| Ocean cruising lessons learned #156649 10/07/08 08:11 PM 10/07/08 08:11 PM |
Joined: Nov 2006 Posts: 30 Lake Norman, NC Doug_P182_LKN OP
Posts: 30 Lake Norman, NC | So let me pick your brains: I've never done a distance sail in the ocean before. This weekend I'm doing a regatta which will be about a 25-mile point-to-point sail. What are some of the tips, pieces of advice, lessons learned you've gained from doing something similar?
Doug Bernstein Prindle 18.2 'Special Treat' #590 Lake Norman, NC
| | | Re: Ocean cruising lessons learned
[Re: ThunderMuffin]
#156651 10/08/08 06:06 AM 10/08/08 06:06 AM |
Posts: 30 Lake Norman, NC | Are you doing it in your cat (if so what regatta is this!?) or are you in a bigger boat? Yes, the cat. She's all I've got (if you don't count the sailboards) and I wouldn't have asked on this board if I didn't mean the Prindle. It's not a race, just a family-fun thing called the pirates festival out to Cape Lookout on the NC Outer Banks.
[Re: Doug_P182_LKN]
#156652 10/08/08 06:49 AM 10/08/08 06:49 AM |
Posts: 12,310 South Carolina | If there's more than one boat, then it's a race! 25 miles is a reasonable distance to do in a couple of hours but you do need to have a few things ready. Be prepared to right the boat without depending on outside assistance and wear the life vests all the time. Don't sail alone and be sure to have at least two people on the boat that can sail it in the event one falls off. Have plenty of water, food....the basics.
Jake Kohl | | | Re: Ocean cruising lessons learned
#156653 10/08/08 08:16 AM 10/08/08 08:16 AM |
Posts: 144 Near SLC, Utah | In addition to some self-sufficiency waterproof food and fresh water, we find it handy to have some other things when we're doing such sailing.
1. A couple of waterproof single smoke and ariel flares is awful handy just in case.
2. One paddle is better than a daggerboard or paddling surfboard style and we wished we had two when the sun went down and we still had a long way to go w/o wind.
3. A fully charged cell phone,
4. LED divers flashlight and a couple of chemical lights and a whistle for each person,
5. submersible GPS,
6. a chart of the area,
7. small waterproof strobe,
8. VHF submersible radio,
9. A few extra batteries in a water proof container with your cell phone is good insurance,
10. A small sea anchor was handy and on one occasion staying put was a good thing and being bow to seas rather than beam on made life better than otherwise.
11. Suitable clothing for expected conditions and something so you can be warm and seen if it turns into an unexpected night-time thing.
12. Give someone who is reliable a copy of your float plan and some instructions if they don't hear back from you at a prearranged time.
13. Give big boats and especially ships a very wide berth. They may or may not actually see you and they don't turn on a dime nor do they stop very well. It is always surprising how fast they are actually going. Just because your a sail boat with the right of way, doesn't mean it will go that way ...and bigger always has the right of way and is more forgiving in a crash than is smaller.
14. PFDs for each whether or not your wearing wet or dry suits.
We were caught out once or twice on such sails and found these kinds of things very useful.
Most of this kind of stuff can be simply lanyard and/or tie to our PFDs so it is easily available for each person whether you or your crew is on the boat or unexpectedly in the water.
On a couple of occasions, we intended a day sail and it turned into a late sail going until nearly midnight. One went unexpectedly until 10 or so the next AM.
Group sailing is great but we generally have often become separated...sometimes never seeing the other boats or they each other.
Assuming what someone else may or may not do is a poor substitute for proper preparation, planning, communication and contingencies. Don't rely totally on someone else to pull your bacon out of the fire.
Expect the best, plan and prepare for the worst, then enjoy. | | | Re: Ocean cruising lessons learned
[Re: tomthouse]
#156656 10/08/08 08:44 AM 10/08/08 08:44 AM | Anonymous
| Anonymous
Unregistered | sunscreen! an all day event on the water can cause sunburn. Amen to food, water, spares and a VHF submersible. | | | Re: Ocean cruising lessons learned
[Re: ]
#156657 10/08/08 08:46 AM 10/08/08 08:46 AM |
Joined: Jan 2008 Posts: 3,655 Portland, Maine ThunderMuffin
Posts: 3,655 Portland, Maine | We were sailing out and about and had a side stay shackle split ring catch on a line and go junk. Tape every one of your split rings. Every.... single..... one.... | | | Re: Ocean cruising lessons learned
[Re: ThunderMuffin]
#156658 10/08/08 08:53 AM 10/08/08 08:53 AM |
Posts: 829 Charleston, SC | I've sailed that area a fair amount. You'll have plenty of people around if something goes wrong. Watch out for the sand bars and stay in the channel if you're on the backside of the cape. There is a park out on the end of Harker's Island that I've launched from with the Nacra 20/Hobie 16/etc. I've also launched from the old fishery building in Beaufort. Where are you launching out of?
Trey
[Re: NCSUtrey]
#156661 10/08/08 02:27 PM 10/08/08 02:27 PM |
Posts: 30 Lake Norman, NC | Thanks for all the advice! We're leaving from the public docks in Beaufort, heading out the inlet and around to the Cape. Weather looks to be low 70's and steady 10-15 winds from the North. Should make for a great sail! 30 boats (mostly half-cats with families) all decorated out as pirate ships, firing stuff at each other.
[Re: Doug_P182_LKN]
#156662 10/08/08 02:44 PM 10/08/08 02:44 PM | Anonymous
| Anonymous
Unregistered | 30 boats (mostly half-cats with families) 1/2 cats? ummmmmm ... what???? | | | Re: Ocean cruising lessons learned
[Re: Doug_P182_LKN]
#156663 10/08/08 02:47 PM 10/08/08 02:47 PM |
Posts: 3,655 Portland, Maine | So you're going into and out of beaufort inlet. Some advice for you then, Check your tides and your winds when you'll be entering and exitting. The currents run in and out of there can be ridiculous and will either suck you out or pull you in if theres not enough wind to carry you. There's a USCG station right there in Morehead City and are a simple VHF call away if you need them. Overall a very nice place to sail. Stay in the channel unless you want to hit sandbars. 1/2 cats? ummmmmm ... what???? a good humored jab at monohulls. They're one-hull short of a cat :P | | | Re: Ocean cruising lessons learned
[Re: ThunderMuffin]
#156664 10/08/08 03:14 PM 10/08/08 03:14 PM |
Posts: 12,310 South Carolina | Stay in the channel unless you want to hit sandbars.
However, if it is light and you're working on getting through an opposing current, get to the shallow edges - the current will flow less strongly there.
[Re: ThunderMuffin]
#156666 10/08/08 09:33 PM 10/08/08 09:33 PM |
Posts: 30 Lake Norman, NC | That body of water can be challenging. You'll be sailing to what you think is open water, only to start seeing sea grass tops popping out of the water.... no visible land in sight for a mile in any direction...
Glad I learned to sail my cats there on my H17 with kick up boards. One of the reasons why I like the P-18.2 - rotating centerboards. Although during their rotation they'll raise up about 2-inches higher than the deck surface. If you're sitting in juuuuust the right place and hit bottom fast enough... WHAMMO! The "boys" will get a quick awakening. Don't ask me to tell you how I learned this. But all in all - a good catamaran for gunk-holing and shallow-water work. For those who asked: I like to refer to monohull sailboats as half-cats and trimarans as a cat-and-a-half. (My dad used to call them sailboats with training wheels.) My little jab at the slower, monohull side of sailing. <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
[Re: Doug_P182_LKN]
#156667 10/09/08 08:32 AM 10/09/08 08:32 AM | Anonymous
| Anonymous
Unregistered | The local resturants call 1/2 cats... Chicken Chow Mein | | |
4,339
guests, and 524
