| Rule clarification, grandfathered boats. #154120 09/05/08 01:14 PM 09/05/08 01:14 PM |
Posts: 976 France | Let me open the can of worms. My boat is a Stealth 'R'. It is not compliant with the box rules because it predates it (for example the hull length is 5.03m, 3cms longer than 5 meters). However this boat has been grandfathered as is into the F16 class, so I can sail it as a F16 with its original set of non compliant sails (sail area is similar, but the distribution is different as the jib is larger than allowed by the box rules): 5.1.2 The Foundation boats Taipan 4.9 (with F16 spi) and Stealth (R) have the special status of "Formula 16 foundation boats"; meaning that, despite the fact that they are dispensated for their non compliance, they have become part of the (closed) Formula 16 class. Their status is permanent; althought it is lost when the boat in question is no longer compliant with their confirmed (class) setup as fixed on the date 1 januari 2002.
Now, if I put a larger main (compliant with the box rule, but no longer compliant with the original class setup) the letter of the rule says this boat is a F16 no longer! This seem a little harsh as I plan to sail solo and losing 1.5m of sail area can't be good. However pushing the limit and sailing duo with a big main *and* the non-compliant jib would be cheating for sure. So I'd like clarification from the class authority. Ideally if the rule could be amended with something like: 5.1.2 [...]Changing the sails from the original class setup is authorized as long as the full set of sails is compliant with the box rules.
As far as I understand there is quite a lot of these boats around sailed with a 'big' main, and some even won previous competitions, so it should not be an issue right? | | | Re: Rule clarification, grandfathered boats.
[Re: pepin]
#154122 09/05/08 06:20 PM 09/05/08 06:20 PM |
Joined: May 2006 Posts: 954 Mumbles Y.C Wales U.K Mark P
Posts: 954 Mumbles Y.C Wales U.K | From a personal point of view if you enter an event single handed with a F16 main that's fine, If you enter an event two up with original jib and main that is also fine. However, as you've probably guessed you can't have the cake and eat it.... <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" /> MP*MULTIHULLS | | | Re: Rule clarification, grandfathered boats.
[Re: Mark P]
#154123 09/05/08 08:30 PM 09/05/08 08:30 PM |
Posts: 976 France | From a personal point of view if you enter an event single handed with a F16 main that's fine. Yup I figure that is the general view, converting the sail plan to be F16 box rule compliant is something that people have done before and it seems to be fair, reasonable and de facto accepted by everybody. However, the rules says what the rule says, if I change the sail plan I'm no longer sailing a rule abiding boat. Hence my request for an official blessing. I'd like the possibility to switch my sail plan to a F16 one, so I can stay somewhat competitive with the more recent boats, without having to use a hacksaw to remove 3 centimeters out of my bow <img src="http://www.catsailor.com/forums/images/graemlins/shocked.gif" alt="" /> BTW, I've calculated the SCHRS rating of the Stealth 'R' solo configuration and it ends up at 1.03 with the small main and .995 with a F16 main. Quite a difference.
[Re: pepin]
#154127 09/06/08 05:09 AM 09/06/08 05:09 AM |
Posts: 465 Oxford, UK | Whilst I find the idea of someone in the UK protesting a Stealth R + F16 main unimaginable, I think the rules are clear: a Stealth R with an F16 main does not meet the requirements for a foundation boat, and therefore does not meet the requirements for the Formula 16 class.
However, it is within the constraints of the "Open Formula 16" class, which means that "the head of a local Formula 16 class organisation may give dispensation" to allow it to become part of the Open Formula 16 class. Now, I would have thought that it should require the local F16 association to give the dispensation, rather than just the head, but it doesn't, and I guess I'm the head, so: dispensation given (this gets reviewed yearly).
On this basis, I'm firmly of the opinion that we should run UK F16 events on the basis of the Open rules. I thought there was a rule that the Global Challenge needed to be run according to Formula 16 rather than Open Formula 16, but I can't find it so I think it's down to the organiser.
If you're really concerned, you could make a proposal to modify the rules to specifically allow a Stealth R + F16 main sailed 1-up to be considered a "foundation" boat. In my opinion is a perfectly reasonable suggestion: it allows the Stealth R platform to continue to feed the class.
Have you actually measured the boat? My understanding was that the very first Stealth F16 came out of the same mould, and I wasn't actually aware that the length changed when the new shape came out. A tape measure might reveal that this is all a non-issue.
[Re: pdwarren]
#154128 09/06/08 11:20 AM 09/06/08 11:20 AM |
Posts: 3,528 Looking for a Job, I got credi... | Pepin,
Bring the boat to Grafham for the open and I will FORMALLY measure the length of the boat (it will not take very long).
Paul will also (barring disasters) be at Grafham and so we can discuss the issue (if there is one) at that time.
F16 - GBR 553 - SOLD I also talk sport here | | | Re: Rule clarification, grandfathered boats.
[Re: Tornado_ALIVE]
#154129 09/06/08 07:32 PM 09/06/08 07:32 PM |
Joined: Jun 2004 Posts: 502 Port Noarlunga, SA, Australia Darryn
Posts: 502 Port Noarlunga, SA, Australia | I see it as leaving yourself very open to protest under the rules I see above. Like a Mossie putting a bigger square top main on, or a superwing mast despite weighing consierabl less than class rules. If I was going to optimise my Mozzie platform for F16 I would add the lead, unfortunately the amount of lead I would have to add is about double the amount allowed under the F16 rules so it isn't viable for me because I would end up with an illegal boat anyway. FAQ is a good idea. Darryn Mozzie 1782 | | | Re: Rule clarification, grandfathered boats.
[Re: Rolf_Nilsen]
#154131 09/07/08 05:32 AM 09/07/08 05:32 AM |
Posts: 9,582 North-West Europe | Come on Wouter, what was the thinking back then?
To prevent cheating using the grandfather rule. The grandfather rule is there to allow an easy access to F16 sailing / events using very similar but non-compliant boats. In smaller (local) events it was envisioned that this allowance would be applied very leniently = open F16 class. However, at important events like the Global Challenge the rules would be applied more stricktly = (closed) F16 class. As an onwer of a non compliant boat you take a small risk; the head of the local organisation or the board of a local class association may not renew your dispensatie next year. But apart from that you are pretty save. Once dispensation is given, it will be valid for the remainder of the season except at very important F16 events (2 a year ?) Personally, I wouldn't worry about 3 cm additional hull length. I don't think any F16 sailor would protest you for it at any event short of the GC. And even then the local class organisation may choose to protect you by issueing a dispensation when you are less performant overall due to other reasons like being overweight, having less sailarea etc. Wouter
[Re: pepin]
#154132 09/07/08 09:43 AM 09/07/08 09:43 AM |
Posts: 893 | My boat is a Stealth 'R'. It is not compliant with the box rules because it predates it (for example the hull length is 5.03m, 3cms longer than 5 meters). However this boat has been grandfathered as is into the F16 class, so I can sail it as a F16 with its original set of non compliant sails (sail area is similar, but the distribution is different as the jib is larger than allowed by the box rules):
Pepin, I'm not sure how the French measure their boats <img src="http://www.catsailor.com/forums/images/graemlins/smile.gif" alt="" /> <img src="http://www.catsailor.com/forums/images/graemlins/smirk.gif" alt="" />but having measured your boat this afternoon and double checked it, Nick and I reckon its 5.003 metres long, ie 3mm over length and not 3 cm's. We measured both Nicks and mine as well and they all are about 2 - 4 mm over the 5.00m mark. We also measured a latest version of the Stealth and its about 5mm under length ie 4.995 metre. I have a possible theory on why you came to be 3cms over length, did you use the Dinghy Stores tape measure, it has an imperial measure on one side and a metric on the other, the imperial starts at Zero, the metric starts at 30mm, I'm not sure why but it does and I have seen this on similar tapes before. We just started from 1.00 metre to make absolutely sure. So by my reckoning you can use a F16 sail and be totally compliant to fit within the rules,If your boat was one of the very early boats and not made by Stealth Marine, you may want to check the weight as they are right on the weight, perhaps even a kilo or two under. <img src="http://www.catsailor.com/forums/images/graemlins/smirk.gif" alt="" /> <img src="http://www.catsailor.com/forums/images/graemlins/smirk.gif" alt="" /> From my understanding the earlier masts were slightly softer than the later masts, you may perhaps want to consider moving the diamonds slightly foward to compensate. Hey you got a lot of boat for your money, I reckon you will be up to speed pretty quick as you used to get your old Nacra shifting pretty well. <img src="http://www.catsailor.com/forums/images/graemlins/cool.gif" alt="" /> | | | Re: Rule clarification, grandfathered boats.
[Re: waynemarlow]
#154134 09/07/08 01:46 PM 09/07/08 01:46 PM |
In my opinion (=same as I was the class chairman) is that 5.003 mtr is rounded off to 5.00 mtr as the rules allow and therefor your boat is F16 compliant with respect to hull length. It is the reason why the class rule specify 5.00 mtr and not 5.000 mtr ! Lets call it a building margin
[Re: pepin]
#154136 09/07/08 02:54 PM 09/07/08 02:54 PM |
Posts: 3,528 Looking for a Job, I got credi... | BTW Wayne, I left before the end of the first race this morning cause I had to go home early, but you all raced the wrong course. You started with a sausage followed by a triangle and the SI call for triangle first...
You mean you do not sail W/L ?
[Re: scooby_simon]
#154137 09/07/08 03:21 PM 09/07/08 03:21 PM |
Posts: 976 France | BTW Wayne, I left before the end of the first race this morning cause I had to go home early, but you all raced the wrong course. You started with a sausage followed by a triangle and the SI call for triangle first...
You mean you do not sail W/L ? Sailing instruction for club racing at DWSC on Sunday morning calls for triangle/sausage, twice. Don't ask me why. | | | Re: Rule clarification, grandfathered boats.
[Re: pepin]
#154138 09/07/08 03:30 PM 09/07/08 03:30 PM |
Posts: 1,382 Essex, UK | But we know why - the first word begins with 'F' and the second word is 'Fifteens' <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
John Alani ___________ Stealth F16s GBR527 and GBR538 | | |
2,546
guests, and 300
