| Re: Solid glass laminate
[Re: Stewart]
#155890 09/24/08 01:22 PM 09/24/08 01:22 PM |
Posts: 805 Gainesville, FL 32607 USA | Who makes 1970s style solid fiberglass hulls anymore? Certainly not modern International Moth builders! I would say look to the Gougeon Bros.
[Re: dacarls]
#155891 09/24/08 08:11 PM 09/24/08 08:11 PM |
Posts: 190 | Try your question here http://www.boatdesign.net/forums/forumdisplay.php?f=20But don't tell them I sent you! <img src="http://www.catsailor.com/forums/images/graemlins/laugh.gif" alt="" />
lesburn1.blogspot.com
A-Cat USA 49 18Sq 49
[Re: Stewart]
#155894 09/25/08 12:07 PM 09/25/08 12:07 PM |
Posts: 1,203 uk | Hobie 16 changed to foam sandwich a long time ago.
[Re: harryproa]
#155895 09/25/08 12:09 PM 09/25/08 12:09 PM |
Posts: 1,203 uk | Dart 18 is about 4mm thick but is a fairly lightly loaded hull
[Re: Darryl_Barrett]
#155897 09/28/08 08:13 AM 09/28/08 08:13 AM |
Joined: Jan 2005 Posts: 31 Perth Western Australia harryproa OP
Posts: 31 Perth Western Australia | G'day,
Thanks Darryl, I figured on a layer of 200 gsm glass instead of the csm either side of 2mm coremat, but will do some tests to see. About 3 kgs /sqm, plus veil and gel, which is not a lot heavier than a foam laminate on 8 sq m of hull and decks.
Bvinning I have been asked to design a car toppable harryproa (harriette) for kids to learn on. Standard spec: light enough to car top, easy to rig and sail, cheap to produce, safe, indestructable, fast etc. Not sure if it will happen, but it is fun rethinking the build for mass production and checking out the options.
Thanks to all who replied.
regards,
Rob. | | | Re: Solid glass laminate
[Re: harryproa]
#155898 09/28/08 09:28 PM 09/28/08 09:28 PM |
Joined: Feb 2004 Posts: 1,012 South Australia Darryl_Barrett
Posts: 1,012 South Australia | 200 gm/sqm either side of 2mm coremat may be a “light” finished laminate but it will also be a very flexible laminate with fairly low impact strength and also require extensive internal "framing" for rigidity integrity over any reasonable square area, which could negate any weight savings if/when going to such a light lay-up. Two laminates of 200 gm/sqm CSM plus 2mm coremat plus resin would equal approx’ as low as 1.2kg/sqm to 1.5kg/sqm depending on how well the resin (polyester) is distributed (these weights assume that the person laying up these laminates is able to remove all the excess resin, if not then the weight will regularly result to be approx’ 30% plus higher if “amateur” built due to over resining) PLUS the extra weight for any additional reinforcing framing. The better glass to use for a Coremat laminate would seem to be CSM rather than any woven product, which in practice delaminates much easier than the CSM with impact and/or excessive flexing. For two laminates of 300gm/sq CSM plus 2mm of coremat plus resin equals approx’ 1.8kgs to 2kgs/sqm. With the heavier laminate, over 60% of any internal framing can be accomplished using “bare” polystyrene, epoxy resined or siliconed into place, but with the lighter laminate then approx’ 90% of internal framing would require rigid (heavier) framing, IE marine ply or better still, semi rigid PVC foam sandwich constructed “frames” and bulkheads – six of one, half a dozen of the other? | | |
584
guests, and 575
