Carbon Wings? #16457
02/17/03 08:49 PM
02/17/03 08:49 PM
WEST. MICH. USA
DVL Offline OP
DVL  Offline OP
WEST. MICH. USA
Has anyone made a set of wing struts/mounts out of carbon fiber or fiberglass instead of aluminum tubing. I would think that the wing frames would or could be stronger and lighter than the stock aluminum set. Anyone have a design available? What would be the risks?
I'm thinking that a set of wings for my H-18 may help me get the wife & kids sailing more.
Re: Carbon Wings? [Re: DVL] #16458
02/17/03 09:35 PM
02/17/03 09:35 PM
catman Offline
catman  Offline
Lets see. Hobie wings for a 18 are about 1500 bucs. Could you imagine what carbon would cost?
Re: Carbon Wings? [Re: DVL] #16459
02/17/03 11:18 PM
02/17/03 11:18 PM
If I had come across a large surplus of carbon fiber cloth, I'd try it, but like said above, it'd be damn expensive.
That being said, I've come across some CF inexpensively, and I'm going to make a new bow foil out of it for my 17.
Re: Carbon Wings? [Re: catman] #16460
02/18/03 07:37 AM
02/18/03 07:37 AM
Brighton, UK
grob Offline
grob  Offline
Brighton, UK
Those wings can't be aluminium as it should cost:-
Aluminium Tube is about $5/kg x 10kg = $50
Carbon fibre tube is about $50/kg x 10kg = $500
Perhaps they are made from silver
$150/kg x 10kg = $1500
Yep thats it, Cunning devils those guys at Hobie!
Re: use broken mast section [Re: DVL] #16461
02/18/03 08:18 AM
02/18/03 08:18 AM
Ohio
TeamTeets Offline
TeamTeets  Offline
Ohio
At Texel a few years back there were several boats that used a broken carbon mast section to make wings. They would drill and insert a tube from from the beam end through the mast groove. Glass it all together and sand. May one of the the folks from the Netherlands have some pictures?
Mike, Ohio
Re: Carbon Wings? [Re: DVL] #16462
02/18/03 03:37 PM
02/18/03 03:37 PM
Neb
flounder Offline
flounder  Offline
Neb
In my own personal experiance with carbon fiber vs. aluminum, you are not going to lose a bunch of weight. Aluminum alloys we use are very close to the weight of carbon fiber and are much cheaper, easier to work with and easier to fix. We can match the weight of carbon fiber on some applications by drilling out non-load bearing sections and butting others.
H-18 wings are pretty light to begin with. I don't see the performance advantage in using carbon fiber in this application.
Re: Carbon Wings? [Re: flounder] #16463
02/18/03 04:20 PM
02/18/03 04:20 PM
42.904444 N; 88.008586 W
Todd_Sails Offline
Todd_Sails  Offline
did you know that CF conducts electicity?
If Hobie made it, they'd just add a 'comp-tip' to it!
F-18 Infusion
#626- SOLD it!
Re: Carbon Wings? [Re: DVL] #16464
02/18/03 05:00 PM
02/18/03 05:00 PM
catman Offline
catman  Offline
I just want to add, you will enjoy having wings.They make the boat larger,give you drier place to sit and add extra righting moment adding safety when the the breeze picks up. I had the old style wings. With the solid covers they weighed in at 36lbs.
0 registered members (), 504 guests, and 41 spiders.
