| Re: Blade building project..
[Re: phill]
#119640 10/10/07 07:57 AM 10/10/07 07:57 AM |
Joined: May 2003 Posts: 4,451 West coast of Norway Rolf_Nilsen OP
Posts: 4,451 West coast of Norway | Phill, great tip about how to make invisible overlaps, thanks! (I think you have mentioned it before, but now I'll remember it). My source for the carbon comment is Bjørn Thomasson in Sweden ( http://www.thomassondesign.com), the kayak/canoe designer/builder. According to him the density of the carbon fibres in the weave is larger than glass fibres. To get a good matrix around the fibres you would need more epoxy, especially if laid up by hand. With vacuum you come closer to the same amount of epoxy as you would use for the same weight of glass. With a lighter carbon cloth I suppose there are some gains, but it looks like there is a crossing point for carbon vs. glass for this application. It would be good to know if he (I) am wrong or even completely wrong. <img src="http://www.catsailor.com/forums/images/graemlins/smile.gif" alt="" /> I know the hull will be stiffer (as in less deflection) with a +-45 layup outside the core. But I was intrigued to hear that the panel integrity also will be better. Thinking about it, it becomes quite attractive to put the cloth on with overlaps due to the points you made. | | | Re: Blade building project..
[Re: Rolf_Nilsen]
#119644 10/11/07 06:16 AM 10/11/07 06:16 AM |
Posts: 461 Victoria, Oztralia | Hi Rolf
So, have you done the working out for strip planking or has Phill made alternate plans for you. I only ask as I wouldn't mind trying it out myself, I have access to ply, but have wanted to do some strip planking for a long time.
Regards
Matt Harper
Homebuilt Taipan 4.9
[Re: mattaipan]
#119647 10/13/07 05:55 AM 10/13/07 05:55 AM | Anonymous
| Anonymous
Unregistered | Hi Matt,
didn't think you had that much of a death wish.
"I wouldn't mind trying it out myself, I have access to ply, but have wanted to do some strip planking for a long time."
Do you ever want to get out of your shed again <img src="http://www.catsailor.com/forums/images/graemlins/crazy.gif" alt="" />.
Strip planking sounds nice and soft and fuzzy. But it is the method of the DEVIL <img src="http://www.catsailor.com/forums/images/graemlins/shocked.gif" alt="" />. To much trying to deal with soft timber and hard glue lines and the fairing NEVER ENDS <img src="http://www.catsailor.com/forums/images/graemlins/mad.gif" alt="" />.
ARGH! I am having flash backs, got to go sailing to get rid of them <img src="http://www.catsailor.com/forums/images/graemlins/wink.gif" alt="" />. | | | Re: Blade building project..
[Re: Rolf_Nilsen]
#119649 10/13/07 07:10 AM 10/13/07 07:10 AM |
Posts: 461 Victoria, Oztralia | Hi Gary
I like to live on the edge......of insanity <img src="http://www.catsailor.com/forums/images/graemlins/smirk.gif" alt="" />
I won't commit myself to doing it just yet, but certainly like to consider it.
Regards
Matt Harper
[Re: Rolf_Nilsen]
#119653 01/05/08 05:20 AM 01/05/08 05:20 AM |
Joined: May 2006 Posts: 954 Mumbles Y.C Wales U.K Mark P
Posts: 954 Mumbles Y.C Wales U.K | Hi Rolf (Darthvader) It looks as if you're cutting 4mm strips off your approx 25x450mm spruce plank. In my experience I would definitely be using the table saw I've seen in earlier posts. You mentioned previous amateur builders using 'Skilsaws' (your DeWalt) but this may be because they didn't have access to a table saw? I only mention this as you'll have to cut close on 200 strips for 6 hulls I would imagine. Being a qualified joiner I'm very interested in your project so please keep posting and don't let your family commitments hinder you too much <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" /> MP*MULTIHULLS | | | Re: Blade building project..
[Re: Rolf_Nilsen]
#119655 01/05/08 07:00 AM 01/05/08 07:00 AM |
Posts: 954 Mumbles Y.C Wales U.K | I left school and became a qualified Joiner, worked my way up and off the tools, went to university and completed a Bsc (Hons) degree in Project and Construction Management. Worked in management roles for various National Construction companies but really missed the feeling of producing things with my own hands instead of the pen. For the past two years I have been self employed as a Joiner, Carpenter and Builder and I'm loving it. There are certainly different pressures involved but the benefits far out way being just a payroll number in a National Company!! By the way, I hope to design and build a Cat this year I have a lot of ideas in my mind I just have to put them onto paper and tell the wife and I'm sure the later will be the hardest task of this project!!
MP*MULTIHULLS | | |
1 registered members (WorrellGal50),
641
guests, and 94
