| New User/New sailor #160053 11/11/08 02:23 AM 11/11/08 02:23 AM |
Joined: Oct 2008 Posts: 35 Chesapeake Bay MD BlowBoater OP
Posts: 35 Chesapeake Bay | Just saying hey to everyone on here.. I'm going to be needing a lot of your help! I recently purchased a 1990 Nacra 5.8 and am currently working on getting it all refreshed and ready to sail. ![[Linked Image]](http://inlinethumb22.webshots.com/31189/2892963600079449133S600x600Q85.jpg) Now, I have lived on the water and around boats my entire life, but I have 0 experience with a Nacra and only a little with a Hobie 16, so please bear with me. What I have replaced so far: -Cam Cleats on jib and main sail blocks. -Here is why. ![[Linked Image]](http://inlinethumb40.webshots.com/2599/2338113480079449133S500x500Q85.jpg) -Main sheet and jib sheet lines. This boat already has a double trapeze set up but needs shock cords return lines. Any advice on the length and width of these I will need? It also need new shock cord to hold the dagger boards in place. Any advice on these size of these? It came with a new tramp I need to lace on and all the shrouds and stay seems to be in good shape, as well as the diamond wires? Any advice is GREATLY appreciated and I can't wait to sail it. Thank you. -I did think of another question. How should the bridle for the jib be attached to the hull? Cable? How ling? I will put a pic up tomorrow of how it currently is.
| | | Re: New User/New sailor
[Re: MD BlowBoater]
#160063 11/11/08 07:51 AM 11/11/08 07:51 AM |
Posts: 396 Annapolis Md. | Use the search engine on this site and you will see a whole lot of Nacra 5.8 fans out there and check the Performance Catamarans site for the assembly manual. Also you'll get more resonse with a more specific thread title that mentions the 5.8 Ed
Still hazey after all these beers. F-16 Falcon #212
[Re: Hullflyer1]
#160067 11/11/08 09:25 AM 11/11/08 09:25 AM |
Posts: 1,253 Columbia South Carolina, USA | Just my preference, but it does work better...Use seperate shock cord for each trapeze and double the lenght(run to other side and back around a small block. The advantage is you or the crew can go around the forestay in a stuff and the shock cord will be long enough to not break. If it does break, then only 1 trapeze is flyng around loose instead of both side(if they were connected together). Instead of shock cord for the daggers, glue in a piece of carpet to give the dagger well resistnace to the board. The shock cord will get inyour way, and the carpet is just a cleaner solution.
The bridle should be a seperate 2 piece cable witha connector plate tying them together in the middle. The forestay attaches to the plate. Some boats were retrofitted with an aluminum crosspiece(cant remeber the name) that the forestay attches to, bringing the tack of the jib lower.
One suggestion, take your mast off the boat and float it in the water. Anywhere it bubbles, seal it!
Godd luck, keep us posted, and always wear your pfd on a cat, especially if you are new to cats and its getting colder.
[Re: HMurphey]
#160095 11/11/08 01:19 PM 11/11/08 01:19 PM |
Posts: 976 France |
And one last little thing ... if you notice we all sign our posts w/ our names ... it is a matter of honor amongst us .... ( there have been "ISSUES" in the past w/ anonymous posters saying nasty things ....), so please be so kind as to sign your name.
No offense, but I never sign with my name. And I'll probably never do. I'm not anonymous either as there are a number of people from my club on this board, and they can all vouch for me: I really exist! And if you look through my post you can find the club I'm sailing at and my sail number, or even the last regatta I went to and the results of it. The reason for using an alias is not for lack of honor or to offend anyone but it is because my name is relatively unique and I don't want my sailing activity to register more than my professional activities in search results. ie, when my name is pushed into google I want my resume to pop up first, not some crazy idea I had related to sailing... So please do not assume that all posters not using their real names are somewhat hiding for a nefarious purpose. There are reasons that could make us choose not to use our names. | | | Re: New User/New sailor
[Re: pepin]
#160101 11/11/08 01:51 PM 11/11/08 01:51 PM |
Posts: 833 St. Louis, MO, | Pepin,
That's easy. Just misspell your name. My name is so common that I have 12 that work for my company alone. I get calls from bill collectors regularly looking for some dead beat Mike Hill. And, No it's not me.
Some people use their name and others don't. Certainly not to big of a deal unless you come in here looking for a fight.
Welcome to the site. There is a wealth of info here.
Your foil attaches to the hulls with two short wires. Then one long wire attaches to the bridle foil and to the main hound on your mast. There is some adjustable chain plate that attaches to the foil part and then you attach the main wire to that.
Good Luck. Do searches and ask specific questions and you will get good answers.
Mike Hill N20 #1005
Mike Hill N20 #1005
[Re: pepin]
#160107 11/11/08 02:44 PM 11/11/08 02:44 PM |
Joined: Jan 2008 Posts: 3,655 Portland, Maine ThunderMuffin
Posts: 3,655 Portland, Maine | And one last little thing ... if you notice we all sign our posts w/ our names ... it is a matter of honor amongst us .... ( there have been "ISSUES" in the past w/ anonymous posters saying nasty things ....), so please be so kind as to sign your name.
This is patently false and entirely misleading. Whether or not we sign with our real names is irrelevant compared to the quality of the words and ideas that we post. | | | Re: New User/New sailor
[Re: pepin]
#160110 11/11/08 03:00 PM 11/11/08 03:00 PM | andrewscott
| andrewscott
Unregistered | The reason for using an alias is not for lack of honor or to offend anyone but it is because my name is relatively unique and I don't want my sailing activity to register more than my professional activities in search results. ie, when my name is pushed into google I want my resume to pop up first, not some crazy idea I had related to sailing... I COMPLETELY AGREE>>>> Pepin's ideas related to sailing are CRAZY!!!!! hehe... | | | Re: New User/New sailor
[Re: ]
#160127 11/11/08 06:24 PM 11/11/08 06:24 PM |
Posts: 291 | Hey Mike. Are my bill collectors calling you again? Just tell them I died, or is it that you died. Oh wait, my name is not Mike Hill.  Seriously though, welcome to a fun group of knowledgable sailors.
[Re: MD BlowBoater]
#160131 11/11/08 07:48 PM 11/11/08 07:48 PM |
Posts: 1,383 Kingston SE South Australia | As a totally unbiased sailor I welcome you to the forum and acknowlege your superior ability to choose a cat. It took me a few different cats before I got the 5.8 and you managed to purchase the best catamaran ever made first time round  . regards
[Re: dave mosley]
#160138 11/11/08 08:23 PM 11/11/08 08:23 PM |
Posts: 1,246 Orlando, FL | Just my preference, but it does work better...Use seperate shock cord for each trapeze and double the lenght(run to other side and back around a small block. Dave, where are you securing the ends? 1 to the trap' handle ... other around the block [tied to opposite tramp lace] and back to ....? where?
USA 777
[Re: ThunderMuffin]
#160144 11/11/08 09:11 PM 11/11/08 09:11 PM |
Posts: 2,490 On the Water | Get jake to step in here and post his most excellent tramp bungie system. Its overkill but we use a toned-down version of it and it works great. KISS, just tie it off on the opposite side tramp lacing where the rear beam and hull meet.
Philip USA #1006 | | |
2,484
guests, and 587
