Help with Garmin 76Cx #162079
12/06/08 10:08 AM
12/06/08 10:08 AM
Alachua, FL
Mugrace72 Offline OP
Alachua, FL
HELP!
I have a new Garmin 76Cx and am trying to get it loaded for the Steeplechase next weekend. However, I cannot get our planned course to show any details when I download the course.
On my computer I have lain (?) out both legs with all the waypoints and such and everything shows, such as day markers, shoals, rocks, etc.
When I download it to the GPS unit, all I see are the waypoints. No course line and no details.
Of course, Garmin tech support is not open until Monday at 8AM, so I am hoping to get this resolved today or tomorrow.
Any Garmin experts out there?
Jack Woehrle
HCA-NA 5022-1
USSailing 654799E
Alachua FL/Put-In-Bay
Re: Help with Garmin 76Cx [Re: Mugrace72] #162084
12/06/08 10:16 AM
12/06/08 10:16 AM
On the Water
P.M. Offline
P.M.  Offline
On the Water
Jack,
Is your "planned course" saved as a route? . . . and make sure that map details is set on highest on the handheld.
Philip
USA #1006
Re: Help with Garmin 76Cx [Re: P.M.] #162086
12/06/08 10:24 AM
12/06/08 10:24 AM
Alachua, FL
Alachua, FL
Originally Posted by mummp
Jack,
I'm not sure. Details are at the highest level though.
I'm checking now on the "saved route" tip.
Jack Woehrle
HCA-NA 5022-1
USSailing 654799E
Re: Help with Garmin 76Cx [Re: Mugrace72] #162089
12/06/08 10:40 AM
12/06/08 10:40 AM
Jack,
The waypoints need to be entered sequentially into a route. Then you go to navigate and choose the route you want to navigate. It will start with the first waypoint in that route and once your VMG goes negative for that waypoint, it will automatically switch to the next one.
I usually setup a "day1" route and a "day2" route.
I use my GPS setup with a bearing to the next mark. This way I can look at my compass and tell if I'm headed right at it or at what kind of angles we're sailing to the next point. If it's a finish line, I watch our compass angles to the shore and make that last gybe when the bearing shown on the GPS matches that number.
Re: Help with Garmin 76Cx [Re: Jake] #162092
12/06/08 11:08 AM
12/06/08 11:08 AM
Alachua, FL
Alachua, FL
Originally Posted by Jake
Jack,
I've done all that Jake. I have both days laid/lain out in sequence, with notes, etc. It looks fine on the computer.
OK...now I have successfully downloaded the course track and waypoints, still no details other than the waypoints I marked.
Jack Woehrle
HCA-NA 5022-1
USSailing 654799E
Re: Help with Garmin 76Cx [Re: Mugrace72] #162095
12/06/08 11:12 AM
12/06/08 11:12 AM
are you looking for map features like land, channels, markers, etc.?
Re: Help with Garmin 76Cx [Re: Mugrace72] #162096
12/06/08 11:27 AM
12/06/08 11:27 AM
John_C Offline
John_C  Offline
Did you download the chart set to your GPS? It took me a couple of trys to figure that part out.
My 76 only had a low detail map that it came with, you had to buy and install a Bluechart set.
John
Re: Help with Garmin 76Cx [Re: Jake] #162097
12/06/08 11:33 AM
12/06/08 11:33 AM
Alachua, FL
Alachua, FL
Yes, all the daymarkers, depth graduations, etc.
Or...do they not show on the GPS unit...only the base map in the computer?
The land shows, but again no details.
I think the base map in the GPS is covering the detailed map for some reason.
Also, when I download, the dialogue box has "waypoints" and "routes" active, and "maps" greyed out.
I think the detailed map is not being transferred.
I have tried everything and suppose I will have to call tech Monday unless you have any more ideas.
I hate this crap...I just want to sail the boat!
Thanks Jake
Jack Woehrle
HCA-NA 5022-1
USSailing 654799E
Re: Help with Garmin 76Cx [Re: Mugrace72] #162098
12/06/08 12:05 PM
12/06/08 12:05 PM
If maps is greyed out it could be one of two things:
1) your GPS unit may need a firmware update (check www.garmin.com support)
2) the basic software doesn't come with that information in it. You have to purchase the marine chart for that region. If you have that marine chart (and can see all the channel markers and navigation aids in Mapsource), you need to unlock your GPS to work with that map set. The marine chart resource CD should have the information about how to unlock your GPS unit. You are allowed two GPS units to unlock with any one of the marine chart regions - their security is pretty tight with those charts (as they make a fortune on them).
Re: Help with Garmin 76Cx [Re: Jake] #162099
12/06/08 12:12 PM
12/06/08 12:12 PM
On the Water
P.M. Offline
P.M.  Offline
On the Water
Pretty simple Jack,
Go to the map page on the handheld and go into set-up, select the map datum you want to display, and de-select any other map datums in the area of the route (i.e. de-select City Navigator). When you get to the keys, select the route and tell it to navigate.
Philip
USA #1006
Re: Help with Garmin 76Cx [Re: P.M.] #162100
12/06/08 12:26 PM
12/06/08 12:26 PM
Oh yeah! Phil got it right - there's a tool that looks like Missouri. Use it to select the map areas you want to upload to the GPS before syncing.
Re: Help with Garmin 76Cx [Re: Jake] #162102
12/06/08 12:48 PM
12/06/08 12:48 PM
On the Water
P.M. Offline
P.M.  Offline
On the Water
Garmin only allows one device unlock per license, as of last year. Garmin was forced to change policy due to their contract with NavTeq (whom provides the datum). Garmin took alot of sh!t from their pissed off loyal customers because of it. Garmin has tried to make it easier with reduced prices with updates to a licensed product. Garmin has been working hard to address the high costs of licenses with NavTeq. Seems to me that Navteq pretty much has got the bull by the balls. The contract expires in 2015, and there are only a couple of players (Tele Atlas), the other in bed with Garmin's competition. Garmin tried unsuccessfully to buy both of them.
Philip
USA #1006
Re: Help with Garmin 76Cx [Re: P.M.] #162104
12/06/08 01:30 PM
12/06/08 01:30 PM
Alachua, FL
Alachua, FL
I am making a little progress and I'm sure it is just operator error.
I did buy and unlock the chart software for the region (BlueChart Americas).
It appears I have several conflicting maps that interfere with each other.
Phil, are you saying I cannot really see my route until I actually get to the location?
Right now I am 600 miles away in SC.
Can I not preview or simulate the route on the handheld unit?
Jack Woehrle
HCA-NA 5022-1
USSailing 654799E
Re: Help with Garmin 76Cx [Re: Mugrace72] #162105
12/06/08 01:44 PM
12/06/08 01:44 PM
Alachua, FL
Alachua, FL
Originally Posted by Mugrace72
[quote=mummp]
OK...I got it!
Maps and details are on.
What a great country!
Thanks Jake and Phil.
Jack Woehrle
HCA-NA 5022-1
USSailing 654799E
Re: Help with Garmin 76Cx [Re: Mugrace72] #162144
12/07/08 07:00 AM
12/07/08 07:00 AM
Re: Help with Garmin 76Cx [Re: fin.] #162145
12/07/08 07:43 AM
12/07/08 07:43 AM
Alachua, FL
Alachua, FL
Originally Posted by Tikipete
I'm not sure Pete.
W T F is "reclaimed sheepskin" anyway? smirk
Jack Woehrle
HCA-NA 5022-1
USSailing 654799E
Re: Help with Garmin 76Cx [Re: Mugrace72] #162146
12/07/08 08:06 AM
12/07/08 08:06 AM
Where do you see that?
Re: Help with Garmin 76Cx [Re: fin.] #162147
12/07/08 08:26 AM
12/07/08 08:26 AM
Alachua, FL
Alachua, FL
Though iPhone owners are the envy of many a crowd, the gadgets do have a notorious flaw: A limited battery life, especially when they are used to simultaneously surf the Web, listen to tunes, and text with friends. Enter the Solar iPhone Charger from Solar Arcadia ($45.95). The case made from reclaimed sheepskin doubles as a solar charger.
Jack Woehrle
HCA-NA 5022-1
USSailing 654799E
Re: Help with Garmin 76Cx [Re: Mugrace72] #162218
12/08/08 12:17 PM
12/08/08 12:17 PM
andrewscott
andrewscott
NEW INSTRUCTIONS: Put electronics away in trunk... raise sails and.... (wait for it).... just sail!
Re: Help with Garmin 76Cx [Re: ] #162372
12/10/08 09:21 AM
12/10/08 09:21 AM
Newport, RI
wildtsail Offline
wildtsail  Offline
Newport, RI
Does anyone have any sort of list of coordinates for the Steeplechase they could send me or give me Friday?
I just bought a new GPS but didn't buy any of the software to upload routes and etc... do I need this?
I also have a mac.. so would I have a hard time with any of this software?
Thanks!
-Todd
0 registered members (), 436 guests, and 52 spiders.
