| Re: New Hobie F18?
[Re: ThunderMuffin]
#159876 11/07/08 12:49 PM 11/07/08 12:49 PM |
Posts: 1,430 california | looks like a inverted anti-pitchpole foil Is it just the angle of the pic or is the hull asymetric?
| | | Re: New Hobie F18?
[Re: Will_R]
#159889 11/07/08 03:49 PM 11/07/08 03:49 PM |
Posts: 12,310 South Carolina | It's too high up for that though...and it's indented the wrong way to be an anti-pitchpole feature. I can't figure out what the idea is behind that.
Jake Kohl | | | Re: New Hobie F18?
[Re: Cheshirecatman]
#159896 11/07/08 05:13 PM 11/07/08 05:13 PM |
Posts: 12,310 South Carolina | Just a spray rail. Look where it fairs back into the hull. The Mk1 hawk had a problem with the spray from this area flowing over the rounded deck and hitting the main beam making the leeward hull a very wet area for the crew.
Cheshirecatman OK, I can see that. I can really feel that water washing over the deck and hitting the front beam on the I20 and it drives me nuts. Nacra solved that on the Infusion by making the top forward deck relatively flush with the main beam. They wouldn't stop a pitchpole but maybe you can get a little lift out of it with those chines (or whatever you would call them).
#159898 11/07/08 05:55 PM 11/07/08 05:55 PM |
Posts: 266 UK | Just a spray rail. Look where it fairs back into the hull. The Mk1 hawk had a problem with the spray from this area flowing over the rounded deck and hitting the main beam making the leeward hull a very wet area for the crew.
Cheshirecatman OK, I can see that. I can really feel that water washing over the deck and hitting the front beam on the I20 and it drives me nuts. Nacra solved that on the Infusion by making the top forward deck relatively flush with the main beam. They wouldn't stop a pitchpole but maybe you can get a little lift out of it with those chines (or whatever you would call them). I can't see the angle or additional buoyancy of the rails doing anything for pitchpole resistance, even in a modest bow down attitude. However, look at the low down hull buoyancy. Cheshirecatman | | | Re: New Hobie F18?
[Re: mbounds]
#159910 11/07/08 09:03 PM 11/07/08 09:03 PM |
Posts: 266 UK | It's not like this is a new concept, although the implementation is different. Shark Catamaran (check out the spray deflector on the bow): If you look closely at these Cougar catamarans, you can see the same spray deflector (this is from 1965): You can add: Hellcat and other early c-class Manta Thai Shearwater Dolphin Yachting World Cat and I am sure many others. All 40+ years old. Cheshirecatman | | | Re: New Hobie F18?
[Re: macca]
#159913 11/07/08 09:40 PM 11/07/08 09:40 PM |
Posts: 5,582 “an island in the Pacifi... | My guess is the slots will be attached to tubes that vent out the stern. They will produce a rooster tail. That will bring in the powerboat crowd that can no longer pay for gas. US Sail Level 2 Instructor US Sail Level 3 Coach | | | Re: New Hobie F18?
[Re: grob]
#159927 11/08/08 08:11 AM 11/08/08 08:11 AM |
Posts: 1,884 Detroit, MI | It could also be to add stiffness locally, or just styling.
Gareth DING! DING! DING! We have a winner! | | | Re: New Hobie F18?
[Re: F-18 5150]
#159951 11/08/08 06:16 PM 11/08/08 06:16 PM |
Posts: 3,116 Annapolis, MD | ahh... consider it character building to forgo the pretty pretty and just try to win with the basics!
But... if the contest is limited just to the bar after the race... Pretty Pretty has enormous rhetorical value and you should absolutely go for it.
Now curved banana boards in the A class that is a story yet to be told... so it could be worse!
crac.sailregattas.com
| | | Re: New Hobie F18?
[Re: Mark Schneider]
#159952 11/08/08 06:22 PM 11/08/08 06:22 PM |
Joined: Sep 2007 Posts: 531 Lake Murray SC FasterDamnit
Posts: 531 Lake Murray SC | Spray rails on the Cougar were a total failure...
E-Scow 24' ULDB
473
guests, and 558
