Page 3 of 4 1 2 3 4
Re: portsmouth calculations [Re: Mark Schneider] #154771
09/11/08 02:58 PM
09/11/08 02:58 PM
what's the DPN hit for foils?
Re: portsmouth calculations [Re: waterbug_wpb] #154772
09/11/08 03:20 PM
09/11/08 03:20 PM
brucat Offline
brucat  Offline
Mark,
I'm not avoiding anything, and I agree with some of what you're saying, but I really don't understand why you're attacking me (or maybe I'm reading too much into it?).
Nothing that I've written is untrue.
My points about who is responsible for what are in the rules.
As several others have pointed out here, we will never be able to make everyone truly happy with any handicap system (hey, there's no way to make everyone happy about anything, so why should that be different?). As long as people aren't happy, they complain.
One design makes the issue of handicaps go away. Is it perfect? No, but it avoids these specific discussions.
The only reason I replied to this thread to begin with is because there seemed to be confusion about the PRO having responsibility to determine a handicap number. As I see it (per the RRS), it is the responsibility of the sailor. If the boat is entered incorrectly, the event measurer files a report to the RC, who in turn files a protest and the jury ultimately decides the issue.
I guess the real lesson here is that OAs should not take this stuff lightly, and should make sure they have someone at the regatta to serve as the measurer (can be a competitor) who knows the ratings systems inside and out. Your point about having a local board agree on the number falls in line with this approach.
Re: portsmouth calculations [Re: waterbug_wpb] #154773
09/11/08 03:20 PM
09/11/08 03:20 PM
Annapolis, MD
Mark Schneider Offline
Annapolis, MD
First a flying foil boat has to race in a buoys' race... Then talk about the need to use windspeed adjustment ratings....
crac.sailregattas.com
Re: portsmouth calculations [Re: Mark Schneider] #154774
09/11/08 03:21 PM
09/11/08 03:21 PM
Clermont, FL, USA
David Ingram Offline
Clermont, FL, USA
As far as I'm concerned the current system serves its purpose allowing a mixed bag of boats to sail together for Wednesday night beer can and weekend fleet races and this is where the "more is better" rule applies. But once you get past the Wednesday night beer can race or weekend fleet race, that's where the "more is better" ends for me.
Putting everyone on the same line for a two day event then pretending that the handicap system makes everything square is not good for the sport in my opinion. Yes I know the area eliminations are run using this format but that is done out of necessity only and the DPN rules are pretty tight (no modifiers).
F18 USA 242
http://www.solarwind.solar
Re: portsmouth calculations [Re: waterbug_wpb] #154775
09/11/08 03:43 PM
09/11/08 03:43 PM
Clermont, FL, USA
Clermont, FL, USA
The foilers have pretty much come and gone. But, if they ever start to foil in the 3knts wind range then we'll have an issue. When that time comes it will probably be handled much the same way the mono's deal with the multi's.
F18 USA 242
Re: portsmouth calculations [Re: David Ingram] #154776
09/11/08 03:50 PM
09/11/08 03:50 PM
Graham, NC
WindyHillF20 Offline OP
Graham, NC
If this decision is to be made by someone, who is it? Would it be a EMSA ruling? I would like to put this to rest, will the 67.6 number work for those in the Southeast area where I sail? Jake seems to say yes, any others wish to chime in?
Re: portsmouth calculations [Re: David Ingram] #154777
09/11/08 04:22 PM
09/11/08 04:22 PM
Annapolis, MD
Annapolis, MD
Ding
Whatever... Our positions are well documented
Are you onboard with Windy Hill's request on his rating?
don't duck the question... again!! (since you are running the premire PN event in the region.... your word has weight)
Mark
Re: portsmouth calculations [Re: Mark Schneider] #154778
09/11/08 05:03 PM
09/11/08 05:03 PM
Clermont, FL, USA
Clermont, FL, USA
I have almost no issue with the numbers Jake has laid out but, I'd want clarification regarding the main. I suspect the TheMightyHobie18 main is smaller than the Tiger main, if that's the case the big main hit needs to be used.
Using DPN numbers (not wind correctors)
Hobie 18 = 71.4
Spin hit = .96
main hit = .98 (big main hit)
Mast hit = .995
DPN = 71.4*.96*.98*.995 = 66.84
Just to make it crystal clear this configuration cannot be used at an Alter Cup Area qualifier.
That's my position on Windy's request for what it's worth.
One more thing... in light air this frankenboat is going to be a rocket especially if singlehanded!
F18 USA 242
Re: portsmouth calculations [Re: David Ingram] #154779
09/11/08 07:39 PM
09/11/08 07:39 PM
Lake Murray SC
FasterDamnit Offline
Lake Murray SC
Hobie 18 = 71.4
Spin hit = .96
Mast hit = .995
As a comparison-
H18Thang (no spin) has a Texel rating of 107 and is shared with P18-2 with DPN of 69.1. Add a spinnaker: 69.1 * .96 = 66.34.
H18Thang w/ spin has Texel of 102, same as F16 2 up w/ spin- DPN 65.2.
So the 66.84 is quite close to extrapolated range of 66.34 - 65.2.
Since you are starting with a stock boat with known DPN, there shouldn't be any debate over using the standard modifiers.
Re: portsmouth calculations [Re: WindyHillF20] #154780
09/11/08 09:53 PM
09/11/08 09:53 PM
Windy, it's going to be up to the individual race management - but we're all a close group and good friends. I don't believe anyone would have a problem with the number we reviewed - but keep an open mind about it in case someone presents a better argument for something else or the results show that the number may not be correct. Concensus could change...that's the peril of walking far off the beaten path and racing with it.
Re: portsmouth calculations [Re: Jake] #154781
09/12/08 12:53 PM
09/12/08 12:53 PM
Fl
Kaos Offline
Kaos  Offline
Fl
I'll chime in too. The more you learn about any rating system the less accurate it becomes. I have been "handling" a large portsmouth regatta for years. Remember the system basically is better than not racing, but that is all. Everyone (so far)is assuming the averaged portsmouth rate, as oppossed to the wind corrected rates. Meaning that the rating will even be less accurate for any given one race. Handicapped racing must be looked at as, friends trying to enjoy sailing together. There is very little meaning in the results. If someone is trying to "beat the system", then it becomes obvious to those who do know what is going on very quickly and obviously. And as a previous poster said it will most likely not be protested. The reason is because it is obvious to those of us who know better. It is the old saying, argue with an idiot and you start to look like one too.
So if you find that the new set up seems a little too sucessful, that is your clue it is probably behaving outside what the system contimplated for giving proper corrections for. There are several boats that I know of that you can modify and get a very good (or unfair) rating. Is it worth making a big fuss over it? No. However the sailors that engage in that type of activity may not know that they are not getting the respect from the other sailors that they may think is due them.
Rather than risk that out come, if you have a really "different" set up than what the other sailors have be prepared to adjust the rating downward yourself. There is only the respect of others that you are competing for, no money in this game. So act accordingly and you can't go wrong.
Re: portsmouth calculations [Re: Kaos] #154782
09/12/08 01:35 PM
09/12/08 01:35 PM
Why not just use SCHRS ?
<img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" /> <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" /> <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
Re: portsmouth calculations [Re: Kaos] #154783
09/12/08 02:54 PM
09/12/08 02:54 PM
Punta Gorda, FL
jkkartz1 Offline
jkkartz1  Offline
Punta Gorda, FL
Can you race unoffically until enough experience to establish a rating?
Yes you pay the entry and enjoy all rights and privleges of racing but be ineligible for any trophys. Would 10 to 20 individual races (2 to 4 regattas) be sufficent to establish a fair rating?
Re: portsmouth calculations [Re: scooby_simon] #154784
09/12/08 02:55 PM
09/12/08 02:55 PM
Alachua, FL
Mugrace72 Offline
Mugrace72  Offline
Alachua, FL
That makes too much sense!
Jack Woehrle
HCA-NA 5022-1
USSailing 654799E
Alachua FL/Put-In-Bay
Re: portsmouth calculations [Re: Mugrace72] #154785
09/12/08 03:03 PM
09/12/08 03:03 PM
Fl
Kaos Offline
Kaos  Offline
Fl
SCHRS is for small cats...
We race all boats together, monohulls, dingies, sailing canoes, PHRF boats ...everything...Porstmouth can do everything.
Next all the fancy formulas miss one big factor the wind. It is always a different speed coming from different directions and is different in the various areas of a single race course. All rating system simply ignore that big fat glaring part of the game. It is a simple consistant x. If you boat does happen to work well with that assunption..oh well..
Re: portsmouth calculations [Re: jkkartz1] #154786
09/12/08 03:08 PM
09/12/08 03:08 PM
Fl
Kaos Offline
Kaos  Offline
Fl
Not that big a deal. I would not worry about it. Being up front it all it takes. Try your rating out. It will take awhile for you to get a feel if the rating is even an issue. If anyone has a beef, just be willing to adjust is all. Typically the ones with a beef that can't be reasonable in discussing... probably know less and are more in the dark than you...
You are on the right track.... <img src="http://www.catsailor.com/forums/images/graemlins/smile.gif" alt="" />
Re: portsmouth calculations [Re: Kaos] #154787
09/12/08 03:56 PM
09/12/08 03:56 PM
brucat Offline
brucat  Offline
"If someone is trying to "beat the system... it will most likely not be protested... It is the old saying, argue with an idiot and you start to look like one too."
While it's hard to disagree with that last statement, this is the attitude that slowly kills events. When people get tired of rules not being enforced, they may stop coming to regattas.
This is one reason that class rules are strictly enforced at Hobie events. We don't care (as much) if one person goes away because we won't allow illegal sails or no Comp Tip, we just don't want to lose the whole fleet slowly over time because the rules aren't being enforced, and someone is perceived to be unilaterally gaining.
Re: portsmouth calculations [Re: gregP19] #154788
09/12/08 04:06 PM
09/12/08 04:06 PM
V
Ventucky Red Offline
V
Any thoughts on the mathematical conversion from DPN to PHRF? Sometimes us northeast cats have to mix it up with leaners.
Yes you can and there are two ways, but I must advise IMPO converting DP-N to PHRF is a hokious pokious numbers.
First is to take you DP-N after you have taken all the hits, subtract 55 and times that by 6. I.E. for a Prindle 18-2 in stock configuration 69.1 - 55 = 14.1 X 6 = 84.6. This formula can be found on the Portsmouth site
Better as it is somewhat discussed use the Texel rating for you boat (if in stock configuration) explain to the RC that they are using the same foundation PHRF is using etc..... to establish the base rating.
IMPO this is the best avenue to take.
Duh, I didn't think of that. That's a great idea. Can somebody run a Hobie 18 with an F18 sail plan through Texel...or wait...is there a point? I'm not intimately familiar with the Texel rating system but the Hobie 18 is going to come out the same as the F18 isn't it?
Go to the TEXEL site - there is a spreadsheet there that will allow you to plug in you measurements for your sails etc... and come up with a number. Don't be surprised if it is the same or less than a 3% off.
Here's the deal:
People, the RC are VOLUNTEERS who are wired-out stressed just putting on the regatta. It's about as pleasant as a root canal. I am amazed that anyone can stand to run a race more than once, much less for years.
And to top it off, the people who come to the race want the RC to figure out what THEY should know, which is their OWN Portsmouth number. And bitch and cry about how the race is run, when they've NEVER run a race themselves, and refuse to spend the time to learn about Portsmouth.
The system is just fine. It's up to YOU, the RACERS, to make it work. The whole basis in Corinthian sailing is that it's SELF-POLICING.
This means that it's up to the RACERS:
--to be honest.
--to deal with EACH OTHER when someone isn't honest.
--to solve infractions on the water, but when you can't, then take it to the RC in a reasonable tone WITH EVIDENCE TO BACK ANY ASSERTIONS YOU MAKE. <<That means KNOW YOUR NUMBER.
BTW...if you build yourself a Frankenboat, it's absolutely incumbent upon YOU to know your mods and report them to the RC. Live with what you're dealt - you didn't have to change the boat.
WORD!!!!!! [color:"red"] [/color]
Re: portsmouth calculations [Re: David Ingram] #154789
09/12/08 05:08 PM
09/12/08 05:08 PM
Graham, NC
Graham, NC
Am I too understand that the self-tacking jib takes no hit? Even though it is a smaller sail the ease of tacking with it makes me think some hit should apply. I planned to use the lower 67.6 which includes a .995 hit for the jib. Ding seems to think a 66.8. I looked into sail size early on and was told the Tiger main is smaller, I cut a foot off the TheMightyHobie18 boom and its still too long for the Tiger main. The mast is only 1.5' taller and this is the old ST main, not the STX.
Re: portsmouth calculations [Re: WindyHillF20] #154790
09/12/08 05:17 PM
09/12/08 05:17 PM
Lake Murray SC
Lake Murray SC
Hobie 18 mainsail area= 15.3 sq. meters
Hobie Tiger mainsail area= 17.0 sq. meters.
Page 3 of 4 1 2 3 4
Most Online22,490
Yesterday at 08:14 AM
