Problems with grass -- the seaweed kind #15963
01/31/03 12:49 PM
01/31/03 12:49 PM
Mary Offline OP
Mary  Offline OP
Lots of places we have sailed have sea grasses floating on top of the water that catch on the daggerboards and rudders. This is especially true of small inland lakes in the Midwest in late summer, but it is also a problem on Biscayne Bay in Miami. On a two-person boat, it is usually the crew's job to keep making the rounds of the boat, raising and lowering daggerboards and rudders to free them of seaweed during a race.
My question is, what do you do if you are a singlehander and have all those foils to keep clearing constantly? Does anybody have an answer to this?
I read something in the Laser Newsletter about this, because they have the same problem. Apparently, some people were trying spraying their daggerboard and rudder with McLube to see if weeds would slide off better, but the editor said he tried it for half of the races in one regatta and he could not see any difference.
Laser sailors also do some spectacular rolls one way or the other to dump the weeds, but it doesn't sound feasible for catamarans.
Another thing Laser have tried is sailing with their rudders **** up more so weeds will slide off, but this is not legal for those boats except in shallow water, because there is some evidence that tilting the rudders up more makes the boats go faster.
For catamarans someone made the not serious suggestion that the fronts of the foils could be made razor-sharp so they just cut through the grass -- hmmm, and anything else they might come in contact with, like a crew member falling off the boat.
Anyway, what do you singlehanders do about the grass problem?
Re: Problems with grass -- the seaweed kind [Re: Mary] #15964
01/31/03 02:26 PM
01/31/03 02:26 PM
On my H17, this isn't much of a problem because the grass slides over the centerboards easily. If it gets stuck on the rudders, I just pop them up real quick to dump it. Never really come though a lot of grass, just some reeds that are natural on the chesapeake bay.
Re: Problems with grass -- the seaweed kind [Re: Mary] #15965
01/31/03 03:01 PM
01/31/03 03:01 PM
Neb
flounder Offline
flounder  Offline
Neb
I raced a Hobie 18mag around the country one summer a few years back. Ran into the same problem, but I remembered something I read about the old America's Cup boats.
I read something about flossing the keel to keep it clean under sail. So I made two "flossing sticks". I used 2-3' pieces of PVC tubing. Drilled holes in them so that water would run right through. I unbraided some old mainsheet line and attached it to the ends of each small pole.
They looked like little mops, but boy did they clear weeds out of the rudders fast. Just floss the daggers and rudders real quick and they were clean. Cost $2 to make.
Re: Problems with grass -- the seaweed kind [Re: Mary] #15966
01/31/03 03:11 PM
01/31/03 03:11 PM
Crystal Beach/Dunedin CSWY Fl.
catsailorp19mx Offline
Hi Mary,
I would probably rather deal with "big wind" than have to put up with the weeds. Thankfully, we don't get much of it here in the Gulf. Although, it does show up at different times of the year.
I am "assuming" your question is directed towards racing. Sorry if my assumption is incorrect.
When I single hand my P19 in distance races, (depending on wind strength) I either clear the boards manually, or lift the windward hull & "usually" they slip off. As you well know, the rudders aren't that easy to dis-engage on the Prindle system.
The windward rudder "usually" clears when out of the water.
No matter how you cut the cake, valuable time is lost when you do this without a crew.
Dave
No boards - no problem, Mon [Re: Mary] #15967
01/31/03 04:00 PM
01/31/03 04:00 PM
Hi Mary -
On the 4.3, popping the offended rudder up and back down quickly works for me, though I usually have big eyes while doing it . A boardless boat is probably infinitely easier to keep moving through grass, because your hand never comes off the steering when clearing the rudders, even on the low side.
On bigger boats, I'm always the guy scrambling around as the skipper freaks out. The kelp forests in Santa Barbera were particularly interesting!
Re: Problems with grass -- the seaweed kind [Re: Mary] #15968
01/31/03 05:04 PM
01/31/03 05:04 PM
catman Offline
catman  Offline
A nice thing about the pivoting center boards on my Mystere is they can be cycled without having to go to the low side to do it. The rudder is part of life.
Re: Problems with grass -- the seaweed kind [Re: catman] #15969
01/31/03 06:07 PM
01/31/03 06:07 PM
Mary Offline OP
Mary  Offline OP
Thanks, all, but I think it is impossible. Picture this: You're singlehanding a Taipan 4.9 in a distance race on Biscayne Bay. You are out on the trapeze. You are steering and handling both a mainsheet and a hooter sheet. You need to clear grass off your leeward board and rudder. What conceivable way would there be to do that without coming in off the trapeze, heading up and basically stopping the boat? And you have to repeat the procedure very frequently.
Re: Problems with grass -- the seaweed kind [Re: Mary] #15970
01/31/03 07:06 PM
01/31/03 07:06 PM
Mary Offline OP
Mary  Offline OP
I've got it!! A Portsmouth modification factor for grass!
Re: Problems with grass -- the seaweed kind [Re: Mary] #15971
02/01/03 02:23 AM
02/01/03 02:23 AM
^ Please god no.
Ratings-Man will invade and write a 10-page thesis on the conceivablility of such an idea.
Re: Problems with grass -- the seaweed kind [Re: Mary] #15972
02/01/03 12:59 PM
02/01/03 12:59 PM
Yardley PA
DanWard Offline
DanWard  Offline
Yardley PA
Your right Mary...Picking up a clump of grass while racing singlehanded is very frustrating. As was mentioned earlier the boards are no problem for us H17 sailors. If you have to dump the main to unload the rudders, go to the back, raise and lower a rudder, you can loose a lot of ground. I do the following: First keep a sharp eye on the water ahead and try to dodge the clumps. If I do pick up a clump and I'm considering a tack anyway, I tack and hope it will come off. If its on the weather rudder I try to fly the hull to get it to drop off. Downwind I use only one rudder. Otherwise I just take the hit and go back and clear it...Dan
Re: Problems with grass -- the seaweed kind [Re: Mary] #15973
02/01/03 04:54 PM
02/01/03 04:54 PM
The Netherlands (North West Eu...
RobLammerts Offline
RobLammerts  Offline
Believe it or not,
But on “our” lake they cut the grass twice a year.
Rob Nacra 6.0 European version Nr 090 + Spi
Re: Problems with grass -- the seaweed kind [Re: RobLammerts] #15974
02/01/03 05:00 PM
02/01/03 05:00 PM
Mary Offline OP
Mary  Offline OP
And do they rake up the grass after they cut it? And then what do they do with all that grass?
Re: Problems with grass -- the seaweed kind [Re: Mary] #15975
02/01/03 05:42 PM
02/01/03 05:42 PM
Baton Rouge, LA
Dean Offline
Dean  Offline
Baton Rouge, LA
My boat has three T-foils. Each "T" is about three feet wide. This boat can roll a lot of grass.
Going down Biscayne Bay in the Conch Cup was memorable for it's grass. I could only come up with one solution that worked reasonably well (short of going out there on the hulls to clean it off by hand). I stopped the boat and sailed backwards three or four times and that usually slid (slid?) most of it loose. Don't feel bad about doing it. The big long distance boats (eg. VO 60's) do the same thing to deal with the problem when it's caught on their keels.
Re: Problems with grass -- the seaweed kind [Re: Mary] #15976
02/01/03 07:38 PM
02/01/03 07:38 PM
South Florida & the Keys
arbo06 Offline
arbo06  Offline
During a race it should not cause you to lose time or position on the competition, all racers would have the same conditions? (maybe) jmo
Eric Arbogast
ARC 2101
Miami Yacht Club
Re: Problems with grass -- the seaweed kind [Re: arbo06] #15977
02/01/03 10:03 PM
02/01/03 10:03 PM
Mary Offline OP
Mary  Offline OP
That would be the case if it were a one-design fleet or if it were a mixed Portsmouth fleet of all two-person boats. But if it is a mixed Portsmouth fleet where most or all of the other boats have two people and you are on a single-hander .....
Really, folks, never mind. There is no good solution to this problem other than having a crew.
Re: Problems with grass -- the seaweed kind [Re: Dean] #15978
02/01/03 11:51 PM
02/01/03 11:51 PM
Mary Offline OP
Mary  Offline OP
Wow, I didn't even think about the problem hydrofoil boats would have with grass. Could a big patch of grass potentially cause a pitchpole?
Re: Problems with grass -- the seaweed kind [Re: Mary] #15979
02/02/03 11:27 AM
02/02/03 11:27 AM
Western Australia
Stewart Offline
Stewart  Offline
Western Australia
the only fully flying International 14 (foiled) had its foils destroyed when they ran through a "pod" umm "school" umm "bunch" umm a "blubber" of jellyfish..
So gues a pile of seas grass would b even more effective at foil destruction
Re: Problems with grass -- the seaweed kind [Re: Mary] #15980
02/04/03 11:45 AM
02/04/03 11:45 AM
Baton Rouge, LA
Dean Offline
Dean  Offline
Baton Rouge, LA
No. Grass collecting on the foils will not cause a pitchpole because an accumulation will cause the foils to lose their ability to fly and the boat simply will come back to the water very slowly. While flying I don't seem to have the grass problem because hitting it and moving at 25mph in Biscayne Bay causes enough action to keep the foils clear.
If sailing backwards for a few feet doesn't clear the stuff it's a real pain. You have to come up into the wind, raise the three foils from their position extended 4' down into the water and walk out on the beam to reach down and clean the stuff off each foil and the rudder, as well. The boat is 17' wide and it takes a little while to reach all the spots. While single handing it's a heads-up operation and "one hand for the boat" doesn't make it an easy chore.
In the Conch Cup I think I cleared grass only three or four times. I was too lazy to do it more often.
Re: Possible solution- [Re: Mary] #15981
02/05/03 07:17 PM
02/05/03 07:17 PM
Arkansas, USA
Kirt Offline
Kirt  Offline
Arkansas, USA
Mary-
You would have to rig up a different up/downhaul mechanism on your Taipan. One solution that might work is a modification of the system often retrofitted to N 5.8/6.0's that I employed on my old "A" cat. I had a bunji uphaul and rigged a line downhual. The rudder downhaul line ended in the front of the rudder in a "cutout" ala the Nacras then ran under a bolt in the rudder housing, up over another bolt at the top of the housing under the tiller arm and ended in a microblock. Then a second line ran from the back of the rear beam, through the microblock, and back to a cheekblock mounted atop the rearbeam (on the Taipan this line would have to run through the rear beam then through a throughdeck block in the front of the rear beam or through a microblock/cheekblock mounted under the inside of the rear beam- If you choose the under beam mounting location then the end of this line needs to be from the outside of the rear beam) and then towards the midline of the boat along the rearbeam to a releasing camcleat (made for dinghy rudders- it releases upon impact and is adjustable) and then I ran it through a plastic line guide (so simply pulling it on the other side of the line guide would cleat it). The line was continuous between sides and I used small Spectra lines. The rudder could be released by merely uncleating from the cam cleat (you did have to go to the middle of the boat in my case but you could mount the cleat wherever) and then quickly pulling the line down.
Remember though- you really do NOT want the rudders "loaded" when they are part way up or down regardless or you will break/bend/tear up either the transom pins, rudder case and/or rudders so regardless you will have to at least slow down and ease sails during the process.
Hope this might help-
Kirt
Kirt Simmons Taipan #159, "A" cat US 48
Re: Problems with grass -- the seaweed kind [Re: Mary] #15982
02/08/03 09:02 AM
02/08/03 09:02 AM
Mary,
I have made a similar system as mentioned by Kirt for my son's Paper Tiger.
The main difference being two rubber rings inside the rear beam. (They were the type used here to joint clay sewer pipes. Takes a good load to stretch them but the still cushion impact and will stretch when you run aground).
There is a continuous line between the rudder cleats , which are located just in front of the rear beam, and the slack in this line is pulled forward by a light shock cord.
The end result is you can flip both windward and leeward rudders without moving from your normal sailing position.
When it comes to centreboards they can be controlled by uphaul and downhaul lines.
If you go to my web page www.geocities.com/phillbrander choose Chined Construction the 32nd photo shows the steering system, cleats and line.
In the photo the line is taught because both rudders are up.
The first time a rudder was release to remove the weed it came up so fast it thru the weed past the centrecase.
The shock cord inside the carbon rudder tube is getting a little tired after two seasons and now needs replacing.
Just the way I've tried to approach the problem.
I'll be putting the same system on my new Taipan when I build its steering system.
0 registered members (), 2,745 guests, and 559 spiders.
Yesterday at 10:10 AM
