| Carbon Fiber Braces #162255 12/08/08 05:58 PM 12/08/08 05:58 PM |
Joined: Nov 2005 Posts: 5,582 “an island in the Pacifi... hobie1616 OP
Posts: 5,582 “an island in the Pacifi... | One of my kids was born with a lot of physical problems. A few require that he wear plastic braces. They usually last about two years. Shriner's Hospital has an excellent program that takes care of the kids needs until they're 21.
Now that he's 21, he faced with insurance companies that want to play 20 questions before even considering replacements. Part of the process was to be seen by a podiatrist. This doc says he's been working on some carbon fiber braces that he thinks will last a life time. Reading through other threads here I kinda doubt it but they have to be better than what's currently available.
Here's my question. Is there anything I can offer the doc on materials, weaves, etc. that would make them stronger? Any other advice that may be helpful is greatly appreciated.
TIA
US Sail Level 2 Instructor US Sail Level 3 Coach | | | Re: Carbon Fiber Braces
[Re: hobie1616]
#162258 12/08/08 06:11 PM 12/08/08 06:11 PM | Scarecrow
| Scarecrow
Unregistered | Can you post a photo of the current braces.
If you're really looking to improve things for both your son and other's with similar requirements sponsor an undergraduate thesis at your local uni and encourage your Son's doctor to be involved as an adviser. Sponsoring an UG thesis will be relatively cheap (materials etc only) and if the student comes up with something with potential it can be taken to the "market" to get commercial sponsorship for a PHD thesis/commercial development. | | | Re: Carbon Fiber Braces
[Re: hobie1616]
#162259 12/08/08 06:12 PM 12/08/08 06:12 PM |
Joined: Oct 2007 Posts: 199 Constanta, Romania isvflorin
Posts: 199 Constanta, Romania | From what I understand aramid fibers (kevlar) have higher abrasion resistance than carbon, meaning it could be used on the outside of the laminate/part to make it more wearproof. Hope people with more knowledge about this would step in. And Spectra(hight strenght polyethilene) fibers have even higher abrasion resistance than aramid.
regards,
Florin
[Re: hobie1616]
#162265 12/08/08 08:39 PM 12/08/08 08:39 PM |
Posts: 12,310 South Carolina | One of my kids was born with a lot of physical problems. A few require that he wear plastic braces. They usually last about two years. Shriner's Hospital has an excellent program that takes care of the kids needs until they're 21.
TIA
What wears out on the plastic braces? Do they wear out from abrasion or fatigue from flexing? Carbon isn't very abrasion resistant but it is strong and lightweight (I know...duh). Lightweight strength means that you can build something stronger while maintaining the same weight as other materials. If cycle stresses are the leading cause of failure in the other plastic versions then the carbon can probably help...some. If the problem is abrasion, then kevlar would definitely be the way to go. Actually, Kevlar is probably the way to go anyway. It is not as strong as carbon but it is less brittle and handles abrasion and flex much better. Note: use epoxy resins with Kevlar...Kevlar (aramids) aren't naturally clingy and their strength properties are only truly realized when used with epoxy based resins. I thought spectra and the like had adhesion problems with epoxy or polyester resins? However
Jake Kohl | | | Re: Carbon Fiber Braces
[Re: isvflorin]
#162266 12/08/08 08:42 PM 12/08/08 08:42 PM |
Posts: 805 Gainesville, FL 32607 USA | Go to your local surfshop, and find a kid board shaper. One of them surely will find it a challenge to build leg braces from thin plastic foam panel, fiberglass and epoxy that will last for 5 years or more. Cost $50. If this works, the kid could do the same thing in carbon fiber cloth and epoxy: result would be lighter and maybe a bit stronger- and last for more years. Cost $100. Seriously. Kid could do this as a science fair project. Do you still have science in Maui high schools? Or I could do it in my garage if I lived there. (DAC- Ph.D. chemistry, U. Hawaii, Mano'a)
[Re: dacarls]
#162271 12/08/08 09:49 PM 12/08/08 09:49 PM |
Posts: 5,582 “an island in the Pacifi... | Wow! Great responses.
Jake, the failures are caused by flexing. It's usually at the bend between the horizontal foot and vertical leg sections.
dacarls, I know some surf guys who may be able to hook me up with a shaper. Science is still taught in the Maui schools. Our closest is Lahainaluna. I'll nose around and see what I can turn up. I'll also pass your suggestions on materials to the doc. US Sail Level 2 Instructor US Sail Level 3 Coach | | | Re: Carbon Fiber Braces
[Re: hobie1616]
#162329 12/09/08 01:22 PM 12/09/08 01:22 PM |
Posts: 199 Constanta, Romania | There might be something more to add on. If you want to make a part that will last a lifetime it would probably be too heavy and actually hurt other parts of the body because of its rigidity. Considering that the part will be interfacing with human body it should be allowed to flex to a certain extent, and flexing will always destroy a part gradually.
We are just speculating since we don't know how it looks like. Instead of making a bulletproof, ultra tough, ultra high strenght thing I would rather investigate the possibility of making a very very easy to use mould which you could use to make the braces at different intervals (2 years or 5 or 10, don't know). Just layup let it cure and you can have another one in a few hours.
Parts that need to interface with human body should not be rigid, even our bones flex, so the brace should flex too, which will destroy it in time. Better to have an easy to use mould so you can be independant of insurance companies.
I don't think the doc can make a perfect brace the first time - it will either be too rigid or too soft, if you have the mould you can make trials at home with different layups untill satisfied.
Florin
[Re: isvflorin]
#162331 12/09/08 02:21 PM 12/09/08 02:21 PM |
Posts: 5,582 “an island in the Pacifi... | My wife has some additional detail on the AFOs or braces. The podiatrist they saw yesterday said he could get the above carbon fiber AFOs that are already on the market for his cost of $700. OR, if the old plastic ones can be repaired and we can hang on until January, his new product will be available and he'll fit my son for free. Thank you all again for your excellent responses. I'm going to pass all of them on the the doc to see if it will help his development. US Sail Level 2 Instructor US Sail Level 3 Coach | | | Re: Carbon Fiber Braces
[Re: hobie1616]
#167191 02/03/09 07:58 PM 02/03/09 07:58 PM |
Posts: 5,582 “an island in the Pacifi... | We just got back from the podiatrist's office. His product is delayed due to paperwork issues so he fitted my son with some Trulife AFOs. http://trulife.com/product.html?product_id=1012The kid felt an immediate difference in feel and comfort. His feet no longer roll over as he walks which means less wear on his knees. It also means the sides of his shoes don't wear so we won't have to buy new ones every three weeks. I'll post more after the doc gets his product out. US Sail Level 2 Instructor US Sail Level 3 Coach | | | Re: Carbon Fiber Braces
[Re: Karl_Brogger]
#167201 02/03/09 10:19 PM 02/03/09 10:19 PM |
Posts: 5,582 “an island in the Pacifi... | What about metal? Something light and semi exotic like Titanium? Probably horribly expensive, but last a very long time. It's always an option but the vendors are all going with carbon. That's what good press will do. The doc that's developing them says he'll use my kid in developing his product. The payoff for us is he'll give us the AFOs for free for life. That's a huge amount of money. US Sail Level 2 Instructor US Sail Level 3 Coach | | | Re: Carbon Fiber Braces
[Re: hobie1616]
#185787 07/22/09 07:20 AM 07/22/09 07:20 AM |
Posts: 5,525 | The link didn't work, but no matter. It's great to see your son is getting the braces he needs.
Pete Pollard Blade 702
19,857
guests, and 1,091
Mod | | Forums26 Topics22,406 Posts267,062 Members8,150 | Most Online23,979 15 hours ago | | |
