? Suggestions welcomed.
Thanks,
Pete
Re: fiberglass repair...again [Re: ucfsailor19] #150637
07/27/08 11:46 AM
07/27/08 11:46 AM
Hey guys,
Thanks,
Pete
It's probably nothing and is likely just a sloppy finish job on an inside seam. Tip: put a digital camera inside the hull and take tons of pictures - they'll tell a pretty good story.
Re: fiberglass repair...again [Re: Jake] #150638
07/27/08 01:41 PM
07/27/08 01:41 PM
U
U
What boat is that a picture from, cause that kinda looks like what I was feeling how it has a shape to it and its not smooth up top. Well the only reason why I looked for broken glass was because I was standing in that area and I heard some cracking...
Re: fiberglass repair...again [Re: ucfsailor19] #150639
07/27/08 02:18 PM
07/27/08 02:18 PM
That's the inside of a Nacra 20 where the shroud chainplate is fixed to the inside of the hull and the spinnaker block attachment point is reinforced under the deck.
0 registered members (), 397 guests, and 40 spiders.
