Diamond wire tension on an a-cat #155853
09/23/08 09:35 PM
09/23/08 09:35 PM
Jake Offline OP
Jake  Offline OP
What's the maximum "reasonable" diamond wire tension to run on an a-cat?
Re: Diamond wire tension on an a-cat [Re: Jake] #155854
09/23/08 10:46 PM
09/23/08 10:46 PM
Tighten them until they are tight, then tighten some more, when you think they are really tight, tighten more. Important to keep measuring frequently. Tighten more until the mast snaps.
Buy new mast, take some poundage off last reading. Run them like that>
<img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" /> <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" /> <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" /> <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
Re: Diamond wire tension on an a-cat [Re: Jake] #155855
09/24/08 01:58 AM
09/24/08 01:58 AM
Mark P Offline
Mark P  Offline
Shouldn't you ask the guy who made the mast! This year I used a saarberg mast but that had a variable control diamond tensioner fitted but the National Champ Chris Field just had the normal bottle screws. I can't be positive what the max tension would be for this particular mast but I think Chris was running with 38 on the new loose gauge but there again Saarberg masts are custom built to each individual customer as near as damit.
MP*MULTIHULLS
Re: Diamond wire tension on an a-cat [Re: Mark P] #155856
09/24/08 06:03 AM
09/24/08 06:03 AM
Tornado_ALIVE Offline
I would imagine just tight enough so you do not have any slack in the windward sidestay when out on trap.
Re: Diamond wire tension on an a-cat [Re: Tornado_ALIVE] #155857
09/24/08 06:52 AM
09/24/08 06:52 AM
Jake Offline OP
Jake  Offline OP
I'm just trying to find a reasonable range of tension so I can start experimenting with various tensions...I don't want to approach the realm of compromising the mast structure. The mast was constructed by Allied Composites 9 years ago and it doesn't appear they're making a-cat masts anymore. Although I have both styles of gauge, If you have it, I would like the measurement in pounds tension (I know, beggers / choosers).
With the diamond wires?
Re: Diamond wire tension on an a-cat [Re: Jake] #155858
09/24/08 07:41 AM
09/24/08 07:41 AM
Atlanta
bvining Offline
bvining  Offline
Atlanta
I'm at 32 on the Model A Loos, Part 91
60mm sweep on the spreaders, 2 inches prebend, 45cm long spreaders.
Re: Diamond wire tension on an a-cat [Re: bvining] #155859
09/24/08 07:57 AM
09/24/08 07:57 AM
Portland, Maine
ThunderMuffin Offline
Portland, Maine
Your ruler must be very very confused :P
Re: Diamond wire tension on an a-cat [Re: ThunderMuffin] #155860
09/24/08 08:39 AM
09/24/08 08:39 AM
lesburn1 Offline
lesburn1  Offline
Doesn't your tape measure have both inches and millimeters on it. Mine also has a Planck length scale. <img src="http://www.catsailor.com/forums/images/graemlins/cool.gif" alt="" />
I few years ago I came across a drywaller's T-square (24"X48") and I have found in very handy for boat building.
At 8 dollars I think it's the least expensive tool I have.
The biggest problem with it is it does not have a metric scale on it. Next time I go to Canada I will have to get one there.
lesburn1.blogspot.com
A-Cat USA 49
18Sq 49
Re: Diamond wire tension on an a-cat [Re: ThunderMuffin] #155861
09/24/08 08:51 AM
09/24/08 08:51 AM
Atlanta
bvining Offline
bvining  Offline
Atlanta
not really.
Re: Diamond wire tension on an a-cat [Re: Jake] #155862
09/24/08 08:53 AM
09/24/08 08:53 AM
Houston
carlbohannon Offline
Houston
I am running 900-1500 lbs indicated on a stiff Marstrom mast. I use "indicated" because I have tiny rod diamond "wires" and I have never been sure of the accurancy of the gauge.
In practice I simply adjust the bolt left or right, in half turns, depending on the wind. This is written on the mast with an old grease pencil. Periodically, I set the mast to known prebend and call that zero. When I set the prebend, I mostly, measure the tension with the gauge and write that on the gauge.
Re: Diamond wire tension on an a-cat [Re: carlbohannon] #155863
09/24/08 10:12 AM
09/24/08 10:12 AM
Jake Offline OP
Jake  Offline OP
Yeah, I would figure that the Loos gauges in use out there are not suited for checking tension on rod rigging. I also bet there is some significant variability attributable to the difference between 7x7 wire and dye-form wire with these same gauges.
Bill, do you know what the diameter of the wire is on your diamonds?
We sometimes go up to 800 or 900 lbs of tension on the I20 but I'm nearly certain that could mean death for my a-cat mast. It's currently at 350 pounds of tension and performing well in light to moderate breeze. Is 500 lbs a reasonable upper maximum? I found a website for Applied Composites - I'll check with them too.
Re: Diamond wire tension on an a-cat [Re: carlbohannon] #155864
09/24/08 10:15 AM
09/24/08 10:15 AM
U
USA197 Offline
USA197  Offline
U
I have a 2003 allied composites mast with a 2007 Glaser sail. I sail at 190 lbs. I am still getting dialed in with my mast settings, but my current settings are 34 on the old loos gauge and 63mm of spreader rake.
If you are getting into the range where you are worried about the mast breaking from diamond tension you are well beyond any setting that would be fast. The tightest I have seen anybody run the diamonds are 36-37. Small changes make a big difference on these boats.
Eric Marshack
Re: Diamond wire tension on an a-cat [Re: USA197] #155865
09/24/08 01:19 PM
09/24/08 01:19 PM
Gainesville, FL 32607 USA
dacarls Offline
dacarls  Offline
Eric Marshack has numbers that work for him that are in my A-class ballpark too: I have 4 carbon masts, some of which are not yet broken.
See Landenberger-sailing.com Tuning guide A-class 2005. Landy describes that you have to match sail luffcurve to mast, mast prebend, downhaul, spreader rake, diamond wire tension: And know why all of these interact to be correct.
Briefly- 33-37 (max in a blow) on the Loos guage with usual twisted wire diamonds- these #s change with dyform, and change more with solid wire rigging.
Dacarls:
Re: Diamond wire tension on an a-cat [Re: dacarls] #155866
09/24/08 02:52 PM
09/24/08 02:52 PM
Jake Offline OP
Jake  Offline OP
does no one convert their numbers to pounds!? <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
Re: Diamond wire tension on an a-cat [Re: Jake] #155867
09/24/08 04:19 PM
09/24/08 04:19 PM
Nope; 37 is easier to remember than 791 lbs (or what ever it is....)
Re: Diamond wire tension on an a-cat [Re: scooby_simon] #155868
09/24/08 04:56 PM
09/24/08 04:56 PM
2017 F18 Americas Site
Dan_Delave Offline
Dan_Delave  Offline
I just set up an old Boyer Mark 3 for a friend. I had to put on new wires and did not know at all what the diamond tension should be. I went over to all the other A Cats in the yard, 5 of them. They were all between 24 and 26 on the Black Loos Guage, which I think of as the newer one. I set this one to 25.
Dan
Re: Diamond wire tension on an a-cat [Re: scooby_simon] #155869
09/24/08 09:25 PM
09/24/08 09:25 PM
Jake Offline OP
Jake  Offline OP
But "37" is meaningless unless you know the wire diameter, wire type, and have the same exact gauge (that has been calibrated).
Re: Diamond wire tension on an a-cat [Re: Jake] #155870
09/25/08 03:59 AM
09/25/08 03:59 AM
LOL..... Skim reading is a bad habit of mine. Thought it said stay wires.
Re: Diamond wire tension on an a-cat [Re: Jake] #155871
09/25/08 06:48 AM
09/25/08 06:48 AM
Atlanta
bvining Offline
bvining  Offline
Atlanta
The wire thickness is 2.5mm, dyform
Old style guage, not calibrated to anything.
Re: Diamond wire tension on an a-cat [Re: Jake] #155872
09/25/08 09:12 AM
09/25/08 09:12 AM
Houston
Houston
My rod diamond wires are 2mm. I have been told that the rods are really stainless music wire.
I have a rod gauge but 2mm is the bottom of it's range and my "rod" is a different alloy. Mostly I use a Loos gauge and don't worry about what the numbers mean in Lbs.
If I had to set your mast up, I would match the spreaders and prebend of an existing mast and use a gauge to repeat that setting.
1 registered members (FredL), 446 guests, and 68 spiders.
