| Re: Blade rudder pins
[Re: PTP]
#162500 12/11/08 09:50 PM 12/11/08 09:50 PM |
Posts: 1,246 Orlando, FL | Patrick,
I've tried various things and still find the Pintle Spring Clip (P/N 21-0413) from Murray's Marine works best. You can also find these at local Hobie Dealers. They're expensive (for what you get -- $3.50 ea.) so you don't want to order them unless you combine it with other stuff (or you'll get killed on shipping and handle fees).
USA 777
[Re: PTP]
#162509 12/12/08 07:13 AM 12/12/08 07:13 AM |
Posts: 606 Maryland | http://www.apsltd.com/Tree/d3000/e740.aspRWO 0767 - Rudder Retaining Clip. Got tired of the pins. I had to remove the plastic covering on the tip (no big deal). I'm sure you can find other manufacturers that produce them without the plastic cover. I was skeptical about adding 2 holes in the stern per hull but no leaks using 3M 5200. 2003 F-18 had them as factory, same for 1998ish Taipans. Kris F-16 WRCRA / WRSC | | | Re: Blade rudder pins
[Re: Kris Hathaway]
#162566 12/13/08 03:28 PM 12/13/08 03:28 PM |
Posts: 6,049 Sebring, Florida. | I've lost 3 of these things in a year, the good news is the rudder never came up and off the pintles, but when you pull up on the beach and it's gone...
I've found something similar to the $3.50 cotter pins at Home Depot for about 50 cents. Looks the same, a little longer, I put them in, use my Leatherman to bend the longer ends over and then put some tape around it just to be sure. I have not noticed any wear on the carbon rudder head, but now I'm going to go look!
I would prefer to have the clips I had on the Inter 20 (like the Ronstan ones listed above), the rudders never came off and there was nothing to lose.
Blade F16 #777
[Re: PTP]
#162572 12/13/08 05:45 PM 12/13/08 05:45 PM |
Posts: 396 Annapolis Md. | I'm learning to copy what Kris does to his boat. Unlike Kris I didn't remove the black caps nor did I use any goo. They work great. Ed
Still hazey after all these beers. F-16 Falcon #212
[Re: PTP]
#162659 12/15/08 07:25 AM 12/15/08 07:25 AM |
Posts: 606 Maryland | No wear on the carbon, leave a small gap so it does not rub but far less of a gap than the pin. I used to chuckle when I finished a race and lost another pin until I capsized without the retaining pin. Then you are in hot water, especially if you're in rough conditions and its your skyward rudder.
The mounting bolts go through the metal shank imbedded in the sterns, so a very tight install can be achieved. Also, 3M 5200 makes sure that it is a non-slip/leak install. One of the few places to use 5200 because it is so permanent, as in not to seat your beams.
Ed. Most of my inspiration is Constantine's Taipan. And.....if only I could reciprocate and finish as well as you.
338
guests, and 106
