| Re: which cat do I purchase ?
[Re: whr241]
#163441 12/24/08 06:02 AM 12/24/08 06:02 AM |
Posts: 744 | Bill, I've owned a few 19s and have to agree with you they are a blast to sail! But if a spinnaker is what you now prefer, try an F18 with a righting pole for single handed sailing. There are a lot of boats out there that simply cannot carry your 2-up crew weight without over stressing the hulls. At 360 crew weight plus, the F18 will really scoot and the 2 of you will smile all day  !!! This is just my opinion from what you describe. There are a lot of pics from the recent NAF18 event. Happy Holidays, Bob
[Re: catman]
#163465 12/24/08 09:57 AM 12/24/08 09:57 AM | andrewscott
| andrewscott
Unregistered | | | | Re: which cat do I purchase ?
[Re: F-18 5150]
#163474 12/24/08 01:15 PM 12/24/08 01:15 PM |
Posts: 2,584 +31NL | Also if you go with the f-18 there is a small main already available for single handing days. There is? | | | Re: which cat do I purchase ?
[Re: Tony_F18]
#163478 12/24/08 03:38 PM 12/24/08 03:38 PM |
Posts: 586 Hobart, Tasmania, Oz. | Also if you go with the f-18 there is a small main already available for single handing days. There is? no  small jib and kite for light crews
[Re: F-18 5150]
#163488 12/24/08 08:12 PM 12/24/08 08:12 PM |
Posts: 586 Hobart, Tasmania, Oz. | It would still be easier to right Mary.
when the boat is on its side the equation is simple. your weight trying to right the boat vs the weight of the rig. Reducing the size of the sail probably does not make that much difference when dry, but a wet sail weighs a lot more. even if its just surface tension.
the further away from the balance point you go the more leverage you have. A taller rig will weigh more than a shorter one even if they are the same weigh on dry land.
I have thought about a storm rig many times and the one thing that stops me is that if you need a small sail to be able to go out then its too windy and should not be on the water anyway.
[Re: Dazz]
#163490 12/24/08 10:26 PM 12/24/08 10:26 PM |
Posts: 713 WA, ID, MT | Dazz, I see the logic in your arguement against sailing when it's blowing hard enough to need a smaller sail(s). But I wanna go sailing at every possible opportunity, as we suffer here from a lot of high pressure/lite air in the summer. And I like the challenge of mastering a boat in 20+ knts of wind. And I like the the idea of a main with a shorter luff(and foot), with a 2 or 3' tether from the masthead hook to the head. My concern is that the new, lower head will want to pull out of the luff groove when the main is sheeted in hard. Seems like I need a strop of some sort wrapping around the mast, through the headboard, cinched tight, to resist the aftward forces acting on the headboard, that are normally handled by the hook at the masthead. Anyone have any thoughts on this? I'd really like to try an A cat main on my HT, but it's an expensive carbon mast, don't want any surprises. Foolish to try?
Dave
[Re: davefarmer]
#163494 12/24/08 10:58 PM 12/24/08 10:58 PM |
Posts: 586 Hobart, Tasmania, Oz. | Hey Dave
It would be very unlikely for the sail to pull out of the mast. bear in mind the majority of the load comes from the downhaul that is pulling vertically.
the main challenge in the setup with be getting the ring unhooked! without the sail headboard twisting the mast wont do anything.
I have read about guys with this setup and they run two halyards, one to the top of the ring and another to the lower side. the idea is to use the second halyard to flick the hook out.
Does not need to be much, a 2mm line should be heaps.
HTH
[Re: Dazz]
#163496 12/24/08 11:14 PM 12/24/08 11:14 PM |
Posts: 1,304 Gulf Coast relocated from Cali... | It would be very unlikely for the sail to pull out of the mast. Not entirely correct. The new wing masts on the Infusion had some problems with this from what I heard. I guess it liked to pull out of the track near the apex of the bend (pre bend). Also when I had my 21SE, I had to put an alluminum track at the top to keep the boltrope from pulling out as well as Calvert installing a 3" long fiberglass rod at the top of the boltrope to keep it in the track while raising the sail. That being said, with some of the pre-bend we run on our rigs, the boltrope can be in danger of pulling if the main is reefed down far enough in the curv of the mast and downhaul is applied. I would assume you are (or would be) using some type of "pig tail ring" to hook up top and can say from first hand experience that it actually unhooks easier than the regular main.
Lee
[Re: TeamChums]
#163499 12/25/08 01:17 AM 12/25/08 01:17 AM |
Posts: 713 WA, ID, MT | Thanks guys, both the current main, and the A main I'm contemplating using, have the hard plastic tubing for a bolt rope. Does this affect anything? If the luff were to pull out of the track, is there any chance of damaging the mast/ luff groove? Lee, I can envision the head wanting to pull out if it has descended much into the mast curve. The A sail is 2' shorter in the luff, do I expect to use a 2' tether to the masthead, so I don't think it'll be very far into the curve. I was sort of expecting to just tip the boat over to rig this set up. So connecting the tether, and releasing it would be no problem. And it would then be easy to secure the headboard to the mast with a short piece of vectran. And the foot of the A main is close to a foot shorter thna the Bim main. Either I continue to sheet from the now substanially forward clew loop, or secure the clew to the boom with an outhaul, and sheet from the aft end of the boom, for a more vertical mainsheet pull. The lightweight aluminum tube(boom) likely wouldn't handle that load. I'm probably in need of a stouter boom for this high wind rig. Or maybe the aftward pull of the mainsheet attached to the clew isn't such a big deal, as I'll be looking for a flat sail for these conditions, and the outhaul forces and reduced mast rotation that this arrangement would produce, might be acceptable. More opinions? Thanks!
Dave | | |
1 registered members (vasil),
289
guests, and 39
