Painting Question? #156806
10/10/08 12:56 AM
10/10/08 12:56 AM
Simon C Offline OP
Simon C  Offline OP
Hi All,
I've just had to do some internal repairs and I have replaced a 45cm length of my working deck. ( Mosquito Cat tortured ply construction). The boat is finished in 2 part epoxy paint. I was wondering if anyone could suggest a way to get a smooth transition in the paint job between the repair and the existing deck. I am not kitted up for spraying so I will be brushing.
Simon
Taipan AUS341
Re: Painting Question? [Re: Simon C] #156807
10/10/08 01:36 AM
10/10/08 01:36 AM
ncik Offline
ncik  Offline
Aside - Try rolling and laying off with a brush to get a smoother finish than just brushing. Test the roller first though to make sure it survives the two-pack solvents.
Re: Paint Transition
Tape off on the existing painted deck say an inch from the repair, lightly wet sand over the existing painted area upto the tape, (re-tape if necessary), paint the repair up to the tape and remove the tape with the paint still wet, wet sand and buff the transition area.
If you want to experiment and the job is small enough, you can try a Preval re-usable spray can...
Preval
...available from Bunnings. Two-pack will require thinning.
Re: Painting Question? [Re: ncik] #156808
10/10/08 02:07 AM
10/10/08 02:07 AM
Simon C Offline OP
Simon C  Offline OP
Thanks for the advice.
I hadn't heard of the Preval but it looks like it'll do the job. It would have to give a better finish than a brush I would think so I'll give it a try.
Thanks again for your help.
Simon
Taipan AUS341
Re: Painting Question? [Re: Simon C] #156809
10/10/08 06:45 AM
10/10/08 06:45 AM
Kingston SE South Australia
JeffS Offline
JeffS  Offline
Simon if you look up International perfection paint they give a good online demo of rolling then tipping. I've used this with singlepack brightside for good results as well.
regards
Jeff Southall
Current boats
Nacra 5.8 1667 Ram Raider
Nacra 18 Square
Arrow 1576
Re: Painting Question? [Re: JeffS] #156810
10/10/08 06:21 PM
10/10/08 06:21 PM
ncik Offline
ncik  Offline
My roll and tip experience was also with the single pack Brightside and it produced a really good finish, as good as any spray job.
Maybe you could try that instead, certainly cheaper.
Re: Painting Question? [Re: ncik] #156811
10/12/08 06:40 AM
10/12/08 06:40 AM
Simon C Offline OP
Simon C  Offline OP
Thanks guys,
I found the video on roll & tipping.
I'll give that a go. I'm using a 2 pac to match what's already on the boat so it's probably a less less hazardous way of going about it. <img src="http://www.catsailor.com/forums/images/graemlins/shocked.gif" alt="" />
Simon
Taipan AUS341
Re: Painting Question? [Re: Simon C] #156812
10/13/08 06:38 AM
10/13/08 06:38 AM
JeffS Offline
JeffS  Offline
Wear a good respirator
regards
Jeff Southall
Current boats
Nacra 18 Square
Arrow 1576
0 registered members (), 567 guests, and 26 spiders.
