Tramp Lacing / Jib block setup #156087
09/28/08 12:57 PM
09/28/08 12:57 PM
Geelong, Victoria, Australia
millex5 Offline OP
millex5  Offline OP
I have just got hold of a new tramp for a Taipan 4.9, and need two things:
1st, a description of how to lace it to the rear beam, and 2nd, pictures of how the jib blocks attach to the boat/tramp.
thanks,
Alex
Alex Millington
Taipan 4.9 - Ragnarok
Re: Tramp Lacing / Jib block setup [Re: millex5] #156088
09/29/08 03:01 AM
09/29/08 03:01 AM
Squiggle Offline
Squiggle  Offline
Hi, Alex
For the first Question:
On the Bottom of the rear beam there should be a number of little black plastic tie off points, just use a length of thin road and lace it using these. Nothing fancy just make sure it doesn't go anywhere.
Secondly, There are two methods for attaching the jib blocks to the tramp. One method (older) involves a wire that it attached to two adjustable rails on either hull, however less people use this method.
The other is some lacing that should be built into the tramp (If you have it there should be four loops on either sides of the boat about a foot back from the font beam) Simply connect the block to one bit of this lacing. (I have attached a photo of what it should look like on you boat)
Chris Taipan 4.9 AUS 83 PMYC
Re: Tramp Lacing / Jib block setup [Re: Squiggle] #156089
09/29/08 07:27 AM
09/29/08 07:27 AM
millex5 Offline OP
millex5  Offline OP
perfect - thanks for that.
Alex Millington
0 registered members (), 285 guests, and 47 spiders.
