| Main sheet systems #151347 08/04/08 05:38 AM 08/04/08 05:38 AM |
Joined: Nov 2007 Posts: 43 Gwandalan [ Lake Macquarie ] Karl69 OP
Posts: 43 Gwandalan [ Lake Macquarie ] | G,day all I’m thinking about changing my mainsheet system [currently using two triple blocks with a ratchet single block and cleat mounted under the triple block]. I’m interested to here what other systems are commonly used and why. The systems I am considering are 1. Two triple blocks with the bottom block having a cleat on it. 2. Two triple blocks with the main sheet running along the bottom of the boom and coming off a single ratchet block [without a cleat] mounted halfway down the boom. 3. The same as 2 but with a ratchet and cleat mounted to the centre beam under the tramp. I usually sail solo cat rigged and wanted to know if by mounting the main sheet forward it would be easier to use [instead of all the controls coming from the back of the boat]. I am interested to here what others think about using a cleat or cleatless system. <img src="http://www.catsailor.com/forums/images/graemlins/ooo.gif" alt="" /> <img src="http://www.catsailor.com/forums/images/graemlins/smile.gif" alt="" /> <img src="http://www.catsailor.com/forums/images/graemlins/confused.gif" alt="" />
Karl Herman Mosquito, 1704 Top Gun. NSW.
| | | Re: Main sheet systems
[Re: Karl69]
#151351 08/06/08 05:43 AM 08/06/08 05:43 AM |
Joined: Jan 2006 Posts: 556 Somers, Westernport Bay, Victo... Peter_Foulsum
Posts: 556 Somers, Westernport Bay, Victo... | Karl,
I use the 2 triple blocks with the bottom block cleat. The bottom centre block has an inbuilt ratchet. I find this to be clean and easy and can just take the whole system off for washing and storage and the end of the day. <img src="http://www.catsailor.com/forums/images/graemlins/cool.gif" alt="" />
I use the cleat when my arms need a short rest <img src="http://www.catsailor.com/forums/images/graemlins/wink.gif" alt="" /> so it is set a bit higher and I have to cleat it by raising my arm.
Peter
Mosquito 1814 Macka Mozzie
[Re: Karl69]
#151352 08/06/08 11:19 PM 08/06/08 11:19 PM |
Posts: 2,921 Michigan | one of the best things I ever did was change my cleating angle so I could cleat it EASIER. I sail a lot with it cleated. I still adjust it but it makes sailing so much easier and relaxing.
[Re: PTP]
#151353 08/07/08 03:03 AM 08/07/08 03:03 AM |
Joined: Aug 2007 Posts: 142 3 weeks Newman WA 1 week Robe ... Brian P
Posts: 142 3 weeks Newman WA 1 week Robe ... | i use the two triple blocks at end of boom, with the sheet running along the boom and a ratchet on the middle beam coming off the tramp. i find the forward sheeting makes it easier for trapping downwind i am more stable with one arm forward(sheet) and one arm back(tiller). if you are going without cleat, i reccomend two ratchets. turn both off for light day, one on for medium day and both on for big day. if you go a cleat, then only need one ratchet. after three races on two big days at SA states ( 20 knots +) i want the cleat back.
Brian Partridge STINGRAY 580 "Fantasia" A Class 585 "FHARKEN A"
YOU CAN'T POLISH A TURD BUT YOU CAN ROLL IT IN GLITTER!!!!!
11,148
guests, and 359
