5200 question #163533
12/26/08 08:51 AM
12/26/08 08:51 AM
Atlanta
bvining Offline OP
bvining  Offline OP
Atlanta
Will it bond permenantly to PVC? I've got a sample glued up in the basement, but the stuff takes forever to cure.
Re: 5200 question [Re: bvining] #163537
12/26/08 09:46 AM
12/26/08 09:46 AM
I seriously doubt it.
I'm not sure of the molecular structure of PVC but the stuff used to weld it together is a solvent, not a "cement", that actually melts the PVC. If there was a cement that could be used to marry it to a dissimilar material someone would have figured that out already. It's used in so many construction trades that the "want" to fix it to another medium is decades old.
You can get a watertight bond using the solvent. Another aside, UV rays eat up PVC quickly. Of course you must have a submerged application if you're using 5200.
Re: 5200 question [Re: _flatlander_] #163543
12/26/08 10:51 AM
12/26/08 10:51 AM
sticks to abs plastic quite well. not sure about PVC.
Re: 5200 question [Re: _flatlander_] #163547
12/26/08 11:26 AM
12/26/08 11:26 AM
Atlanta
bvining Offline OP
bvining  Offline OP
Atlanta
Its for a mold, and the reason I tried 5200 is that it was thick and filled the gaps nicely.
The PVC cement is very thin, and the PVC bond weld (2 part) stuff peels off when you pull off the part.
I've had pretty good results with PVC pipe for round parts, and Azek for flat parts, but I want to do a flat with a round, so I need to "weld" pvc pipe to azek(pvc board)
Bill
Re: 5200 question [Re: bvining] #163607
12/28/08 05:01 PM
12/28/08 05:01 PM
Gainesville, FL 32607 USA
dacarls Offline
dacarls  Offline
PolyVinyl Chloride (PVC) is a solid. 3M 5200 sticks to it quite well. It is used with PVC ports attached to polyester fiberglass sailboats all over the world.
Dacarls:
Re: 5200 question [Re: dacarls] #163611
12/28/08 06:47 PM
12/28/08 06:47 PM
“an island in the Pacifi...
hobie1616 Offline
hobie1616  Offline
Would 5200 work on filling a gouge in a rotomolded hull?
US Sail Level 2 Instructor
US Sail Level 3 Coach
Re: 5200 question [Re: hobie1616] #163627
12/29/08 07:38 AM
12/29/08 07:38 AM
South Florida & the Keys
arbo06 Offline
arbo06  Offline
yes.
Eric Arbogast
ARC 2101
Miami Yacht Club
0 registered members (), 515 guests, and 49 spiders.
