| Re: portsmouth calculations
[Re: waterbug_wpb]
#154772 09/11/08 03:20 PM 09/11/08 03:20 PM |
Posts: 3,969 | Mark,
I'm not avoiding anything, and I agree with some of what you're saying, but I really don't understand why you're attacking me (or maybe I'm reading too much into it?).
Nothing that I've written is untrue.
My points about who is responsible for what are in the rules.
As several others have pointed out here, we will never be able to make everyone truly happy with any handicap system (hey, there's no way to make everyone happy about anything, so why should that be different?). As long as people aren't happy, they complain.
One design makes the issue of handicaps go away. Is it perfect? No, but it avoids these specific discussions.
The only reason I replied to this thread to begin with is because there seemed to be confusion about the PRO having responsibility to determine a handicap number. As I see it (per the RRS), it is the responsibility of the sailor. If the boat is entered incorrectly, the event measurer files a report to the RC, who in turn files a protest and the jury ultimately decides the issue.
I guess the real lesson here is that OAs should not take this stuff lightly, and should make sure they have someone at the regatta to serve as the measurer (can be a competitor) who knows the ratings systems inside and out. Your point about having a local board agree on the number falls in line with this approach.
Mike | | | Re: portsmouth calculations
[Re: waterbug_wpb]
#154773 09/11/08 03:20 PM 09/11/08 03:20 PM |
Posts: 3,116 Annapolis, MD | First a flying foil boat has to race in a buoys' race... Then talk about the need to use windspeed adjustment ratings....
crac.sailregattas.com
[Re: Mark Schneider]
#154774 09/11/08 03:21 PM 09/11/08 03:21 PM |
Posts: 3,906 Clermont, FL, USA | As far as I'm concerned the current system serves its purpose allowing a mixed bag of boats to sail together for Wednesday night beer can and weekend fleet races and this is where the "more is better" rule applies. But once you get past the Wednesday night beer can race or weekend fleet race, that's where the "more is better" ends for me. Putting everyone on the same line for a two day event then pretending that the handicap system makes everything square is not good for the sport in my opinion. Yes I know the area eliminations are run using this format but that is done out of necessity only and the DPN rules are pretty tight (no modifiers).
[Re: waterbug_wpb]
#154775 09/11/08 03:43 PM 09/11/08 03:43 PM |
Posts: 3,906 Clermont, FL, USA | The foilers have pretty much come and gone. But, if they ever start to foil in the 3knts wind range then we'll have an issue. When that time comes it will probably be handled much the same way the mono's deal with the multi's.
#154778 09/11/08 05:03 PM 09/11/08 05:03 PM |
Posts: 3,906 Clermont, FL, USA | I have almost no issue with the numbers Jake has laid out but, I'd want clarification regarding the main. I suspect the TheMightyHobie18 main is smaller than the Tiger main, if that's the case the big main hit needs to be used.
Using DPN numbers (not wind correctors) Hobie 18 = 71.4 Spin hit = .96 main hit = .98 (big main hit) Mast hit = .995
DPN = 71.4*.96*.98*.995 = 66.84
Just to make it crystal clear this configuration cannot be used at an Alter Cup Area qualifier.
That's my position on Windy's request for what it's worth.
One more thing... in light air this frankenboat is going to be a rocket especially if singlehanded!
[Re: David Ingram]
#154779 09/11/08 07:39 PM 09/11/08 07:39 PM |
Joined: Sep 2007 Posts: 531 Lake Murray SC FasterDamnit
Posts: 531 Lake Murray SC | I have almost no issue with the numbers Jake has laid out but, I'd want clarification regarding the main. I suspect the TheMightyHobie18 main is smaller than the Tiger main, if that's the case the big main hit needs to be used.
One more thing... in light air this frankenboat is going to be a rocket especially if singlehanded! As a comparison- H18Thang (no spin) has a Texel rating of 107 and is shared with P18-2 with DPN of 69.1. Add a spinnaker: 69.1 * .96 = 66.34. H18Thang w/ spin has Texel of 102, same as F16 2 up w/ spin- DPN 65.2. So the 66.84 is quite close to extrapolated range of 66.34 - 65.2. Since you are starting with a stock boat with known DPN, there shouldn't be any debate over using the standard modifiers. | | | Re: portsmouth calculations
[Re: WindyHillF20]
#154780 09/11/08 09:53 PM 09/11/08 09:53 PM |
Posts: 12,310 South Carolina | If this decision is to be made by someone, who is it? Would it be a EMSA ruling? I would like to put this to rest, will the 67.6 number work for those in the Southeast area where I sail? Jake seems to say yes, any others wish to chime in? Windy, it's going to be up to the individual race management - but we're all a close group and good friends. I don't believe anyone would have a problem with the number we reviewed - but keep an open mind about it in case someone presents a better argument for something else or the results show that the number may not be correct. Concensus could change...that's the peril of walking far off the beaten path and racing with it.
Jake Kohl | | | Re: portsmouth calculations
[Re: Kaos]
#154782 09/12/08 01:35 PM 09/12/08 01:35 PM |
Posts: 3,528 Looking for a Job, I got credi... | Why not just use SCHRS ?
<img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" /> <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" /> <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
F16 - GBR 553 - SOLD I also talk sport here | | | Re: portsmouth calculations
[Re: scooby_simon]
#154784 09/12/08 02:55 PM 09/12/08 02:55 PM |
Posts: 921 Alachua, FL | Why not just use SCHRS ?
<img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" /> <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" /> <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" /> That makes too much sense!
Jack Woehrle Hobie Wave #100, Tiger Shark III HCA-NA 5022-1 USSailing 654799E Alachua FL/Put-In-Bay | | | Re: portsmouth calculations
[Re: gregP19]
#154788 09/12/08 04:06 PM 09/12/08 04:06 PM |
Posts: 1,403 | Any thoughts on the mathematical conversion from DPN to PHRF? Sometimes us northeast cats have to mix it up with leaners. Yes you can and there are two ways, but I must advise IMPO converting DP-N to PHRF is a hokious pokious numbers. First is to take you DP-N after you have taken all the hits, subtract 55 and times that by 6. I.E. for a Prindle 18-2 in stock configuration 69.1 - 55 = 14.1 X 6 = 84.6. This formula can be found on the Portsmouth site Better as it is somewhat discussed use the Texel rating for you boat (if in stock configuration) explain to the RC that they are using the same foundation PHRF is using etc..... to establish the base rating. IMPO this is the best avenue to take.
Duh, I didn't think of that. That's a great idea. Can somebody run a Hobie 18 with an F18 sail plan through Texel...or wait...is there a point? I'm not intimately familiar with the Texel rating system but the Hobie 18 is going to come out the same as the F18 isn't it?
Go to the TEXEL site - there is a spreadsheet there that will allow you to plug in you measurements for your sails etc... and come up with a number. Don't be surprised if it is the same or less than a 3% off. Here's the deal:
People, the RC are VOLUNTEERS who are wired-out stressed just putting on the regatta. It's about as pleasant as a root canal. I am amazed that anyone can stand to run a race more than once, much less for years.
And to top it off, the people who come to the race want the RC to figure out what THEY should know, which is their OWN Portsmouth number. And bitch and cry about how the race is run, when they've NEVER run a race themselves, and refuse to spend the time to learn about Portsmouth.
The system is just fine. It's up to YOU, the RACERS, to make it work. The whole basis in Corinthian sailing is that it's SELF-POLICING.
This means that it's up to the RACERS: --to be honest. --to deal with EACH OTHER when someone isn't honest. --to solve infractions on the water, but when you can't, then take it to the RC in a reasonable tone WITH EVIDENCE TO BACK ANY ASSERTIONS YOU MAKE. <<That means KNOW YOUR NUMBER.
BTW...if you build yourself a Frankenboat, it's absolutely incumbent upon YOU to know your mods and report them to the RC. Live with what you're dealt - you didn't have to change the boat. WORD!!!!!! [color:"red"] [/color]
[Re: WindyHillF20]
#154790 09/12/08 05:17 PM 09/12/08 05:17 PM |
Posts: 531 Lake Murray SC | Am I too understand that the self-tacking jib takes no hit? Even though it is a smaller sail the ease of tacking with it makes me think some hit should apply. I planned to use the lower 67.6 which includes a .995 hit for the jib. Ding seems to think a 66.8. I looked into sail size early on and was told the Tiger main is smaller, I cut a foot off the TheMightyHobie18 boom and its still too long for the Tiger main. The mast is only 1.5' taller and this is the old ST main, not the STX. Hobie 18 mainsail area= 15.3 sq. meters Hobie Tiger mainsail area= 17.0 sq. meters. | | |
21,193
guests, and 605
