Racing Rules Jan 1 2009 CHANGES!! #158492
10/28/08 04:17 PM
10/28/08 04:17 PM
Gulf Coast
tami Offline OP
tami  Offline OP
Gulf Coast
Re: Racing Rules Jan 1 2009 CHANGES!! [Re: tami] #158540
10/29/08 08:19 AM
10/29/08 08:19 AM
Gulf Coast
tami Offline OP
tami  Offline OP
Gulf Coast
hello hello, weren't there a discussion about Rule 18 recently, which same rule is now CHANGED!!
Re: Racing Rules Jan 1 2009 CHANGES!! [Re: tami] #158556
10/29/08 09:23 AM
10/29/08 09:23 AM
Portland, Maine
ThunderMuffin Offline
Portland, Maine
tami,
I think we already had a discussion about these new rules which is why there aren't any replies.
Re: Racing Rules Jan 1 2009 CHANGES!! [Re: ThunderMuffin] #158561
10/29/08 09:57 AM
10/29/08 09:57 AM
Clermont, FL, USA
David Ingram Offline
Clermont, FL, USA
18.2.e is interesting, did we talk about that?
Situation:
Crowded 'C' mark rounding (no gate) starboard boat is on the layline and let's say four boats all on port setting up to pinwheel around the mark. According to 18.2.e the starboard tack/inside boat may not be entitled to room because "from the time the overlap began, the outside boat has been unable to give mark-room, she is not required to give it"
I'm also assuming the "outside" boat to the starboard tacker is the inside boat of the port pinwheel. In order to give starboard/inside boat room the "outside" (inside of the port pinwheel) boat would need get room from its outside boat and on down the chain. If it goes to the room it could be argued... I asked for room and didn't get it. So, starboard is hosed.
Anybody else read it the same way?
F18 USA 242
http://www.solarwind.solar
Re: Racing Rules Jan 1 2009 CHANGES!! [Re: David Ingram] #158574
10/29/08 11:42 AM
10/29/08 11:42 AM
SE Pa. or Chesapeak Bay
HMurphey Offline
HMurphey  Offline
Yea, I saw that too. I think that maybe a problem!!!! and dangerous ....
Note: "starboard" has starboard rights and has had a inside overlap FOREVER!!! Shouldn't the port tack boats seen this developing and anticipated the need for inside mark rounding room.
So what do you do? .... come in outside of the "zone" on starboard w/ starboard rights and force all the port tackers to tack away????? then starboard tacks for the mark???
Starboard's Hail: "I will be outside the zone and I'm on starboard, STARBOARD!!!! ..."
Now once you hail "starboard" you are required to hold your course (unless a collision is imminent) ... does the starboard boat need to continue through until they are clear of the port boats and then tack for the mark????
What if starboard tack does not feel that the port tackers are responding and are going to T-Bone him so he tacks away and while doing so a port tack still hits starboard tack .... I can think of arguments for both sides under this rule....
This could be "interesting ... very interesting..."
Tami, thanks for posting the new RRS's
HarryMurphey
Re: Racing Rules Jan 1 2009 CHANGES!! [Re: David Ingram] #158576
10/29/08 12:03 PM
10/29/08 12:03 PM
I'm not sure Dave - the old rule-set wasn't exactly crystal clear on that situation to begin with and I think there is still some complicated application here too. 18.4 clearly states that a boat that must gybe at the mark must not sail any further from the mark than necessary but nothing else directly applies to a "gybe".
if you stick with 18.2 a) and b) (since they refer to each other), it's pretty clear that the overlapped, starboard "gybing" boat is the inside boat and is owed inside room at the mark. The only other exclusions to crossing tacks in the zone is 18.3 and it clearly indicates "tacking" and not gybing...so it doesn't apply here.
As you pointed out 18.2 e) seems to give the outside boat some leeway in it's ability give room. While I'm not sure under what circumstances an outside boat could claim the were "unable" to give room, the kicker here is that the overlap has to be developed from "clear astern". "Clear Astern" is defined in the appendix to be the following:
Clear Astern and Clear Ahead; Overlap One boat is clear astern of another
when her hull and equipment in normal position are behind a line abeam
from the aftermost point of the other boat’s hull and equipment in normal
position. The other boat is clear ahead. They overlap when neither is clear
astern. However, they also overlap when a boat between them overlaps both.
These terms always apply to boats on the same tack. They do not apply to
boats on opposite tacks unless rule 18 applies or both boats are sailing more
than ninety degrees from the true wind.
scratch that...I thought this might not apply since the boats would be on opposite tacks...but we're clearly talking about gybes and we're sailing at more than 90 degrees from the true wind...so "clear astern" does appear to apply to this situation...but can you really measure "clear astern" overtake from opposite gybe boats (at the angles we sail)?
Re: Racing Rules Jan 1 2009 CHANGES!! [Re: Jake] #158582
10/29/08 12:19 PM
10/29/08 12:19 PM
Clermont, FL, USA
Clermont, FL, USA
I think that clear astearn thing could be argued too, but I need a white board.
In the end, the new rule is a bit better and it does take away the starboard layline approach a bit. Even with the old rule if it was crowded the starboard approach could be a low percentage play. I'd hate to be the judge for that one.
F18 USA 242
Re: Racing Rules Jan 1 2009 CHANGES!! [Re: David Ingram] #158584
10/29/08 12:41 PM
10/29/08 12:41 PM
I don't think it made it more difficult for a starboard gybe boat to force it's way in at a c-mark rounding. I don't think it changed much. If you read 18.2 e) again and focus on the details, I think you can pretty much forget about trying to apply it.
(e) If a boat obtained an inside overlap from clear astern and,
unable to give mark-room, she is not required to give it.
Even if you could argue that a starboard gybe boat obtained overlap from clear astern, you're going to have a hard time arguing that the port gybe boat is "unable to give mark-room from the time the overlap began" since opposite gybe boats are overlapped pretty much from the moment they become opposite gybe boats.
I still would like to know what circumstance would prevent the port gybe, outside, boat from being unable to give mark room. This rule applies like a domino to any of the more outer pinwheel boats so you can't argue that starboard gybe boat was not entitled to room because the port gybe boat had boats stacked up outside her.
Re: Racing Rules Jan 1 2009 CHANGES!! [Re: Jake] #158587
10/29/08 12:54 PM
10/29/08 12:54 PM
HMurphey Offline
HMurphey  Offline
Before the applicable mark rounding rules were clear cut ..... now they are situationally dependent .... this makes them "fuzzy ... how many boats in a pinwheel do you need to deny an inside overlap/mark rounding room to a starboard tack boat?????
and lets think this through the next few steps when the starboard tack boat is denied "room" ....
They can head-up or foot-off ...
1) Head-up Scenerio: they head-up, accelerating into the port tack boats shreaming "STARBOARD" ... at some point they are no longer in the "zone" and the rules revert to simple port/starboard. Will the port tack boats anticipate this????
2)Footing Scenerio: the starboard boat "foots-off" possibly passing on the wrong side of the mark and heading straight into the boats rounding the mark into a head on collision.
What happens if the starboard boat has been on the starboard layline forever and the port tack boat only reached the port layline recently and tacked??? the starboard boat has had a inside overlap from the moment the port tack boat tacked onto the port layline ...
I have never been a fan of coming into the leeward mark on starboard where we only had to deal w/ "room to make a Tactical rounding" or "room to make a rounding in a seamanshiply manor" .... but this adds another whole layer of issues to mark rounding ....w/ NO safe options. It promotes head-on collisions, before it was mostly glancing side to side contact .... is this what we want?
On first analysis, IMHO this doesn't make mark roundings simpler or safer ... but adds complications and danger ....
Sail Flat, Sail Fast, Sail SAFE
HarryMurphey
H18MAG/P19MX
Re: Racing Rules Jan 1 2009 CHANGES!! [Re: Jake] #158590
10/29/08 12:59 PM
10/29/08 12:59 PM
Clermont, FL, USA
Clermont, FL, USA
See that's just it, I think you could and you could do it successfully.
F18 USA 242
Re: Racing Rules Jan 1 2009 CHANGES!! [Re: David Ingram] #158592
10/29/08 01:08 PM
10/29/08 01:08 PM
HMurphey Offline
HMurphey  Offline
Do which one successfully???
A: Deny room forcing a starboard tacker into a T-Bone or head-on collision .....
B: As a Starboard tack boat claim your inside overlap?
Remember the whole mess depends on the boat handling skills of the worst sailor of the group and the kindness of the most aggressive sailor involved ... and as we tend to be "TypeA" personalities in this sport ....
HarryMurphey
Re: Racing Rules Jan 1 2009 CHANGES!! [Re: David Ingram] #158593
10/29/08 01:09 PM
10/29/08 01:09 PM
Gulf Coast
tami Offline OP
tami  Offline OP
Gulf Coast
1. I don't recall a recent discussion of the NEW rules - where's that at?
2. Can we get sketches/drawings of the situations? Descriptions are confusing AFAIC.
Re: Racing Rules Jan 1 2009 CHANGES!! [Re: HMurphey] #158595
10/29/08 01:25 PM
10/29/08 01:25 PM
Clermont, FL, USA
Clermont, FL, USA
No matter how right you are two boats cannot occupy the same space at the same time. Enforcing your rights with contact will not work. Any sailor worth their salt can see a situation developing and create a plan B which could and probably should include a protest.
I know how I would approach the issue, but I'm a pretty passive person as many of you already know. I'm a lover not a fighter.
F18 USA 242
Re: Racing Rules Jan 1 2009 CHANGES!! [Re: David Ingram] #158598
10/29/08 01:47 PM
10/29/08 01:47 PM
Insert song lyrics here to; "Where is the Love..." The rap version of course.
0 registered members (), 21,873 guests, and 1,863 spiders.
17 minutes ago
