| Racing Rules Jan 1 2009 CHANGES!! #158492 10/28/08 04:17 PM 10/28/08 04:17 PM |
Posts: 623 Gulf Coast | | | | Re: Racing Rules Jan 1 2009 CHANGES!!
[Re: ThunderMuffin]
#158561 10/29/08 09:57 AM 10/29/08 09:57 AM |
Posts: 3,906 Clermont, FL, USA | 18.2.e is interesting, did we talk about that?
Situation:
Crowded 'C' mark rounding (no gate) starboard boat is on the layline and let's say four boats all on port setting up to pinwheel around the mark. According to 18.2.e the starboard tack/inside boat may not be entitled to room because "from the time the overlap began, the outside boat has been unable to give mark-room, she is not required to give it"
I'm also assuming the "outside" boat to the starboard tacker is the inside boat of the port pinwheel. In order to give starboard/inside boat room the "outside" (inside of the port pinwheel) boat would need get room from its outside boat and on down the chain. If it goes to the room it could be argued... I asked for room and didn't get it. So, starboard is hosed.
Anybody else read it the same way?
[Re: David Ingram]
#158576 10/29/08 12:03 PM 10/29/08 12:03 PM |
Posts: 12,310 South Carolina | I'm not sure Dave - the old rule-set wasn't exactly crystal clear on that situation to begin with and I think there is still some complicated application here too. 18.4 clearly states that a boat that must gybe at the mark must not sail any further from the mark than necessary but nothing else directly applies to a "gybe". if you stick with 18.2 a) and b) (since they refer to each other), it's pretty clear that the overlapped, starboard "gybing" boat is the inside boat and is owed inside room at the mark. The only other exclusions to crossing tacks in the zone is 18.3 and it clearly indicates "tacking" and not gybing...so it doesn't apply here. As you pointed out 18.2 e) seems to give the outside boat some leeway in it's ability give room. While I'm not sure under what circumstances an outside boat could claim the were "unable" to give room, the kicker here is that the overlap has to be developed from "clear astern". "Clear Astern" is defined in the appendix to be the following: Clear Astern and Clear Ahead; Overlap One boat is clear astern of another when her hull and equipment in normal position are behind a line abeam from the aftermost point of the other boat’s hull and equipment in normal position. The other boat is clear ahead. They overlap when neither is clear astern. However, they also overlap when a boat between them overlaps both. These terms always apply to boats on the same tack. They do not apply to boats on opposite tacks unless rule 18 applies or both boats are sailing more than ninety degrees from the true wind. scratch that...I thought this might not apply since the boats would be on opposite tacks...but we're clearly talking about gybes and we're sailing at more than 90 degrees from the true wind...so "clear astern" does appear to apply to this situation...but can you really measure "clear astern" overtake from opposite gybe boats (at the angles we sail)?
Jake Kohl | | | Re: Racing Rules Jan 1 2009 CHANGES!!
#158582 10/29/08 12:19 PM 10/29/08 12:19 PM |
Posts: 3,906 Clermont, FL, USA | I think that clear astearn thing could be argued too, but I need a white board.
In the end, the new rule is a bit better and it does take away the starboard layline approach a bit. Even with the old rule if it was crowded the starboard approach could be a low percentage play. I'd hate to be the judge for that one.
[Re: David Ingram]
#158584 10/29/08 12:41 PM 10/29/08 12:41 PM |
Posts: 12,310 South Carolina | I don't think it made it more difficult for a starboard gybe boat to force it's way in at a c-mark rounding. I don't think it changed much. If you read 18.2 e) again and focus on the details, I think you can pretty much forget about trying to apply it. (e) If a boat obtained an inside overlap from clear astern and, from the time the overlap began, the outside boat has been unable to give mark-room, she is not required to give it. Even if you could argue that a starboard gybe boat obtained overlap from clear astern, you're going to have a hard time arguing that the port gybe boat is "unable to give mark-room from the time the overlap began" since opposite gybe boats are overlapped pretty much from the moment they become opposite gybe boats. I still would like to know what circumstance would prevent the port gybe, outside, boat from being unable to give mark room. This rule applies like a domino to any of the more outer pinwheel boats so you can't argue that starboard gybe boat was not entitled to room because the port gybe boat had boats stacked up outside her.
#158590 10/29/08 12:59 PM 10/29/08 12:59 PM |
Posts: 3,906 Clermont, FL, USA | See that's just it, I think you could and you could do it successfully.
[Re: HMurphey]
#158595 10/29/08 01:25 PM 10/29/08 01:25 PM |
Posts: 3,906 Clermont, FL, USA | No matter how right you are two boats cannot occupy the same space at the same time. Enforcing your rights with contact will not work. Any sailor worth their salt can see a situation developing and create a plan B which could and probably should include a protest.
I know how I would approach the issue, but I'm a pretty passive person as many of you already know. I'm a lover not a fighter.
[Re: David Ingram]
#158598 10/29/08 01:47 PM 10/29/08 01:47 PM |
Posts: 6,049 Sebring, Florida. | Insert song lyrics here to; "Where is the Love..." The rap version of course.
Blade F16 #777
19,104
guests, and 781
