interesting righting pole pic #163447
12/24/08 07:37 AM
12/24/08 07:37 AM
japan
erice Offline OP
erice  Offline OP
japan
eric e
1982 nacra 5.2 - 2158
2009 weta tri - 294
Re: interesting righting pole pic [Re: erice] #163448
12/24/08 07:40 AM
12/24/08 07:40 AM
Australia
macca Offline
macca  Offline
Australia
standard Nacra Europe setup
________________________
http://aus300.blogspot.com
Re: interesting righting pole pic [Re: macca] #163452
12/24/08 08:21 AM
12/24/08 08:21 AM
japan
erice Offline OP
erice  Offline OP
japan
made in europe for the european market only?
eric e
2009 weta tri - 294
Re: interesting righting pole pic [Re: erice] #163455
12/24/08 08:28 AM
12/24/08 08:28 AM
Annapolis Md.
LuckyDuck Offline
LuckyDuck  Offline
Annapolis Md.
I like that. Nice clean set up. Would like to get a lead on where it can be had. Thanks. Ed
F-16 Falcon #212
Re: interesting righting pole pic [Re: LuckyDuck] #163462
12/24/08 09:52 AM
12/24/08 09:52 AM
andrewscott
andrewscott
after watching my friends dolphin striker break while in use last summer.. i dont push or pull my boat (on wheels or water) by that area,... isnt that a lot of strain on that striker (when righting)?
Re: interesting righting pole pic [Re: ] #163467
12/24/08 10:10 AM
12/24/08 10:10 AM
RickWhite Offline
RickWhite  Offline
Exactly! It should attach to the beam. Looks a bit short as well. Also, the righting line need to be tightened with bungee to keep from dragging in the water.
Just some quick observations.
Rick
Rick White
www.onlinemarinestore.com
Re: interesting righting pole pic [Re: RickWhite] #163482
12/24/08 05:04 PM
12/24/08 05:04 PM
Australia
macca Offline
macca  Offline
Australia
All the load is on the bridle lines, so there is very minimal load on the striker post which is solid stainless anyway so its not a problem.
Works great and is very simple and clean too. Has been used in Euroland for quite some years now with no complaints or breakages.
Re: interesting righting pole pic [Re: macca] #163504
12/25/08 09:04 AM
12/25/08 09:04 AM
H
Hullflyer1 Offline
Hullflyer1  Offline
H
Where and how do you attach the bridal lines, and do you think one could fabricate a similar system using a boom from a Prindle 16 or 18 as they have goose neck fittings that swivel.
Thanks
Re: interesting righting pole pic [Re: Hullflyer1] #163532
12/26/08 08:50 AM
12/26/08 08:50 AM
South Florida & the Keys
arbo06 Offline
arbo06  Offline
Or, indtall shroud extenders. We right the ARC21 in zero wind easily.
Eric Arbogast
ARC 2101
Miami Yacht Club
Re: interesting righting pole pic [Re: arbo06] #163549
12/26/08 01:14 PM
12/26/08 01:14 PM
H
Hullflyer1 Offline
Hullflyer1  Offline
H
Will shroud extenders work on my nacra 6.0 ? It has a some what of a captive mast base like the older SC-20.
Thanks
Re: interesting righting pole pic [Re: Hullflyer1] #163550
12/26/08 02:39 PM
12/26/08 02:39 PM
arbo06 Offline
arbo06  Offline
I imagine, as long as the mast can't slip out.
Eric Arbogast
ARC 2101
Miami Yacht Club
Re: interesting righting pole pic [Re: erice] #163551
12/26/08 02:52 PM
12/26/08 02:52 PM
Santa Cruz, CA
SurfCityRacing Offline
Santa Cruz, CA
Here's a pic of an adapter that a friend of mine made to install a righting pole on a 17. Attaching it to the beam on the 17 is virtually impossible. This has been used for over a year with no problems.
Re: interesting righting pole pic [Re: SurfCityRacing] #163552
12/26/08 03:28 PM
12/26/08 03:28 PM
The guy was capsized for a year?!?!?
Re: interesting righting pole pic [Re: SurfCityRacing] #163554
12/26/08 04:35 PM
12/26/08 04:35 PM
WEST. MICH. USA
DVL Offline
DVL  Offline
WEST. MICH. USA
Jeremy; I made a pole mount bracket from that picture for my Hobie 18. The only issue that I had was that it splashed a lot of water up through the center tramp lacing. I am trying to resolve that issue.
0 registered members (), 20,834 guests, and 1,148 spiders.
Most Online22,490
14 hours ago
