Anyone know Office 2000? #152687
08/14/08 02:27 PM
08/14/08 02:27 PM
Gang:
Can't get it to save documents to CD/DVD drive from Office 2000. Says I don't have rights to E:\ folder, contact administrator. I AM the administrator and only user on computer. Use to work before. I have tried reloading BOTH XP and Office a few times. I can write to drive fine from all other programns. Windows wants $50 just to talk. Can anyone help?
Doug
Re: Anyone know Office 2000? [Re: ] #152688
08/14/08 02:40 PM
08/14/08 02:40 PM
Albuquerque NM
Banzilla Offline
Banzilla  Offline
Albuquerque NM
have you tried saving the document to the My Documents folder and then copying it to the cd?
You might have to close word because the system thinks you have the file locked.
Are you sure the CD is good?
Sam
[b] Sail Like you have a Pair
Re: Anyone know Office 2000? [Re: Banzilla] #152689
08/14/08 03:18 PM
08/14/08 03:18 PM
I can get the files to the disk using My Computer or Total Commander, that is not the problem. Office is the problem, need it to work.
Doug
Re: Anyone know Office 2000? [Re: Banzilla] #152690
08/14/08 03:38 PM
08/14/08 03:38 PM
Atlanta, Ga
BLR_0719 Offline
BLR_0719  Offline
Atlanta, Ga
Its probably the disc, try a different one
Re: Anyone know Office 2000? [Re: BLR_0719] #152691
08/14/08 03:44 PM
08/14/08 03:44 PM
Atlanta, Ga
BLR_0719 Offline
BLR_0719  Offline
Atlanta, Ga
never mind.. but would still try using another disc just to see
Re: Anyone know Office 2000? [Re: ] #152692
08/14/08 03:49 PM
08/14/08 03:49 PM
Clermont, FL, USA
David Ingram Offline
Clermont, FL, USA
Google is your best friend. If you can't find it using Google it can't be done. Well, that's not totally true but it's pretty close.
You could also try posting the question on TechNet (Microsoft's support forum), you might want to do a search before asking though. Techy types get a bit uppity when you don't RTFM or do an internet search first. Some of them can be real a$$holes.
F18 USA 242
http://www.solarwind.solar
Re: Anyone know Office 2000? [Re: BLR_0719] #152693
08/14/08 03:50 PM
08/14/08 03:50 PM
Why do you need Office to save directly to the DVD drive?
If copying files to the drive triggers the burning function in software and hardware it sounds like everything is as it should be. Are you certain Office2000 CAN save directly to the DVD drive? It might be that your hardware needs a special driver which dont permit that kind of functionality.
I never tried and never needed the kind of functionality you describe so I dont know for sure.
Re: Anyone know Office 2000? [Re: Rolf_Nilsen] #152694
08/15/08 06:49 PM
08/15/08 06:49 PM
Cincinnati, Ohio
Tri_X_Troll Offline
Tri_X_Troll  Offline
Cincinnati, Ohio
Is the original file on a network resource? If so, it's possible that windoz thinks another user (yourself) has the file open and won't let you save it....
This can happen if you've changed a password recently and haven't logged out and back in since the password change.
Re: Anyone know Office 2000? [Re: Tri_X_Troll] #152695
08/15/08 09:05 PM
08/15/08 09:05 PM
Saved on my hard drive. Use to work before I had to reformat drive. Nothing different than before and I have reloaded both program to see if that was it after totally remove Office
Re: Anyone know Office 2000? [Re: ] #152696
08/16/08 04:42 AM
08/16/08 04:42 AM
rexdenton Offline
rexdenton  Offline
Sounds like a ROM driver bug. Try looking for a driver update for your CD/DVD ROM.
Nacra F18 #856
0 registered members (), 309 guests, and 40 spiders.
