Dyneema jib halyard #152730
08/14/08 11:57 PM
08/14/08 11:57 PM
Hobart, Tasmania, Oz.
Dazz Offline OP
Dazz  Offline OP
Hi everyone
Im about to replace the jib halyard on the capricorn, I would like to use dyneema but i am concerned about the stretch as my halyard is not adjustable on water.
are there many peeps using dyneema over wire now?
C2 AUS 222 by Goodall design
"Darph Bobo"
Re: Dyneema jib halyard [Re: Dazz] #152731
08/18/08 09:15 AM
08/18/08 09:15 AM
mikekrantz Offline
mikekrantz  Offline
Use vectran if you are concerned about creep.
Re: Dyneema jib halyard [Re: Dazz] #152732
08/23/08 01:41 PM
08/23/08 01:41 PM
uk
TEAMVMG Offline
TEAMVMG  Offline
uk
Don't do it unless you can rig an easy on the water tensioner
Re: Dyneema jib halyard [Re: TEAMVMG] #152733
08/23/08 11:13 PM
08/23/08 11:13 PM
WA, ID, MT
davefarmer Offline
davefarmer  Offline
WA, ID, MT
I'm happy using Vectran.
dave
Re: Dyneema jib halyard [Re: davefarmer] #152734
08/24/08 07:32 PM
08/24/08 07:32 PM
Dazz,
the last owner of your boat was a know nothing layabout. Whatever you do change all his systems and rope selections etc.
Re: Dyneema jib halyard [Re: ] #152735
08/27/08 02:37 AM
08/27/08 02:37 AM
Dazz Offline OP
Dazz  Offline OP
Thanks Scarecrow, I'm sure TA will be pleased to hear that :P
There are some realy good setups on this boat that I havnt seen anywhere else.
I have made some changes, done a bucket load of maintenace (all standing rigging, diamonds, all shock cord, new sheets..) mostly so the boat is easier to deal with on a week to week basis.
The forestay is being replaced today, the furler is coming out as the jib doesnt furl anyway. The choice between a rope or wire jib halyard determins the type of pulley that will be swaged onto the forestay.
Im sticking with wire.
"Darph Bobo"
Re: Dyneema jib halyard [Re: Dazz] #279572
06/23/15 02:55 AM
06/23/15 02:55 AM
Juha Offline
Juha  Offline
Hi there,
I would like to replace the jib halyard on my Nacra Infusion mk II. What line are recommending for the halyard? Should I use Dacron or some other material, such as Vectran?
Here's the Nacra's manual how to replace the halyard -> http://goo.gl/ohNDxi .
Thanks in advance.
Re: Dyneema jib halyard [Re: Dazz] #279593
06/24/15 07:06 PM
06/24/15 07:06 PM
Dazz Offline OP
Dazz  Offline OP
What a fortune teller you turned out to be Scarecrow. by the time I had finished it was virtually identical in setup to the C2, so when i made the move to a new boat, everything was the just the same but faster/easier to sail.
Juha, any old piece of string will do for a nacra halyard. If you have the stock hook/ring arrangement then there is no load on the halyard at all.
"Darph Bobo"
Re: Dyneema jib halyard [Re: Dazz] #279658
06/28/15 03:11 PM
06/28/15 03:11 PM
Knokke-Heist - Belgium
Gilo Offline
Gilo  Offline
Vectran has a very bad UV resistance. I don't think the line will last longer than 3 years. My preference would be dyneema.
Setting up an adjustable jib halyard is quite easy and definately worth the investment if you are racing.
Falcon F16 - BEL666
Boats: TheBoatShop.be
0 registered members (), 799 guests, and 916 spiders.
