| Re: Teflon Chip / Mast Step problem
[Re: Tri_X_Troll]
#153726 09/01/08 10:32 AM 09/01/08 10:32 AM |
Posts: 1,252 California | From the 2005 Hobie parts catalog... Hobie Cat has also reworked the mast base and step castings to improve the rotation stop function and durability. We have also added a feature we call the “Chip Keeper” in the mast step castings. This is an array of small holes around the inside of the cup. As the mast chip is pressed down by the base, the chip is forced into these small indents, virtually locking the chip in place. This is fantastic! It keeps your chip in place. No more chips squirting out of place while sailing. We also made the rotation stops taller and wider. These new castings were tested extensivly through demanding conditions of the 2004 Hobie 16 Worlds. They worked great! Standard on the H16 mast step. Works great. | | | Re: Teflon Chip / Mast Step problem
[Re: QuinnLong]
#153727 09/02/08 01:18 PM 09/02/08 01:18 PM |
Posts: 1,187 38.912, -95.37 | On my previous boats I would use the same chip for months and it always took to the shape of the mast base and stayed wedged securely and centered in place. With this boat, The chips slide off center and get shredded up with each sail. Any suggestions? Thank you. Pretty sure I drilled the base, as Matt suggested, on your last boat, but I may be wrong. Regardless, I've tried to do it on every boat since. I've been wanting to try one of those #1130 teflon chips. Matt, are the new boats fitted with these?
[Re: _flatlander_]
#153728 09/02/08 07:49 PM 09/02/08 07:49 PM |
Posts: 1,252 California | I've been wanting to try one of those #1130 teflon chips. Matt, are the new boats fitted with these? The #1130 Molded bearing is not teflon as far as I know. Some kind of injected plastic. Personally... I don't like them. Too hard and thick. The "Chip Keeper" idea does the trick that the 1130 was intended to do other than being per-molded to a cup shape. | | | Re: Teflon Chip / Mast Step problem
[Re: QuinnLong]
#153731 09/04/08 10:06 AM 09/04/08 10:06 AM |
Posts: 242 Brisveagas | Quinn,
We use the plastic lids of a coke bottle for mast chips. IMO they work better than the teflon ones. The reason being that they wrap around the end of the mast base and then cant really go anywhere until you take the mast down. You have to crank on the jib halyard hard when you put in a new one to squash it to the right shape.
Aido Viper 288
[Re: mmiller]
#153733 09/19/08 08:32 AM 09/19/08 08:32 AM | Anonymous
| Anonymous
Unregistered | Can someone post a picture of the holes drilled into the mast base as a "Chip Keeper" Thanks, CP | | | Re: Teflon Chip / Mast Step problem
[Re: ]
#153734 09/23/08 06:24 AM 09/23/08 06:24 AM |
Posts: 242 Brisveagas | Oi Quinn,
Have you given the coke bottle lid a try? Its definitely the way forward.
Aido Viper 288
16,438
guests, and 846
