| Rudder repair epoxy selection advice #160837 11/19/08 11:21 AM 11/19/08 11:21 AM |
Posts: 291 | I have a Hobie 18SX with EPO rudders. I have noticed damage to the rudders in the form of a puncture where the set screw used to control rake has worn (crushed) into the rudder. I want to fill the holes with somesort of epoxy to repair the rudder but I want to select a hard epoxy to minimize the time it takes for the problem to reoccour. I was actually thinking about using JB WELD but I wanted the opinion of those much smarter than me before I proceed. The holes are about 1/4 inch diameter and probably 1/8 to 1/4 inch deep. Thanks for your input.
| | | Re: Rudder repair epoxy selection advice
[Re: JACKFLASH]
#160842 11/19/08 11:47 AM 11/19/08 11:47 AM |
Posts: 1,382 Essex, UK | I think I'd be inclined to epoxy something like a short S/S self tapping screw into the rudder head at that point to take the load.
John Alani ___________ Stealth F16s GBR527 and GBR538 | | | Re: Rudder repair epoxy selection advice
[Re: Rolf_Nilsen]
#160857 11/19/08 12:39 PM 11/19/08 12:39 PM |
Posts: 1,430 california | My recomendations. Drill out the hole and remove all debris and damaged material. then fill with a good quality filler and epoxy. I had a hole in the head of my tiger rudder head and filled it with West system. Hard as a rock and very stable. when using the resin let it fil the hole then lightly tap the rudder with a rubber malet to allow any trapped air to escape. Make sure to tape the work area off first as the epoxy is hard to get off once set. Fill the hole completely but allow a slight upward bubble to form on top. The resin epoxy will settle as it goes off. the bubble can then be sanded smooth and your good to go. Btw gel coat will not readily stick to most epoxy's so keep the epoxy as the finish coat. Hope this helps.
[Re: F-18 5150]
#160865 11/19/08 12:51 PM 11/19/08 12:51 PM |
Posts: 12,310 South Carolina | JB weld is an epoxy based adhesive with fillers for adhesion and resistance to abrasion (very likely finely powdered aluminum, talc, and lord knows what else). It should actually hold up quite well as far as abrasion resistance goes.
If you want to fill with epoxy, I would make a mixture of any good laminating epoxy (West, MAS, etc.) with aluminum powder (abrasion and UV resistance), and cabosil. The cabosil will make it very thick and almost impossible to sand...this is just the long way around to make your own JB Weld (but you can make it as thick/thin as you need).
Jake Kohl | | | Re: Rudder repair epoxy selection advice
[Re: JACKFLASH]
#160872 11/19/08 01:21 PM 11/19/08 01:21 PM |
Joined: Jul 2004 Posts: 125 Clinton, Mississippi rattlenhum
Posts: 125 Clinton, Mississippi | You may get better advice specific to the H-18, but most of the H-16 sailors I know (including myself) just remove the set screw. The adjustable bar in the upper casting controls how far back the rudder go, which is what's most important. I guess the thinking is that, while underway at least, the rudder will be pushed back and there's no need to limit it's forward range.....not much room for slop there anyway. I'd recommend you get rid of the set screw after making the repair and see how it goes.....you can always put it back later.
Jerome Vaughan Hobie 16 Clinton, Mississippi
[Re: HMurphey]
#160915 11/19/08 06:07 PM 11/19/08 06:07 PM |
Posts: 291 | Excellent advise from all as usual. With the aftermarket sails I need to find that sweet spot before I make it a perm repair. It seems like it felt good after I tuned the rudders to the Hobie 18 performance manual. I think I will fix the hole and retune to that manual and then sail a couple days to confirm I like it and then follow the above recomendations. Thanks again guys.
[Re: HMurphey]
#160946 11/19/08 10:20 PM 11/19/08 10:20 PM |
Posts: 805 Gainesville, FL 32607 USA | Thisd sounds correct- but--- Epoxy doesn't cure with UV, just faster with heat, assuming close to the proper ratio between amine and epoxy has been mixed. You are supposed to wash off the amine blush then sand it. The dogma is to then use epoxy with fumed silica gel= gelcoat. (PS: It yellows)
Polyester does cure with UV- or ozone + air inside the unused can, eventually. But it doesn't do well on top of epoxy.
[Re: dacarls]
#161028 11/20/08 10:25 PM 11/20/08 10:25 PM | cattail
| cattail
Unregistered | with the epoxys mentioned you will want to weigh the part a and b on a gram scale before adding any fillers. The epoxy sold in the 2 part siringe or hobby shops 15 or 30 min stuff can be mixed eyeball measure just dont try to make it set faster by adding more hardener. Chopped glass or milled. Carbon fibers are a good thickener in a pinch some of those other fillers like cabosil you have to buy a lot more that you need. Another good thickening is microballons they are either white or rust colored sold in hobby stores also. Should be able to gelcoat over epoxy if its sanded and cleaned with alcohol. | | |
657
guests, and 123
