| Re: New to me 81 H16 Setup advice
[Re: mmiller]
#153615 09/15/08 06:33 PM 09/15/08 06:33 PM |
Posts: 117 Atlanta, GA | One thing that seems to work for me is to use a phillips head screw driver instead of the pin. It's a lot easier to grab and pull with, in addition to supporting the mast like Matt says. It also is a better reminder to pull the pin before you start raising the sails.
Kent 1988 H16
[Re: KentHobie]
#153616 09/15/08 08:21 PM 09/15/08 08:21 PM |
Joined: Sep 2007 Posts: 224 Cincinnati, Ohio Tri_X_Troll
Posts: 224 Cincinnati, Ohio | Yeah, the shrouds are going to be loose until you pull the jib up. Then the wire in the jib will act as the forestay and the shrouds will be pulled tight.
Also the leeward shroud will always be slack while sailing.
Ryan - H16
I prefer to go sailing because baseball, football, tennis, and golf only require 1 ball!
[Re: pauledude]
#153619 09/22/08 01:02 PM 09/22/08 01:02 PM |
Joined: Jul 2004 Posts: 125 Clinton, Mississippi rattlenhum
Posts: 125 Clinton, Mississippi | I bought the heavy duty Murrays hinge years ago and found it difficult to use with even moderate (aft) mast rake. I have a newer boat/sails now and run hard (aft) rake for heavy air. Rigged this way, even the old Hobie hinges didn't work well for me....I'd have to rake back after steppping the mast and rake forward before lowering it. And yes, we were pushing/pulling the mast as far forward as possible. I had several old hinges, so I ground off the forward top corners (where yours is hitting the bottom of the mast base) for a test. It works great, and I'm still using it. The Phillips head screwdriver (size No. 2, I think) trick mentioned above makes things much easier, too.
Jerome Vaughan Hobie 16 Clinton, Mississippi
4,024
guests, and 659
