Dock Plan /Materials? #153509
08/27/08 10:40 PM
08/27/08 10:40 PM
Westport, Ma. U.S.A.
Brian_Mc Offline OP
Brian_Mc  Offline OP
I know this isn't Cat related, but am hoping someone can steer me towards some resources. I'm planning to put a dock deck across some boulders to the water, using anchor bolts into the stone. These will hold 4x4s which I can then build onto. At the end, I want to put a ramp attached to the stone with removable pins/bolts, going down to a float. I'm thinking put some eyebolts in the stone on either side of the dock, and having mooring anchors further out in the water. Where can I find the: eyebolts (preferably with rings);anchors for said bolts; epoxy to seal bolts in stone. Any help apreciated. Thanks, Brian
Re: Dock Plan /Materials? [Re: Brian_Mc] #153510
08/28/08 06:45 AM
08/28/08 06:45 AM
Kingston SE South Australia
JeffS Offline
JeffS  Offline
G'day Brian I've never built a dock but when I assembled a steel frame house on concrete we just laid the slab and drilled holes to suit specialised concrete bolts that just screwed into the concrete using a rattle gun. You could use the same bolts or if you dont want to remove the bolts Dyna bolts will hold anything.
regards
Jeff Southall
Current boats
Nacra 5.8 1667 Ram Raider
Nacra 18 Square
Arrow 1576
0 registered members (), 740 guests, and 22 spiders.
