| Problems with grass -- the seaweed kind #15963 01/31/03 12:49 PM 01/31/03 12:49 PM |
Joined: Nov 2002 Posts: 5,558 Key Largo, FL & Put-in-Bay, OH... Mary OP
Posts: 5,558 Key Largo, FL & Put-in-Bay, OH... | Lots of places we have sailed have sea grasses floating on top of the water that catch on the daggerboards and rudders. This is especially true of small inland lakes in the Midwest in late summer, but it is also a problem on Biscayne Bay in Miami. On a two-person boat, it is usually the crew's job to keep making the rounds of the boat, raising and lowering daggerboards and rudders to free them of seaweed during a race.
My question is, what do you do if you are a singlehander and have all those foils to keep clearing constantly? Does anybody have an answer to this?
I read something in the Laser Newsletter about this, because they have the same problem. Apparently, some people were trying spraying their daggerboard and rudder with McLube to see if weeds would slide off better, but the editor said he tried it for half of the races in one regatta and he could not see any difference.
Laser sailors also do some spectacular rolls one way or the other to dump the weeds, but it doesn't sound feasible for catamarans.
Another thing Laser have tried is sailing with their rudders **** up more so weeds will slide off, but this is not legal for those boats except in shallow water, because there is some evidence that tilting the rudders up more makes the boats go faster.
For catamarans someone made the not serious suggestion that the fronts of the foils could be made razor-sharp so they just cut through the grass -- hmmm, and anything else they might come in contact with, like a crew member falling off the boat.
Anyway, what do you singlehanders do about the grass problem? | | | No boards - no problem, Mon
[Re: Mary]
#15967 01/31/03 04:00 PM 01/31/03 04:00 PM |
Posts: 3,293 Long Beach, California | Hi Mary - On the 4.3, popping the offended rudder up and back down quickly works for me, though I usually have big eyes while doing it  . A boardless boat is probably infinitely easier to keep moving through grass, because your hand never comes off the steering when clearing the rudders, even on the low side. On bigger boats, I'm always the guy scrambling around as the skipper freaks out. The kelp forests in Santa Barbera were particularly interesting!
| | | Re: Problems with grass -- the seaweed kind
[Re: Mary]
#15976 02/01/03 07:38 PM 02/01/03 07:38 PM |
Posts: 1,911 South Florida & the Keys | During a race it should not cause you to lose time or position on the competition, all racers would have the same conditions? (maybe) jmo
Eric Arbogast ARC 2101 Miami Yacht Club | | | Re: Possible solution-
[Re: Mary]
#15981 02/05/03 07:17 PM 02/05/03 07:17 PM |
Posts: 344 Arkansas, USA | Mary- You would have to rig up a different up/downhaul mechanism on your Taipan. One solution that might work is a modification of the system often retrofitted to N 5.8/6.0's that I employed on my old "A" cat. I had a bunji uphaul and rigged a line downhual. The rudder downhaul line ended in the front of the rudder in a "cutout" ala the Nacras then ran under a bolt in the rudder housing, up over another bolt at the top of the housing under the tiller arm and ended in a microblock. Then a second line ran from the back of the rear beam, through the microblock, and back to a cheekblock mounted atop the rearbeam (on the Taipan this line would have to run through the rear beam then through a throughdeck block in the front of the rear beam or through a microblock/cheekblock mounted under the inside of the rear beam- If you choose the under beam mounting location then the end of this line needs to be from the outside of the rear beam) and then towards the midline of the boat along the rearbeam to a releasing camcleat (made for dinghy rudders- it releases upon impact and is adjustable) and then I ran it through a plastic line guide (so simply pulling it on the other side of the line guide would cleat it). The line was continuous between sides and I used small Spectra lines. The rudder could be released by merely uncleating from the cam cleat (you did have to go to the middle of the boat in my case but you could mount the cleat wherever) and then quickly pulling the line down. Remember though- you really do NOT want the rudders "loaded" when they are part way up or down regardless or you will break/bend/tear up either the transom pins, rudder case and/or rudders so regardless you will have to at least slow down and ease sails during the process.
Hope this might help-
Kirt
Kirt Simmons
Taipan #159, "A" cat US 48
[Re: Mary]
#15982 02/08/03 09:02 AM 02/08/03 09:02 AM |
Posts: 1,449 | Mary, I have made a similar system as mentioned by Kirt for my son's Paper Tiger. The main difference being two rubber rings inside the rear beam. (They were the type used here to joint clay sewer pipes. Takes a good load to stretch them but the still cushion impact and will stretch when you run aground). There is a continuous line between the rudder cleats , which are located just in front of the rear beam, and the slack in this line is pulled forward by a light shock cord. The end result is you can flip both windward and leeward rudders without moving from your normal sailing position. When it comes to centreboards they can be controlled by uphaul and downhaul lines. If you go to my web page www.geocities.com/phillbrander choose Chined Construction the 32nd photo shows the steering system, cleats and line. In the photo the line is taught because both rudders are up. The first time a rudder was release to remove the weed it came up so fast it thru the weed past the centrecase. The shock cord inside the carbon rudder tube is getting a little tired after two seasons and now needs replacing. Just the way I've tried to approach the problem. I'll be putting the same system on my new Taipan when I build its steering system. Phill
2,601
guests, and 416
