Adult 12' cat???? #156363
10/02/08 01:02 PM
10/02/08 01:02 PM
Ft. Pierce, Fl. USA
Seeker Offline OP
Seeker  Offline OP
Ft. Pierce, Fl. USA
Not to dilute the successful effort to provide an entry catamaran for children and teenagers, nor to distract those who are designing or building the youth boats…but has anyone moved forward with an adult version (180lb crew weight)?…a “quick after work” 12’+ cat that a few expressed interest in when the F12 concept was first being kicked about? Possibly going a few inches longer to take advantage of the properties Wouter brought to light many moons ago?
Robert
Re: Adult 12' cat???? [Re: Seeker] #156364
10/02/08 01:23 PM
10/02/08 01:23 PM
Finland
Gato Offline
Gato  Offline
Finland
It would be too fat. 14 feet is the option, but is there a real need?
Re: Adult 12' cat???? [Re: Gato] #156365
10/02/08 02:25 PM
10/02/08 02:25 PM
Yes...with the time crunched Americans!
Kick this question out on the Open forum and see the fire storm ensue <img src="http://www.catsailor.com/forums/images/graemlins/shocked.gif" alt="" />
Re: Adult 12' cat???? [Re: _flatlander_] #156366
10/02/08 03:14 PM
10/02/08 03:14 PM
Darryl Barret have pushed the 14 for a long time without much interest. He have a really good product, but not much of a market. Berny also have a really good 14 and moulds to build more, but again there is not enough real interest.
Re: Adult 12' cat???? [Re: Rolf_Nilsen] #156367
10/02/08 03:24 PM
10/02/08 03:24 PM
as Robert has eluded, this goes back to the arguement/s (err...discussions) of whether the F12 would have a stayed or un-stayed rig, and the five minute assembly time originally proposed by Wouter.
Re: Adult 12' cat???? [Re: Seeker] #156368
10/02/08 04:57 PM
10/02/08 04:57 PM
Kingston SE South Australia
JeffS Offline
JeffS  Offline
Robert if your not looking for high performance then the F12 will do fine. I took my 8yo lad out on his 11ft Arafura Cadet (with much thinner hulls than the F12) 3 weeks ago, total crew weight 130kg and we went along just fine. When I watched the video afterwards I was amazed at the way it carried us. You can also see the F12 is carrying Gato no problem. The problem with the short boats is pitchpoling which means an adult in a blow probably needs a trap wire like the Arafura has
regards
Jeff Southall
Current boats
Nacra 5.8 1667 Ram Raider
Nacra 18 Square
Arrow 1576
Re: Adult 12' cat???? [Re: JeffS] #156369
10/02/08 07:35 PM
10/02/08 07:35 PM
Ft. Pierce, Fl. USA
Seeker Offline OP
Seeker  Offline OP
Ft. Pierce, Fl. USA
“Robert if your not looking for high performance then the F12 will do fine.”
Performance is always important…if one just wants to drift around there are plenty of mono slugs...not looking to go 30 knotts...but it would have to go fast enough to make it worth while.
Robert
Re: Adult 12' cat???? [Re: Seeker] #156370
10/02/08 08:16 PM
10/02/08 08:16 PM
JeffS Offline
JeffS  Offline
I watched this 11ft Arafura play in wind and waves when I was overpowered on my 5.8
http://www.catsailor.com/forums/download.php?Number=154352
http://www.catsailor.com/forums/download.php?Number=154353
I believe as long as you've got a stayed rig and traps you can add the sail area you want, I would expect my F12's to be much more bouyant
regards
Jeff Southall
Current boats
Nacra 18 Square
Arrow 1576
Re: Adult 12' cat???? [Re: JeffS] #156371
10/03/08 12:51 AM
10/03/08 12:51 AM
Finland
Gato Offline
Gato  Offline
Finland
I have been sailing the two F12 cats that I have in conditions from 0 -30 knots of wind. + 15 knots of wind and they are fun with the current sail area. When it gets up to +25 knots at least the DS12 starts to dig the nose in. with the current sail area there is no need for a trap, not even to hike. Ther is another problem rising when your weight i two times the weight of the platform,a small shift in position changes a lot.
Re: Adult 12' cat???? [Re: Gato] #156372
10/03/08 01:47 AM
10/03/08 01:47 AM
JeffS Offline
JeffS  Offline
If the F12's were the only cat you had what rig would you put on them?
regards
Jeff Southall
Current boats
Nacra 18 Square
Arrow 1576
Re: Adult 12' cat???? [Re: JeffS] #156373
10/03/08 02:33 AM
10/03/08 02:33 AM
Finland
Gato Offline
Gato  Offline
Finland
They are in fact the only cats that I have for the moment!!!
I have been thinking of powering up them a little bit but decided against it. They are designed for the rig they carry, and making the mast much longer will at least here attract the attention of the police once cartopping.
They are fun to sail, but for me the ultimate would be a 14 feet with a little bit more sail.
So for the F12 a stayed rig with 7-9 m2 of sail depending on the conditions you are sailing in.
Re: Adult 12' cat???? [Re: Gato] #156374
10/03/08 11:44 PM
10/03/08 11:44 PM
Asuncion, Paraguay
Luiz Offline
Luiz  Offline
Asuncion, Paraguay
Are the stays important? Wouldn't a self standing mast work almost the same way?
Luiz
Re: Adult 12' cat???? [Re: Luiz] #156375
10/04/08 04:09 AM
10/04/08 04:09 AM
Finland
Gato Offline
Gato  Offline
Finland
The solution with the Dynema shrouds and forestay is so simple , easy and cheap and it gives you a good control of the rig so I don't see why not...
Re: Adult 12' cat???? [Re: Luiz] #156376
10/04/08 05:58 PM
10/04/08 05:58 PM
JeffS Offline
JeffS  Offline
I was thinking of upping it closer to 9 or 10m by adding a jib so that two teenagers can have a go on it.
A well engineered non stayed mast should work fine. I had a wow of a time on a Bic open with unstayed rig in big wind but my kids want traps and deep down I want traps so I can use it on days when my other cats are overpowered.
regards
Jeff Southall
Current boats
Nacra 18 Square
Arrow 1576
Re: Adult 12' cat???? [Re: JeffS] #156377
10/06/08 02:50 AM
10/06/08 02:50 AM
Finland
Gato Offline
Gato  Offline
Finland
We have been thinking of adding a kite. It's downwind that you feel that there is not power enough, and there the jibe won't help...
1 registered members (WorrellGal50), 427 guests, and 91 spiders.
Posts267,056
