| Re: n20 mast
[Re: scooby_simon]
#161222 11/23/08 04:56 PM 11/23/08 04:56 PM |
Posts: 3,224 Roanoke Island ,N.C. | C'mon Macca ,spill the beans. Todd p.s. Love those VX 40 vids, just get a decent cameraman.That one's funny lookin'.
| | | Re: n20 mast
[Re: macca]
#161233 11/23/08 11:09 PM 11/23/08 11:09 PM |
Posts: 2,490 On the Water | don't worry guys, the new alloy rig was tested properly before release Andrew, Tested by whom, . . . where, . . . when?
Philip USA #1006 | | | Re: n20 mast
[Re: P.M.]
#161234 11/24/08 02:38 AM 11/24/08 02:38 AM |
Posts: 1,449 | Pesumeably they are using the Infusion mast extrusion at required length. It would be silly of them not to.
| | | Re: n20 mast
[Re: phill]
#161242 11/24/08 07:08 AM 11/24/08 07:08 AM |
Posts: 3,224 Roanoke Island ,N.C. | I don't think length is the spin bail issue,I doubt they'd shorten the mast. I'm guessing it's strength above the hounds, i.e. lower bail gets it closer to the supported section.There was word floating around awhile ago about double spreaders for support,but that's alot of weight aloft. Todd
| | | Re: n20 mast
[Re: macca]
#161250 11/24/08 10:55 AM 11/24/08 10:55 AM |
Posts: 5,590 Naples, FL | Karl,
In your note from them, did they offer any price estimate for a new N20 with this setup? Or prices for replacement aluminum stick, main and spin?
I liked the "idiot resistant (not idiot proof)" toughness of the carbon mast, but if the aluminum one is as tolerant, is recycleable, and cheaper.....
How did the wing shape affect the performance as seen by the testers? Would we be correct in presuming the mast rotation settings would be different?
And they need something other than a 10:1 mainsheet? Because of the taller mast?
| | | Re: n20 mast
[Re: ThunderMuffin]
#161263 11/24/08 12:20 PM 11/24/08 12:20 PM |
Posts: 833 St. Louis, MO, | Where does that line go and what does it do that is going down into the board well? Also I noticed the diamonds go into the mast here. I'm assuming the mast is sealed above that point? Where do those diamonds attach at the bottom? And how do you adjust diamond tension? I hope this all works out. I'm very concerned about it. I used to hoist that 6.0 and H20 mast and they were a lot heavier. I also really hope that the hoist hieght is not changed on the spin. That would be really disappointing. Our current kite already uses the entire hoist hieght without an inch to spare.
Mike Hill N20 #1005
| | | Re: n20 mast
[Re: Mike Hill]
#161266 11/24/08 12:42 PM 11/24/08 12:42 PM |
Posts: 3,906 Clermont, FL, USA | Look at pages 19 - 21 of the Infusion Assembly Manual to get your answers regarding the mast plug and how to change the diamond tension. Nacra Infusion Assembly Guide
| | | Re: n20 mast
[Re: Mike Hill]
#161269 11/24/08 12:45 PM 11/24/08 12:45 PM |
Posts: 12,310 South Carolina | The diamonds appear to be setup just like the infusion mast...which is a really slick system. There is a foam plug above the diamond wire hole in the bottom of the mast to seal the rest of the mast. Diamond wire tension is adjusted with a big nut at the bottom of the mast...really easy, really slick. I really like having the rotation limiter down low too.
These developments are all coming out of the F18 class and it will be nice to have them on a 20.
Jake Kohl | | | Re: n20 mast
#161278 11/24/08 01:59 PM 11/24/08 01:59 PM |
Joined: Jan 2008 Posts: 3,655 Portland, Maine ThunderMuffin
Posts: 3,655 Portland, Maine | These developments are all coming out of the F18 class and it will be nice to have them on a 20.
Yeah, great for those of us that just blew a wad of cash on a new trampoline without the proper gromets to upgrade! :P | | |
573
guests, and 1,065
