Hydroptère does 55 knots! 61knots peak! Pitchpole! #163240
12/21/08 12:17 PM
12/21/08 12:17 PM
Tony_F18 Offline OP
Tony_F18  Offline OP
The french are at it again, crazy boat goes crazy wink
http://www.bymnews.com/news/newsDetails.php?id=48207
Link to French article...
(Babelfish translation)
" The Hydrofoil capsized with 55 knots
AFP
21/12/2008 | Update: 12:01
The Hydrofoil, trimaran with foils, capsized today off Port-Saint-Louis-du-Rhône (Rhone delta) where it tried to beat the speed records absolute with the veil.
The crew, composed of nine people, is healthy and except and the operations of towing were in hand at the end of the morning.
Hydoptère capsized then was turned over to approximately 400 m of the coast, the mast and the foils, kind of wings on which the trimaran floats above the sea, finding itself under water.
Caused by the swell then a gust of wind, the damage occurred whereas the Hydrofoil reached 55 nodes. Stabilized on 500 m, this speed would have constituted the world records with the veil.
The record is currently held by the French Alexandre Caizergues who reached a constant speed of 50,57 nodes out of 500 meters with his kitesurf in Namibia on October 5."
Re: Hydroptère does 55 knots! 61knots peak! Pitchpole! [Re: Tony_F18] #163274
12/21/08 10:51 PM
12/21/08 10:51 PM
Central California
ejpoulsen Offline
ejpoulsen  Offline
Central California
WoW!!!
Sail big; crash big.
Multihull sailing: the original extreme sport.
Eric Poulsen
A-class USA 203
Ultimate 20
Central California
Re: Hydroptère does 55 knots! 61knots peak! Pitchpole! [Re: ejpoulsen] #163279
12/22/08 12:27 AM
12/22/08 12:27 AM
japan
erice Offline
erice  Offline
japan
full marks for effort and getting the crew out in 1 piece
hope the bmw oracle DOG boys can pucker up for some big runs soon
eric e
1982 nacra 5.2 - 2158
2009 weta tri - 294
Re: Hydroptère does 55 knots! 61knots peak! Pitchpole! [Re: erice] #163324
12/22/08 01:39 PM
12/22/08 01:39 PM
Tony_F18 Offline OP
Tony_F18  Offline OP
Re: Hydroptère does 55 knots! 61knots peak! Pitchpole! [Re: Tony_F18] #163370
12/23/08 12:41 AM
12/23/08 12:41 AM
C
cattail
cattail
C
Look at those white caps, got to be 30 kts.
Re: Hydroptère does 55 knots! 61knots peak! Pitchpole! [Re: ] #163386
12/23/08 10:16 AM
12/23/08 10:16 AM
Wind conditions were pretty though with an established wind at 35-38 knots and gusts at over 45 knots off Napoléon beach at Port-Saint-Louis-du-Rhône, which is the speed base of l’Hydroptère, certified by the WSSRC.
That’s in these conditions that the trimaran started the first full speed run of the day. Taking advantage of the established wind, the speed progressively increased: 50, 55 and then 61 knots at top speed!
The squall that provoked this acceleration was really powerful and resulted in l’Hydroptère’s capsizing.
from sail-world
Re: Hydroptère does 55 knots! 61knots peak! Pitchpole! [Re: _flatlander_] #163470
12/24/08 11:37 AM
12/24/08 11:37 AM
Hollister CA, Plano TX
avalondarlyn Offline
I couldn't get the vidio link to work but i found this 8 min of footage from that day. http://www.youtube.com/watch?v=DgNtPETcta4
