| Whats The Advantage #161014 11/20/08 05:55 PM 11/20/08 05:55 PM |
Joined: Oct 2008 Posts: 6 South Gippsland ausstricker OP
Posts: 6 South Gippsland | Gday everybody ill be looking at getting into F16 in a couple of years time using a taipan, whats the advantage of widening the platform 160mm (Taipan 2340mm & F16 2500mm)to make it widest possible as per F16 Reg.s Cheers Ausstricker
Boat Less & Cant Sail To Save My Self (16ft Dolphin Currently Under Major Rebuild)
| | | Re: Whats The Advantage
[Re: ncik]
#161020 11/20/08 06:43 PM 11/20/08 06:43 PM |
Posts: 3,528 Looking for a Job, I got credi... | Advantages - More righting moment (RM) - More speed upwind as more RM once hull is flying - More speed downwind as more RM once hull is flying
Disadvantages - New beams - New tramp - Maybe new mainsheet track - I doubt it, my traveller rarely goes out more than 12 inches. - minor Trailer mods - A tiny little bit more windage - Not Taipan compliant - More weight (unless you go to lighter beams)
F16 - GBR 553 - SOLD I also talk sport here | | | Re: Whats The Advantage
[Re: scooby_simon]
#161035 11/21/08 02:39 AM 11/21/08 02:39 AM |
Posts: 4,451 West coast of Norway | My thinking is that more RM dont always result in better speed, but there is a sliding scale. Anyway, if you sail in a strong-wind area and you care about it, go max beam  (there is so much psychology into this, so if you think you are at an disadvantage, do something to equalize it). Simon, since we have the advantage of having the SCHRS guru in the class, how much would the SCHRS rating change in this case? Always useful to know a bit about how large the theorethical difference is. | | | Re: Whats The Advantage
[Re: Rolf_Nilsen]
#161037 11/21/08 03:56 AM 11/21/08 03:56 AM |
Posts: 3,528 Looking for a Job, I got credi... | Simon,
0.002 single handed boat goes from 0.982 to 0.984!
[Re: Rolf_Nilsen]
#161046 11/21/08 05:53 AM 11/21/08 05:53 AM |
Joined: Dec 2003 Posts: 244 Central Coast NSW Australia TonyJ
Posts: 244 Central Coast NSW Australia | The 4.9 has been around for a while now, and is still the bench mark small cat in Aus.
They have the advantage of being well developed. A well sailed Taipan is a fast boat and will be hard to beat in most conditions.
My advise, for what it's worth, is, get your self a Taipan, stay Taipan legal, and enjoy.
Put on a spinnaker and enjoy the best of both worlds.
Regards Tony
Teach them how to think.
Not what to think.
Aus
Blade 002
[Re: Rolf_Nilsen]
#161059 11/21/08 08:52 AM 11/21/08 08:52 AM |
Posts: 3,528 Looking for a Job, I got credi... | Dont sound like a large difference in the pure physical sense for real world racing? But the mental difference might be huge. I dont want to wear you out on SCHRS Simon, but if one was to add sailarea to the main, or remove weight, how much area/weight does a difference of 0.002 make then? Just to put the question into perspective and as long as we all understand this is a hypothetical discussion. Rolf, no problem, doing this on SCHRS is very ver yeasy. To make it clear; I took a FULLY OPTIMISED Single handed F16 and changed the beam to make it less; this gave the 0.002. I do not have the measurements for the Tiapan. To take a thinner F16 and get it back up to 0.982 with sail area would require an additional 0.1sqm of mainsail or 0.5sqm of Spi.
[Re: ausstricker]
#161071 11/21/08 12:54 PM 11/21/08 12:54 PM |
Joined: May 2006 Posts: 954 Mumbles Y.C Wales U.K Mark P
Posts: 954 Mumbles Y.C Wales U.K | A wider platform without a longer water line length is also more prone to pitch polling! However, this is splitting hairs in this instance. Also, a slightly narrower beam will raise the windward hull sooner reducing wetted hull area/drag and I also think narrower Cats like the Stealth R point higher than the Stealth F16 but there's no real proof of this occurance. Therefore, you have a couple of years to consider the pro's and con's MP*MULTIHULLS | | | Re: Whats The Advantage
[Re: simonp]
#161127 11/22/08 03:59 AM 11/22/08 03:59 AM |
Posts: 9,582 North-West Europe | Actually, making the Taipan wider by 160 mm makes a much larger difference optically. Throw in the selftacker and that Taipan F16 trampoline feel alot more roomy than that of the Taipan 4.9. That was the conclusion of the Dutch Coast Challenge of 2004 when both boats layed side by side.
I can't really explain why but the difference is very noticeably or at least I though so. Additionally I hadn't expected that so maybe my feelings were amplified by the surprise of the change.
[Re: scooby_simon]
#161165 11/22/08 11:21 PM 11/22/08 11:21 PM |
Posts: 1,479 Thailand | Yes but then you may also want to calculate in your crew weight as in "real world racing" the boat will not sail itself..;-)) Dont sound like a large difference in the pure physical sense for real world racing? But the mental difference might be huge. I dont want to wear you out on SCHRS Simon, but if one was to add sailarea to the main, or remove weight, how much area/weight does a difference of 0.002 make then? Just to put the question into perspective and as long as we all understand this is a hypothetical discussion. Rolf, no problem, doing this on SCHRS is very ver yeasy. To make it clear; I took a FULLY OPTIMISED Single handed F16 and changed the beam to make it less; this gave the 0.002. I do not have the measurements for the Tiapan. To take a thinner F16 and get it back up to 0.982 with sail area would require an additional 0.1sqm of mainsail or 0.5sqm of Spi.
[Re: Tornado_ALIVE]
#161167 11/23/08 02:47 AM 11/23/08 02:47 AM |
Posts: 1,479 Thailand | OK if you say so... More beam = more righting momentum = more speed
Nowhere more noticeable than on the upwinds particularly when punching of a start line.
Other factors such as sailing skill will always come into play, but reduction in beam is a guaranteed disadvantage. That you cannot hide that or argue against.
[Re: Buccaneer]
#161169 11/23/08 03:12 AM 11/23/08 03:12 AM |
Posts: 4,451 West coast of Norway | T_A
no denying there is a difference. I wanted to quantify how large the difference is, and the SCHRS numbers suggests that in this specific case the difference in speed is very small? Perhaps even negligible? By all means, I think Ausstricker should widen the boat if the lack of 16cm beam bothers him, but buying a set of new sails and rigging a selftacker sounds to me like a better investment if he wants to go F16 racing.
My personal pet theory is that a lot of people let things like percieved disadvantages on their gear get in the way of their performance on the water. Playing the game of 'blaming' like "My boat have 16 cm less beam than everybody elses, so of course we were last in heavy wind" and all sort of other 'plausible reasons' to excuse their lack of performance. I even think this can drab very experienced racers as well, making them perform less than their potential or sub-par to their skills. In in this context, 16cm can make a world of difference on the water, but only until some new excuse to blame can be thought up, and we sailors are very creative when it comes to thinking up excuses. Not directed towards you T_A, just an explanation on my standpoint to the question starting this thread. It is all in our heads!
2,651
guests, and 342
