F18 Infusion Rig on a Nacra 5.5? Thoughts... #154416
09/08/08 05:35 PM
09/08/08 05:35 PM
M
Mappy Offline OP
Mappy  Offline OP
M
I purchased an Infusion this year and kept my 2000 Nacra 5.5. I would like to use the Infusion mast, Main Sail, boom, spinnaker, spin gear on the 5.5. Any reason why this would be a bad idea? I normally sail the 5.5 with a spinnaker solo but I like the idea of the F18 lighter wing mast. I set it up this weekend in the yard and it looks like it will only require minor tweaking to make it work.
Re: F18 Infusion Rig on a Nacra 5.5? Thoughts... [Re: Mappy] #154417
09/08/08 05:47 PM
09/08/08 05:47 PM
Lake Murray SC
FasterDamnit Offline
Lake Murray SC
Go for it!
If it is straight forward, why not? You may have a bit more nose dive compared to the Infusion hulls.
Just curious- Is there any ting wrong w/ the I F18?
E-Scow
24' ULDB
Re: F18 Infusion Rig on a Nacra 5.5? Thoughts... [Re: FasterDamnit] #154418
09/08/08 06:08 PM
09/08/08 06:08 PM
rictorn Offline
rictorn  Offline
thats cool go for it, it will be a bit quicker is it 170 kg or 150 kg? the f18 is too heavy at 180kg so you may have a flying machine, i put a tornado rig on unicorn hulls with wide beams it was as fast as an about 110 kg all up and as a 11 foot wide single hander it was faster than a formula 18 when they were flying a spinaker and i was just on 2 sails
Re: F18 Infusion Rig on a Nacra 5.5? Thoughts... [Re: Mappy] #154419
09/08/08 06:35 PM
09/08/08 06:35 PM
Is the Infusion too boring or something?
Re: F18 Infusion Rig on a Nacra 5.5? Thoughts... [Re: Jake] #154420
09/09/08 09:30 AM
09/09/08 09:30 AM
too heavy he thinks...
Re: F18 Infusion Rig on a Nacra 5.5? Thoughts... [Re: Mappy] #154421
09/09/08 10:48 AM
09/09/08 10:48 AM
Toronto, Ontario
pitchpoledave Offline
Toronto, Ontario
Why not just get an F17? If you took the rig off the Infusion then how are you going to sail it?
Re: F18 Infusion Rig on a Nacra 5.5? Thoughts... [Re: pitchpoledave] #154422
09/09/08 11:22 AM
09/09/08 11:22 AM
If he wants a lighter mast then go for the F16 alu mast with F16 rig. Lightest alu rig available on the market today !
Re: F18 Infusion Rig on a Nacra 5.5? Thoughts... [Re: waterbug_wpb] #154423
09/09/08 11:29 AM
09/09/08 11:29 AM
The 5.5 is lighter than the Infusion? I'm thinking that they are very close to the same weight.
0 registered members (), 12,481 guests, and 695 spiders.
Most Online11,466
3 seconds ago
