| Hobie Cat multi europeans #152433 08/11/08 04:18 AM 08/11/08 04:18 AM |
Joined: Jul 2001 Posts: 256 North Europe, Sweden, Uppsala Hakan Frojdh OP
Posts: 256 North Europe, Sweden, Uppsala | Hobie cat multi europeans in Denmark has just finished. The battle for the top places in the Hobie 16 gold fleet was tough but was finally won by Jerone Le Gal, Marco Lazetta (FRA). Second was Jens Goritz, Katrin Wiese-Dose (GER) and third was Jimmy Lefloch, Valentin Lefloch (FRA) 49 points. Link to multi europeans /hakan | | | Re: Hobie Cat multi europeans
[Re: Hakan Frojdh]
#152435 08/11/08 11:46 AM 08/11/08 11:46 AM |
Posts: 1,203 uk | Saw you on the entry list Hakan, meant to look you out to say Hi to a fellow poster.
I was on the GBR Rib for the finals, my youngest was out there with you [#50]
J.C. won the tigers
Any other Posters present?
[Re: brucat]
#152438 08/11/08 02:16 PM 08/11/08 02:16 PM |
Posts: 1,203 uk | the gates did get a bit hectic - only 6 boat lengths across!
The sail pattern makes it easy to see which teams were carrying a lot of mast rake in the varying conditions - the jib and main line up better with less rake. they did gaff with the jib numbers a bit cos' some were on the port side and some on the starboard side. not sure if this directly related to the chance of being OCS tho. The race team was pretty sharp
309
guests, and 40
