| Re: Luricating spinnaker & chute
[Re: Steve_Kwiksilver]
#16031 02/03/03 03:10 PM 02/03/03 03:10 PM |
Posts: 5,590 Naples, FL | West Marine sells it under the name "SAILCOTE" in aerosol and liquid forms. If I recall, someone said that it softens the spray bottles over time, so you may want to store it in the original container...
| | | Re: Lubricating spinnaker & chute
[Re: Eric Anderson]
#16037 02/13/03 11:58 AM 02/13/03 11:58 AM |
Posts: 5,558 Key Largo, FL & Put-in-Bay, OH... | Eric, I just have some dumb questions: Can that teflon spray be used on other things, like car windshields, ski goggles, sailing goggles...? And would it make a boat faster if it were sprayed all over the hulls? | | | Re: Luricating spinnaker & chute
#16038 02/13/03 12:04 PM 02/13/03 12:04 PM |
Posts: 23 | Hi:
McLube is teflon based, and yes, it's pretty expensive. We've tried nylon spinnakers coated with McLube, and spinnakers made from Dynalite, which is silicone impregnated nylon. For our boat, (Tcat), and I suspect most larger boats, Dynalite is too light for long life. Spinnakers launch and retrieve well, but the retrieval line wears small tears into the cloth (according to Mitch Booth who looked at ours), and Dynalite stretches out pretty quickly. The McLube option works pretty darn well actually. We use a small weed sprayer to apply it, using the finest mist we can cajole out of the sprayer. That's actually more than needed. McLube suggests using a low pressure, high volume paint sprayer to apply the stuff. According to them, the amount required is very small. If it turns your kite white, then you are applying too much. McLube stays on our kites for quite a while. We occaisionally reapply it near the pulldown patches. We coat the launcher with it as well. A little less than a pint (half liter) can do a 250 ft^2 kite. That's about $15.00 worth of the stuff. We periodically wetsand our launcher with 600 grit paper as well.
-Greg | | | Re: Lubricating spinnaker & chute
[Re: Mary]
#16039 02/13/03 01:36 PM 02/13/03 01:36 PM |
Posts: 364 | Yes, some sailors coat their entire boats; there's a McLube ad in, I believe, Sailing World, from a year or so ago, announcing that the world champion Star boat used Sailkote as a hull coating. The website suggests an array of other uses as well.
Andrew Tatton
Nacra 20 "Wiggle Stick" #266
Nacra 18 Square #12
[Re: Andrew]
#16040 02/13/03 02:26 PM 02/13/03 02:26 PM |
Posts: 5,558 Key Largo, FL & Put-in-Bay, OH... | Okay, then the next questions are: Does use on the hulls actually make boats faster? And, if so, why is it legal to use it? I remember when the use of long-chain polymers was banned because they made boats faster. | | | Re: Lubricating spinnaker & chute
[Re: Mary]
#16043 02/13/03 04:09 PM 02/13/03 04:09 PM |
Posts: 2,844 42.904444 N; 88.008586 W | West Marine sells a set of two bottles, one cleaner, the other, Teflon polish-sort of a liquid wax. I've used it before, worked great! I wonder if it would work on by spin.
The West Marine stuff is designed for boat hulls.
There has been alot of research about coatings that can disrupt the laminer flow over the hull. Regular wax is usually not recommended for this reason.
F-18 Infusion #626- SOLD it!
458
guests, and 34
