| Re: F16 Main sails
[Re: pepin]
#153795 09/04/08 02:47 PM 09/04/08 02:47 PM |
Joined: May 2006 Posts: 954 Mumbles Y.C Wales U.K Mark P
Posts: 954 Mumbles Y.C Wales U.K | Hi Pepin When I was sailing an R and bought a new Landy F16 mainsail I had to move the boom/goose neck below the mast rotator bracket but it worked out really well. I had to also adjust the outhaul system to the max length of the boom, that boom was a rectangular shape. If you're looking to change mains and need photo's info on what I did please don't hesitate to contact me. MP*MULTIHULLS | | | Re: F16 Main sails
[Re: davidtugwell]
#153796 09/04/08 03:05 PM 09/04/08 03:05 PM |
Joined: Jun 2001 Posts: 890 Dunedin Causeway, FL David Parker
Posts: 890 Dunedin Causeway, FL | So what's the point of the sail below the downhaul? wgy not use that sail area somewhere useful? Isn't that section acting as a boom vang? As you release main sheet the boom wants to rise. The lug in the lower sail section is in the sail track and that sail panel pulls tight, stopping boom lift. Vangs are something cats never seem to have. Just a guess... | | | Re: F16 Main sails
[Re: David Parker]
#153797 09/04/08 03:23 PM 09/04/08 03:23 PM |
Posts: 976 France | Vangs are something cats never seem to have. As it was explained to me recently, cats do not have vangs because it would impair mast rotation. With a vang you lock the mast and the boom together and the mast can't rotate freely anymore. Monohulls with vang do not have rotating masts. So if your mast rotate: traveler. If it does not, you get a more convenient (IMHO) vang. | | | Re: F16 Main sails
[Re: pepin]
#153798 09/04/08 03:31 PM 09/04/08 03:31 PM |
Joined: Mar 2008 Posts: 201 Adelaide, South Australia simonp
Posts: 201 Adelaide, South Australia | My Arrow had a Vang and the mast rotated fine. The Arrow has a fairly low aspect rig compared to modern cats though. I think it would be scary how much tension you would need on the vang to get decent leech tension on the big head mains. Can you imagine the boom you would need to handle that sort of load?
Simon BLADE F16 AUS405
| | | Re: F16 Main sails
[Re: David Parker]
#153799 09/04/08 03:34 PM 09/04/08 03:34 PM |
Posts: 201 Adelaide, South Australia | The lug in the lower sail section is in the sail track and that sail panel pulls tight, stopping boom lift. That lug would never hold the tension required to keep the boom done.
| | | Re: F16 Main sails
[Re: simonp]
#153804 09/04/08 08:56 PM 09/04/08 08:56 PM |
Joined: May 2008 Posts: 107 Melbourne, Australia MitchB
Posts: 107 Melbourne, Australia | I crewed on a skiff a few times over winter... It had about a 24:1 ratio on the vang, and he would wrap it around his hand and CRANK it. This caused a lot of mast bend... but more amazingly it cause the boom which must have been about 80mm diameter to bend! And his rig was substantially smaller than a cat rig!
Stingray #579 GLYCish
| | | Re: F16 Main sails
[Re: simonp]
#153805 09/04/08 11:34 PM 09/04/08 11:34 PM | Anonymous
| Anonymous
Unregistered | I wonder why the Goodall F16 sail for the Viper is different then the Blade/Taipan on the same mast?
me too I can't speak for AHPC, but Greg told me that he would build the Viper main different to the Taipan because. The spreaders are different, the mast is longer,the boom is shorter, also the loads are higher because of extra width and weight. The spreader difference and weight apply to the Blade Vs Viper also. Although I would expect the Blade and Viper main to be closer in design than the Taipan. In reality though, you will easily get more variation from different manafacturers making sails for the same boat from my experience. <img src="http://www.catsailor.com/forums/images/graemlins/tongue.gif" alt="" /> I don't think sailmaking is the exact science we all wish it was. <img src="http://www.catsailor.com/forums/images/graemlins/wink.gif" alt="" /> | | | Re: F16 Main sails
[Re: ]
#153806 09/05/08 02:11 AM 09/05/08 02:11 AM |
Posts: 1,382 Essex, UK | Pepin, are you planning to acquire new beams from John P?
Of course, you'd need a new tramp as well or at least insert a widening strip down the centre of your existing tramp. However, you'd then (with a new main) have a fully optimised Stealth F16 and have increased the value of your boat? Psychologically too, you'd feel that you were on the pace.....
It's just what I would do in your position if I was planning on new sails, go the whole hog!
John Alani ___________ Stealth F16s GBR527 and GBR538 | | | Re: F16 Main sails
[Re: Jalani]
#153807 09/05/08 03:35 AM 09/05/08 03:35 AM |
Posts: 976 France | Pepin, are you planning to acquire new beams from John P? Definitely not. The 0.02% gain in performance I will get by widening the boat by 8inches will not compensate for my poor sailing skills. I'd say I should improve the man first, the material second.
| | | Re: F16 Main sails
[Re: pepin]
#153808 09/05/08 03:58 AM 09/05/08 03:58 AM |
Posts: 954 Mumbles Y.C Wales U.K | A F16 main on a type R platform was great at going upwind, don't ask me why but I'm sure it points higher. We have had quite a few beer discussions at the bar over this but no one has come up with a clear answer as to how a slightly narrower platform (200mm-8inches) could point higher but it does. Also, in the lighter stuff you can get the windward hull out quicker both up and downwind and the platform could be stiffer. So all in all there's extremely little overall speed difference between the two. Like Pepin admits it's the nut on the end of the tiller that wins, loses races in most cases. MP*MULTIHULLS | | | Re: F16 Main sails
[Re: Mark P]
#153809 09/05/08 04:36 AM 09/05/08 04:36 AM |
Posts: 1,382 Essex, UK | Ahhhhhh! - NOW I understand!! - It's not the 8 inches themselves but how you use those 8 inches? <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
[Re: pepin]
#153810 09/05/08 05:46 AM 09/05/08 05:46 AM |
Posts: 1,669 Melbourne, Australia | Vangs are something cats never seem to have FYI, many non apparent cats have vangs. When going downwind square with the traveller and main sail all the way out, it is important to keep the boom low to present max sail area to the wind. My old Dolphin had a wing mast like a super wing and never experienced any promlems with rotation. Also had a vang on my old Mari 4.3. Paper Tigers, Mosquitoes, Arafuras and Quickcats I have also sailed had vangs. | | | Re: F16 Main sails
[Re: Tornado_ALIVE]
#153811 09/05/08 05:58 AM 09/05/08 05:58 AM |
Joined: Jun 2004 Posts: 502 Port Noarlunga, SA, Australia Darryn
Posts: 502 Port Noarlunga, SA, Australia | Vangs are something cats never seem to have FYI, many non apparent cats have vangs. When going downwind square with the traveller and main sail all the way out, it is important to keep the boom low to present max sail area to the wind. My old Dolphin had a wing mast like a super wing and never experienced any promlems with rotation. Also had a vang on my old Mari 4.3. Paper Tigers, Mosquitoes, Arafuras and Quickcats I have also sailed had vangs. I use the vang upwind also in the light stuff, vang sheeting like a Laser. While some Mozzies run square downwind I find it quicker to gybe downwind, using apparent wind, the vang helps over rotate the mast. If the Viper rig has more grunt then...? Perhaps I miss the point. Darryn | | |
2,748
guests, and 589
