| Anyone know Office 2000? #152687 08/14/08 02:27 PM 08/14/08 02:27 PM | Anonymous
| Anonymous
Unregistered | Gang:
Can't get it to save documents to CD/DVD drive from Office 2000. Says I don't have rights to E:\ folder, contact administrator. I AM the administrator and only user on computer. Use to work before. I have tried reloading BOTH XP and Office a few times. I can write to drive fine from all other programns. Windows wants $50 just to talk. Can anyone help?
Doug | | | Re: Anyone know Office 2000?
[Re: ]
#152688 08/14/08 02:40 PM 08/14/08 02:40 PM |
Posts: 321 Albuquerque NM | have you tried saving the document to the My Documents folder and then copying it to the cd?
You might have to close word because the system thinks you have the file locked.
Are you sure the CD is good?
Sam
[b] Sail Like you have a Pair
[Re: Banzilla]
#152689 08/14/08 03:18 PM 08/14/08 03:18 PM | Anonymous
| Anonymous
Unregistered | I can get the files to the disk using My Computer or Total Commander, that is not the problem. Office is the problem, need it to work.
[Re: BLR_0719]
#152691 08/14/08 03:44 PM 08/14/08 03:44 PM |
Posts: 271 Atlanta, Ga | never mind.. but would still try using another disc just to see | | | Re: Anyone know Office 2000?
[Re: ]
#152692 08/14/08 03:49 PM 08/14/08 03:49 PM |
Posts: 3,906 Clermont, FL, USA | Google is your best friend. If you can't find it using Google it can't be done. Well, that's not totally true but it's pretty close.
You could also try posting the question on TechNet (Microsoft's support forum), you might want to do a search before asking though. Techy types get a bit uppity when you don't RTFM or do an internet search first. Some of them can be real a$$holes.
[Re: Rolf_Nilsen]
#152694 08/15/08 06:49 PM 08/15/08 06:49 PM |
Joined: Sep 2007 Posts: 224 Cincinnati, Ohio Tri_X_Troll
Posts: 224 Cincinnati, Ohio | Is the original file on a network resource? If so, it's possible that windoz thinks another user (yourself) has the file open and won't let you save it....
This can happen if you've changed a password recently and haven't logged out and back in since the password change.
Ryan - H16
I prefer to go sailing because baseball, football, tennis, and golf only require 1 ball!
[Re: Tri_X_Troll]
#152695 08/15/08 09:05 PM 08/15/08 09:05 PM | Anonymous
| Anonymous
Unregistered | Saved on my hard drive. Use to work before I had to reformat drive. Nothing different than before and I have reloaded both program to see if that was it after totally remove Office | | | Re: Anyone know Office 2000?
[Re: ]
#152696 08/16/08 04:42 AM 08/16/08 04:42 AM |
Posts: 297 | Sounds like a ROM driver bug. Try looking for a driver update for your CD/DVD ROM.
Nacra F18 #856
506
guests, and 108
Mod | | Forums26 Topics22,405 Posts267,056 Members8,150 | Most Online2,167 Dec 19th, 2022 | | | |
