| inward tension you put on the bows #156483 10/06/08 12:22 PM 10/06/08 12:22 PM | Anonymous
| Anonymous
Unregistered | I am hearing that a "Low" spin pole puts inward stress on the bows. I sail a Mystere 5.5 and fly a Tornado Spin. I have tried to rake the mast back.. but this effects my helm to much and depowers me to much. Is this really a serious concern? Anyone ever see a Mystere fail due to this? Should i look into making a foil? Thanks, ![[Linked Image]](http://www.metalfree.com/a/cat/new-spin.jpg) | | | Re: inward tension you put on the bows
[Re: ]
#156484 10/06/08 12:24 PM 10/06/08 12:24 PM | Anonymous
| Anonymous
Unregistered | Another pic: ![[Linked Image]](http://www.metalfree.com/a/cat/new-spin2.jpg) | | | Re: inward tension you put on the bows
[Re: ]
#156485 10/06/08 12:58 PM 10/06/08 12:58 PM |
Posts: 3,116 Annapolis, MD | Did you shorten the bridle to lower the pole to lengthen the luff lenght for your chute?
If not... the mystere's usually have a sub deck in the bows ... so you should be good.
Just for grins... where is your spinaker bail... I am surprised the spin luff is not too long.
crac.sailregattas.com
[Re: Mark Schneider]
#156487 10/06/08 04:38 PM 10/06/08 04:38 PM | Anonymous
| Anonymous
Unregistered | Did you shorten the bridle to lower the pole to lengthen the luff lenght for your chute?
Just for grins... where is your spinaker bail... I am surprised the spin luff is not too long. My pole was very high when i used a F18 spin.. i had to lower it alot when i got the Tornado spin to get luff tension on the bigger sail. PS my spin bridal is a cable with line on the ends for adjusting pre-bend / position Is a "spinnaker bail" the same thing as a tang (more or less)? If so... the picture below (from when i first rigged the f18 spin) shows where the tang is... i have lowered the halyard block by 8" as it made me nervous being so high.... i drilled holes in my mainsail track and ran a line in front of my mast for the block to swivel on and ran a line up to the tang. ![[Linked Image]](http://www.metalfree.com/a/cat/spi/2.jpg)
[Re: ]
#156489 10/06/08 05:14 PM 10/06/08 05:14 PM |
Posts: 266 UK | You could do with a compression tube as used on the Condor 16/Hurricane 4.9. If I recall correctly this was a 1" od tube with a 1/4" wall and had tube end pieces(solid) that had a groove that slotted over the bridle tangs which were at 90 degrees to the hull. If yours are as suspected in line with the hull you could look to carefully drill through the tube and attach with a large bow shackle which would also be used to attach the bridle. The advantage of this arrangement is that it cannot 'capsize' like the nacra flying foil which leads to expensive breakages. http://www.catsailor.com/gallery/displayimage.php?album=lastupby&cat=0&pos=1http://www.catsailor.com/gallery/displayimage.php?album=lastupby&cat=0&pos=2Cheshirecatman | | | Re: inward tension you put on the bows
[Re: DHO]
#156494 10/07/08 07:24 AM 10/07/08 07:24 AM | Anonymous
| Anonymous
Unregistered | Actually cos(45 deg) = root 2/2 = approx. 0.707. Coincidentally, sin (45 deg) also = root2/2. Sooooo... if i read this all correctly.... as long as i dont have a 707 lb crew member sitting atop my mast, and an unladen african swallow doesn't drop a coconut on my spinnaker, i should be ok with my setup? | | | Re: inward tension you put on the bows
[Re: ]
#156495 10/07/08 10:18 AM 10/07/08 10:18 AM |
Posts: 5,590 Naples, FL | but what if there were TWO unladen african swallows? Maybe they could tie it between them?
[Re: JeffS]
#156500 10/08/08 10:06 AM 10/08/08 10:06 AM |
Posts: 5,590 Naples, FL | Blue....NO, Yellow!
Aaaaaaaaarrrrrrrrrrrgggggggghhhhh
1 registered members (vasil),
372
guests, and 39
