Warts and all #151768
08/06/08 04:53 PM
08/06/08 04:53 PM
Central Coast NSW Australia
TonyJ Offline OP
TonyJ  Offline OP
Made a big boo boo.
In a hurry to get decks glassed, I took a short cut and didn't weigh the hardener and resin. I took a guess and got it wrong. It never went off, and now I have had to rip it all off.
Talk about 1 step forward and 2 steps back.
Now I have a gooey mess on the decks to clean up and start again.
Probabaly set my self back 2 weeks. Doh !
Teach them how to think. Not what to think. Aus Blade 002
Re: Warts and all [Re: TonyJ] #151769
08/06/08 08:27 PM
08/06/08 08:27 PM
Port Noarlunga, SA, Australia
Darryn Offline
Darryn  Offline
What sort of resin are you using?
Darryn
Re: Warts and all [Re: Darryn] #151770
08/06/08 09:55 PM
08/06/08 09:55 PM
I'm guessing SP
edit. Just to clarify this is not a comment on the resin, just Tony's stated preferance for other products. I only use and recommend SP (Gurit) composite materials.
Re: Warts and all [Re: ] #151771
08/06/08 11:58 PM
08/06/08 11:58 PM
Ouch Tony! That is a mess to clean up.
Re: Warts and all [Re: Rolf_Nilsen] #151772
08/07/08 12:59 AM
08/07/08 12:59 AM
TonyJ Offline OP
TonyJ  Offline OP
You would think working for the company I would know better.
Not to worry. It has cleaned up a easier than I thought.
Just mad at my self.
Re: Warts and all [Re: TonyJ] #151773
08/07/08 02:35 AM
08/07/08 02:35 AM
How did you clean it up. Ripped the glass off and?? How can you know you have got all the uncured resin/hardener away from the wood/bonding area?
Just trying to learn a bit from your mishap. <img src="http://www.catsailor.com/forums/images/graemlins/smile.gif" alt="" />
Re: Warts and all [Re: Rolf_Nilsen] #151774
08/07/08 02:58 AM
08/07/08 02:58 AM
Finland
valtteri Offline
valtteri  Offline
Finland
If it's still soft then it's easy, just pull the glass out and use good paint scraper (?) with rounded corners to avoid scratches and sand slightly before doing it properly again. Using too much hardener on the other hand may take lot more effort and it's not even easy to spot, so if mix ratio is not perfect it's better take it too soft <img src="http://www.catsailor.com/forums/images/graemlins/wink.gif" alt="" />.
Valtteri Blade F16
1 registered members (Damon Linkous), 2,526 guests, and 167 spiders.
